Quantcast VIN Number Decode - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > VIN Number Decode
Poison Spyder Brawler Rockers!TJ WW2WW rockers on sale with free gaskets this month.DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-
Old 11-22-2009, 11:57 AM   #1
Canfourjeep
VIN Number Decode
I bought a Jeep TJ to fix up and run both as a daily driver and on the trails. I looked at the VIN number and it shows the 10th number is a Y. The paperwork shows a 99 and the vin number decode I find shows a 2000 model. I am trying to find wiring for the engine and am not sure what year it actually is. I bought a 99 engine and if it is actually a 2000 it wont work. Any help is appreciated.
Thanks
Canfourjeep is offline   Reply With Quote
Old 11-22-2009, 12:03 PM   #2
Hesher420
!!! SLAYER !!!
Hesher420's Avatar
Contact Jeep
A build sheet from Chrysler will tell you what year it is
FOR SALE*NIB*TJ CHOME GRILL OVERLAYCLICK HERE
**'06 Blacked Out LJ**
> > > LJ Owners Group < < <
Black Jeep Society
"We are one. One society. Digitless."
"I am not a number, I am a free man!"
Hesher420 is offline   Reply With Quote
Old 11-22-2009, 12:45 PM   #3
Tjosh97
I have a VIN decoder at my work, not as good as Chrysler's, but should tell the year Ill be here till 3pm
Beep Beep, who got da keys to the JEEP???
Red Jeep Club #556 - "DA 4-$LANGER"
1997 Flame Red TJ 4-Banger (2.5L) 4.0 TB 62mm Bored w/ Spacer -- 31x10.50 D. Cepek "Crushers" -- 15" Black Rock Crawlers -- AEM DryFlow -- Dynomax Super Turbo Cat-Back -- EBC Brake System -- Rough Country 2.5" Lift w/ Discos -- RC Adj Track Bars -- Currie HD Steering -- Rugged Ridge Diff Covers - DDM 6000K HID
Tjosh97 is offline   Reply With Quote
Old 11-22-2009, 01:09 PM   #4
06JEEP65
try this site
Decoding an NSX VIN - NSX-Wiki
it shows Y as a 2000 also
2011 JK 4 DOOR
FIREFIGHTERS JEEP CLUB GREEN JEEP CLUB CAJUN JEEPERS CO-FOUNDER
06JEEP65 is offline   Reply With Quote
Old 11-22-2009, 01:51 PM   #5
Canfourjeep
Vin number
the first numbers are 1J4FA49S7YP. I know the last numbers are serial numbers. The guy insists he bought it new early 1999.
I live in Canada and am not sure how to get a build sheet as the jeep is still in the other guys name. I can not register it until it is running.
First digit is where it is made.
Second digit is Jeep
Third is MPV
Fourth is Gross Weight
Fifth is Wrangler
Sixth is Series
Seventh is Body Type
Eighth is Engine
Ninth is Control Dight
Tenth is Year
Eleven is Plant
Twelve through 17 is Serial Number.
Old 11-22-2009, 03:21 PM   #6
pielet97
Looks like you have a 2000 by parts and 99 by paper.
This is for a GC, but Y is 2000 and X is 1999. Maybe for Y2K??
Jeep Grand Cherokee WJ - VIN decoding
I require things to do.
pielet97 is offline   Reply With Quote
Old 11-22-2009, 03:51 PM   #7
BlueFlame
The model year has little to do with the date of manufacture. 2000 models hit showrooms mid 1999. (my 03 was built in July 02)
The Title and REgistration tell you what year it is.
BlueFlame is offline   Reply With Quote
Old 11-22-2009, 04:01 PM   #8
TheHeretic
TheHeretic's Avatar
Originally Posted by Hesher420 View Post
Contact Jeep
I wish the Jeep site allowed me to get true build sheet for a Canadian registered vehicle Chrysler Canada doesn't offer this.
VA3IPB
OBAMA !
TheHeretic is offline   Reply With Quote
Old 11-22-2009, 04:04 PM   #9
pielet97
I don't think that is true in this case. His title says 99 but his VIN says Y. Y is 2000.
My 2004 suburban, has 2003 parts all over the engine. Coolant temp sensor to name one.
Old 11-22-2009, 04:15 PM   #10
Hella
my buddy also has one of these. We went to do his front brakes and figured out they are from a 2000 even though his is a 99. Different size rotors and stuff I guess.
Hella is offline   Reply With Quote
Old 11-22-2009, 04:27 PM   #11
BlueFlame
[I don't think that is true in this case. His title says 99 but his VIN says Y. Y is 2000.]
Perhaps Canada or his Province registration works that way? By date rather than model year?
[My 2004 suburban, has 2003 parts all over the engine. Coolant temp sensor to name one.]
[my buddy also has one of these. We went to do his front brakes and figured out they are from a 2000 even though his is a 99. Different size rotors and stuff I guess.]
Very common on first or last years of a model.
Old 11-22-2009, 04:49 PM   #12
pielet97
2003 and 04 were neither 1st or last years of the model.
My 95 vette had 96 parts in it, again middle of the model years.
If I were OP, I would first attempt to buy 2000 year parts b/c his VIN says it is a 2000.
Old 11-22-2009, 05:13 PM   #13
Canfourjeep
Year built.
If it is a 99 or 2000. I just need to know how to identify the wiring and see what I need. The wiring from the dash to the fuse box is all there. Someone just unplugged the wires to PCM and removed it also the wires were unplugged that go to the engine. If it is a 99 I have the correct engine. The 99 engine I have has a distributor and not a coil pac. If this is a 2000 then it had a coil pack and no distributor. Either way I do not see how the engines will interchange. I was told it was a 99 and bought a 99 TJ PCM and a 99 Cherokee engine. If it is a 2000 then these wont work as far as I can tell as the change was between 1999 and 2000 models. Really confused.
Old 11-25-2009, 02:35 PM   #14
Canfourjeep
2000 Jeep TJ.
I got the build sheet today and the TJ was built December 1999. Guess the guy did not know when he bought it. Now to try to use the 99 engine in it.
Old 11-25-2009, 02:37 PM   #15
BlueFlame
IF it was built in December 1999 then it is definitely a 2000 model. That was half way through the 2000 model year production.
Glock Forum
