VIN Locations? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > VIN Locations?
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 10-16-2008, 07:31 AM   #1
HeepToJeep
1982 CJ8
VIN Locations?
Anyone know where all the VIN locations are for the TJ Wranglers?
Wm
HeepToJeep is offline   Reply With Quote
Unread 10-16-2008, 07:32 AM   #2
patricknolan
Look above your steering wheel, on the dash. Kind of awkward spot.
patricknolan is offline   Reply With Quote
Unread 10-16-2008, 07:41 AM   #3
HeepToJeep
1982 CJ8
I've seen that one but there's generally more than one location, especially in vehicles made after 1990. For instance, my Cherokees have it on the dash, firewall, both fenders and a hidden one inside the A pillar....laser etching has become quite popular among automakers.
Wm
Unread 10-16-2008, 07:58 AM   #4
LJameson
Theres also a tag underneath the grill attached to the frame.
2000 TJ- Slowly Rebuilding
1990 YJ-2.5/AX5. Stock DD: http://www.jeepforum.com/forum/f12/2...d-fun-1465702/
LJameson is offline   Reply With Quote
Unread 10-16-2008, 09:02 AM   #5
Wif
If you mean the white bar code stickers with the VIN on it then they are attached to all 'loose' panels as the go thru the factory ,, it's part of the inventory tracking system for assembly.
Look on the tailgate, underside of each door, firewall, fenders, .. each panel will have a sticker.
The true VIN # is on the dash above the steering wheel .. viewed from teh outside.
[B]----------------------
Formally 88Jeepster
----------------------[/B]
[I]Who's[/I] in front ?
Ridin' topless again .. sweet !!
Wif is offline   Reply With Quote
Unread 10-16-2008, 09:18 AM   #6
athos76
These are the ones that I've found...
Dash
Drivers Door Jamb
Floor board behind passenger seat
all carpet pieces
Tailgate
inside of rocker panel area on drivers side
firewall
etched into frame on drivers side
passenger side rear wheel well
roll cage
2006 I6 6-Speed X, 33" Goodyear Duratrac, RC 3.25" lift, Windstar CAI, York OBA (in progress), custom corner guards (in progress)
Stupidity is NOT a crime... therefore you're free to go.
Support STU-OFFROAD NOW!!!
athos76 is offline   Reply With Quote
Unread 10-16-2008, 09:52 AM   #7
HeepToJeep
1982 CJ8
No, I mean on my Cherokees the VIN is literally laser etched into the metal of the fenders, firewall and inside the A pillar as well as the white stickers on most all of the other parts. The sticker info is good to know and I'd forgot about that but I'm mainly referring to those in the metal or on metal tags.
Wm
Unread 10-16-2008, 09:59 AM   #8
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Wm
A pillar next to drivers side windshield, it's printed on Vehicle Certifiation Label, which is on drivers side door shutface, and it is located somewhere on frame rail, I believe front of vehicle on frame. This is what it shows for an 02 TJ. Hope this helps!
GOLENJEEPTJ is offline   Reply With Quote
Unread 10-16-2008, 10:55 AM   #9
kbarwall
1980 CJ5
anyone have a site that will decode your vi for you, I used one for my cummins once a while back but forget the site...
kbarwall is offline   Reply With Quote
Unread 10-16-2008, 11:01 AM   #10
NakedJeeper
Jeep VIN Decoder:
http://jeep.avtograd.ru/VIN/vin_en.asp
www.NakedJeep.com
NakedJeeper is offline   Reply With Quote
Unread 10-18-2008, 09:51 PM   #11
HeepToJeep
1982 CJ8
I rephrased the original question so it was a little clearer. I don't currently own a TJ but I'm looking at three that have been totalled offroad.....I'd like to build one nice Jeep out of them IF and only if I can make the titling as painless as possible.
Wm
