Quantcast Viking Offroad TJ Fast Back Soft Top - Page 7 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Viking Offroad TJ Fast Back Soft Top
Old 08-05-2008, 10:42 PM   #91
02tjsport
I love these but one question.
Where does the back two straps go? Can someone provide a closeup picture? Is there a bracket that you have to bolt onto the body? Or does it snap under the rail edge as well?
'02 TJ Sport - 3.5" RE Springs/Mono-tubes; BFG A/T 33x12.50x15 on ProComp Black Steelies; JKS: BPE's, 1.25" BL, shock conversion, front Adj. TB's, quick discos, Extended Brake lines; FT 3-link rear; JCR 1-ton Steering; Warn 6" Flares; Olympic Slider Bumpers; OME SS; Taurus Electric Fan; 4.88 Gears; D30/D44 Detroit True-Trac Front/Rear;
02tjsport is offline   Reply With Quote
Old 08-05-2008, 10:47 PM   #92
Twitchy
they run through a stitched slit on either corner and the metal hooks clip into the factory rail
My store of choice....NATIONAL 4 WHEEL DRIVE; CALGARY, ALBERTA
RCD 6" Long Arm, Procomp Xterrain 35x12.5, DC-1 Black 16x10, Champion 10,000lbs winch, PIAA lighting, H4 Headlights, Magnaflow muffler, Viking Soft Top, Tuffy Consoles, Boston Acoustic audio, Hurst short throw, Trailjammer system, Air Raid CAI
my armor thread: http://www.jeepforum.com/forum/f9/360-degrees-gen-right-tj-armor-594083/
Twitchy is offline   Reply With Quote
Old 08-05-2008, 11:20 PM   #93
unsung
4
unsung's Avatar
Originally Posted by 02tjsport View Post
You need door surrounds, the bestop no drill (quick detach) header, and the lower rear bar from the back window on a stock soft top as well as the brackets that secure the bar into place.
Thank you. I have the header already from running a bikini top. Going to have to find the rest. Gotta find some half doors too.
unsung is offline   Reply With Quote
Old 08-06-2008, 06:20 AM   #94
unsung
4
unsung's Avatar
Originally Posted by zachv View Post
Are they $650 with free shipping as found here or $675 as seen on the website?
Old 08-06-2008, 10:27 AM   #95
02tjsport
you can get the rear bar from many places, as well as from zach at a to z fab
Old 08-06-2008, 10:31 AM   #96
crgrissom
Master of Reality
crgrissom's Avatar
There are lots of door surrounds on ebay right now.
Chuck
Chuck Grissom
Black Jeep Society Member
My Jeep
Opportunity is missed by most people because it is dressed in overalls and looks like work.
- Thomas A. Edison
crgrissom is offline   Reply With Quote
Old 08-06-2008, 10:55 AM   #97
graham74
Just wanted to throw out that I am another satisfied customer. Got a chance to meet Jon in person, and spoke with Thor on the phone a few times. They are both great guys to deal with. I can't begin to tell you how good the customer service is. The fit is VERY tight the first couple times. I live in Washington state and luckily Monday was around 80 degrees. Any cooler than that and it would have been a lot tougher. I had looked at Stu's write up pretty thoroughly and saw that he had it over a soundbar, but no cage padding. Just in case anyone is wondering, I have mine over the soundbar and padding and it works just fine. Had to work each zipper down a few inches at a time on the back window the first few times. After that, it zips down really easy.
graham74 is offline   Reply With Quote
Old 08-06-2008, 12:38 PM   #98
Twitchy
Do be careful with the rear straps, I tightened mine down way to far two days ago and the plastic piece that holds both ends of webbing snapped in half, I jerry rigged it for now, but I have some riveting to do in my future to make it work nicely, just a warning, the directions say to not overtighten even when new, but clearly I didn't heed the warning effectively
my armor thread: http://www.jeepforum.com/forum/showthread.php?t=594083
Old 08-08-2008, 03:36 PM   #99
hulkboy
do you guys with the vikings run them or plan to run them in the winter?? i have a hardtop im trying to sell to get a viking. i really like the style but have any of you swapped your hardtop for the viking? if so would you recommend it?
hulkboy is offline   Reply With Quote
Old 08-08-2008, 03:50 PM   #100
dabprice
I've run mine for two winters and have had absolutely no problems. It's quiet and retains heat very well.
dabprice is offline   Reply With Quote
Old 08-08-2008, 05:54 PM   #101
hulkboy
ok cool and your in new york so your winters are more harsh than what ive got down here in texas..
Old 08-11-2008, 09:19 PM   #102
raskull
I would not recommend using any soft top up here in Canada however. My brother's rear window cracked in several places last year in cold weather.
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (pic)
http://myjeeptj.com <- Write-ups on mods/maintenance/trips and a video/image gallery
Custom front bumper build
Custom rockers build
My build thread
raskull is offline   Reply With Quote
Old 08-13-2008, 01:13 AM   #103
missionAvs
missionAvs's Avatar
I don't understand how the whole taking the top down thing works with this Viking top but from what I've seen, I am very interested. I have one concern, someone mentioned earlier that when you take the top down you are essentially removing it. If so, can you leave it in the same position as you leave the stock top when its down and drive? or do you have to roll it up and place it somewhere else until you put the whole top back on which would get old real quick for me unless its drastically easier than putting the stocker back up. Can someone who has bought this top go into more detail on how the taking top down thing works with this top? Also I think pics showing the tops safari mode would be cool and also pics of it with the top down unless you have to remove the top entirely.
Thanks for the help!!
04 Willys Edition TJ Wrangler
missionAvs is offline   Reply With Quote
Old 08-13-2008, 03:01 AM   #104
02tjsport
Yea you have to remove the top entirely if you want to take it "down". The windows are stored inside the "safari" part of the top. You may be able to store it behind the rear seat area when it is off if you roll it up. There is no frame system to fold down. It simply slides in the header on the windshield, slides in the door surrounds and is pulled taught around the rollbars. The windows zip onto the safari part of the top.
Old 08-14-2008, 12:41 PM   #105
missionAvs
missionAvs's Avatar
Is the process of removing the top an putting it back on relatively easy? Or is it much harder than stock?
Glock Forum
