Quantcast voltage regulator - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > voltage regulator
Poison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 03-16-2007, 05:24 PM   #1
bgreen
voltage regulator
does anybody know where the voltage regulator is on a 2.5 4clynder 2001 jeep wrangler
bgreen is offline   Reply With Quote
Old 03-16-2007, 06:00 PM   #2
Rule303
I think the ECU/PCM. Why they put it there I have no idea.
Rule303 is offline   Reply With Quote
Old 03-16-2007, 06:02 PM   #3
bgreen
no dont think so I have already replaced the altnator
Old 03-16-2007, 06:04 PM   #4
Rule303
I edited my earlier post after doing a search. Its in the PCM. Why do you think you have a voltage regulation problem? If the voltage is spiking up, it could be a bad ground or connection somewhere. If it goes up and stays up, I'd suspect the regulator.
Old 03-16-2007, 06:26 PM   #5
bgreen
I think it is my voltage regulator becaues My amp guage shows about 8amp while running but if I by pass the plug on the back of the altnator and hook it up strait to the battery it shows about 16amps
Old 03-16-2007, 07:01 PM   #6
bgreen
can anybody help
Old 03-17-2007, 08:10 AM   #7
Rule303
How are you hooking up your "amp guage" to check this? You checking amps or volts?
Old 03-17-2007, 11:12 PM   #8
bgreen
I have checked both I had autozone do it for me, there is some thing keeping my battery from charging and the altnator is good and so is the battery. this is my main problem
Old 03-18-2007, 09:32 AM   #9
Rule303
Connections need to be clean, clean, clean. If they are then you may very well have a problem with the PCM.
Old 03-18-2007, 10:14 AM   #10
Jerry Bransford
Do it right or not at all
Jerry Bransford's Avatar
The alternator's voltage regulator is in the ECM but I would bet big $$$ your problem is not with that. If you're certain the alternator and battery are both ok, I'd be checking for a bad connection(s) somewhere. The voltage regulator has proven to be VERY reliable.
Gone to King of the Hammers, back Sunday!
Jerry's Geezer Jeep II Website
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote
Old 03-18-2007, 11:04 AM   #11
Tinker
I just went round and round chasing down the same problem, turns out.........Bad ground at the battery. Check and recheck All of your grounds.
"Does this look broken to you?"
Tinker is offline   Reply With Quote
Old 03-18-2007, 11:20 AM   #12
Woodyhfd
I had a similar problem with my 97 2.5. My "Check Gauges" light went on and I noticed that my voltmeter was suddenly pegged high. I pulled back into the driveway, made sure that I wasn't on fire, and then tried to start it again. Nothing happened.
Long story short, I had bad battery cables. They were pretty cheap to begin with and were in pretty bad shape. The alternator needed to work too hard to keep the battery charged. It was pushing high amps for too long, overheated and the ECU shut everything down.
I removed and measured the original wires and I built some 4 gauge battery and ground cables from bulk cable and end links that I bought from Advance Auto. They cost about $25 for everything. You can also buy heavy duty ones online for about $100.
Problem solved
"There's only two things in life, but I forget what they are." -John Hiatt
Woodyhfd is offline   Reply With Quote
Old 03-18-2007, 11:18 PM   #13
bgreen
no my battery cables are good I tested it and it is the voltage regulator so I am going to try to find an externial voltage regulator and just wire it up. instead of buying a new pcm
Old 03-18-2007, 11:23 PM   #14
Jerry Bransford
There's more to that wiring that could be the root cause than just the wires leading to the battery. I think you're being too quick and anxious to dismiss the wiring as a possibility. I REALLY doubt the VR in the PCM is the problem.
Getting Savvy...
Old 03-18-2007, 11:45 PM   #15
mckaax
IS the VR in the ECM or in the PCM on a 2001
Midnight Blue 06 X, 5.5 Rusty's LONG ARM kit, JKS Quickers , AA-SYE/My shafts a Woody, 35" GoodYear Wrangler MT/R, 4.56 Gears, Rustys OTK Steering, Eagle Alloys Fake Bead lock 15x8, Lightbar W/ Lots of Lights, Rock Crawler SRC Rocker Guards, 48 in High-Lift. LOD Rear Bumper/Tire Carrier. BUILT BY ME!
Blue Jeep Club Member #227
mckaax is offline   Reply With Quote
Glock Forum
