Quantcast Viking Offroad TJ Fast Back Soft Top - Page 10 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Viking Offroad TJ Fast Back Soft Top
Old 08-21-2008, 09:34 PM   #136
ryan188
Originally Posted by Bennettj13 View Post
Really? Anyone?
post a pic of that console you have, or better yet, a pic of your jeep with it in
ryan188 is offline   Reply With Quote
Old 08-21-2008, 10:07 PM   #137
Stu Olson
Stu Olson's Avatar
I like this top a lot. Unfortunately I don't think it's going to work with a Tuffy overhead console since it uses the footmans loop. Any ideas?
I used the bar @ the left side of the photo (part of the front sports bar). My loop was pretty much negated by the sPOD installation. Anyway, I snugged the center strap to the roll bar and called it good. Worked great.
Stu Olson
ARB Locked & Loaded
www.stu-offroad.com
Stu Olson is offline   Reply With Quote
Old 08-21-2008, 10:07 PM   #138
Jeepster197
Can an anybody with this top tell me if you lose your back seat, when you install this top? Can people still sit in the back or do they have to duck down to sit in the back?
03' Wrangler X 4.0 Blue 5 spd.
4" Fabtech Lift w/33x12.5 MTZ's on 16" DC-1 Blacks
Bestop front w/Ramsey 9500UT. w/Hella's
Rampage rear w/tire swing out.
Precision 4.56 gears, Edge Trailjammer
AA SYE w/Coast Driveline CV DS
Jeepster197 is offline   Reply With Quote
Old 08-21-2008, 10:10 PM   #139
raskull
Nope, it's fine with a back seat. Unless your passengers are taller than your roll bar. :P
(O|||||||O)
l_l*-----*l_l
Raskull - Metallic Silver '03 Jeep TJ Sport (pic)
http://myjeeptj.com <- Write-ups on mods/maintenance/trips and a video/image gallery
Custom front bumper build
Custom rockers build
My build thread
raskull is offline   Reply With Quote
Old 08-21-2008, 10:27 PM   #140
Twitchy
People actually use their backseat????
My store of choice....NATIONAL 4 WHEEL DRIVE; CALGARY, ALBERTA
RCD 6" Long Arm, Procomp Xterrain 35x12.5, DC-1 Black 16x10, Champion 10,000lbs winch, PIAA lighting, H4 Headlights, Magnaflow muffler, Viking Soft Top, Tuffy Consoles, Boston Acoustic audio, Hurst short throw, Trailjammer system, Air Raid CAI
my armor thread: http://www.jeepforum.com/forum/f9/360-degrees-gen-right-tj-armor-594083/
Twitchy is offline   Reply With Quote
Old 08-22-2008, 12:40 AM   #141
87warrior
Originally Posted by nettak View Post
Actually, I have a similar question... I want to get a Rockhard 4x4 sport cage. It has the panel between the 2 bars of the T-section. I figured this would be a nice place to put a CB....but then it would interfere with the strap to the footman loop.
I have the front section on the rockhard cage. The T-Bar causes no problems, the strap just rests agianst it. This is where I will be mounting the screen for a spotter cam under the jeep someday.
Anybody over 5'6" will feel cramped and uncomfortable in the backseat. I rarely haul folks around back there, but they always comment on the 'sloped window'.
03 Rubicon(Rubicon build)
92 Comanche (92/99 Comanche Project)
87warrior is offline   Reply With Quote
Old 08-22-2008, 07:47 AM   #142
Jeepster197
Thanks for the info, and yes i use my backseat all the time. When we going wheeling we load are jeeps up everytime, usually we'll have 3-4 jeeps going with a minimum of 9 passengers and none of us have 4 door JKs. So i did need to know about this top for passengers.
Old 08-23-2008, 12:49 PM   #143
Pionex311
Hey guys, its my first post and I thought it should be on tops. Newho, how does this top hold up in the cold? I have a hard top on my tj with a sheet of plastic for a back window cause it broke the first month I had it. I've considered getting a new window installed on it but for $550, I want to consider my options, you know. Also, would it be worth selling the hard top to get one of these if the chance comes around for it?
Pionex311 is offline   Reply With Quote
Old 08-23-2008, 03:15 PM   #144
87warrior
I would not waste the money to repair your hard top. You could pick up a used one in like new condition for $700 if you shop around Had about 6" of snow fall on my top and I did not feel that it sagged as much as the factory soft top.
The Viking will keep you just as comfortable as a hard top will durring the dead of winter. However, I love my hardtop in the winter because of the defrost/wipe/wash function on the back window.
Old 08-23-2008, 05:58 PM   #145
Pionex311
Cool beanz. The one month that I did have the back window on, the wiper didn't work and the heater element leads were broken, so I didn't mind it that much. I wonder how much I should sell it for. All I have to do is clean it and remove the plastic makeshift window and tape gunk and it'll be good to go. I just have to wait a couple of more months since I'm out on deployment.
Old 12-16-2008, 06:01 PM   #146
UTmike
I put my Viking on for the first time about a month ago and I must say that it is way too tight. Did anyone else have trouble getting it to fit, possibly b/c of the roll bar? The rear window is about an inch too high so I can't get it anywhere near to securing in the rear channels and the side windows aren't flat as there's some tension folds in them.
Also, any suggestions on how to get the windows into the bag flat without folding up the corners so when you put them in the top they don't buldge out?
4.5" RE SF Lift, 1" BL, 35" Cooper Discoverer STT, Lockrite Locker, 8.8 Rear, AA SYE, Tom Woods DS, Sliders, Skids, Bumpers, Rear Stinger, RockCrusher Diff Covers, 8000# Winch, Herc'd Tub, Homemade Deck Cover, On Board Misting System and Faucet
UTmike is offline   Reply With Quote
Old 12-18-2008, 11:08 AM   #147
02tjsport
Is it cold in MO? That may be your problemt. I didnt put my factory soft top on until Late November and It took me an hour to fidangle the top and make it stretch...
'02 TJ Sport - 3.5" RE Springs/Mono-tubes; BFG A/T 33x12.50x15 on ProComp Black Steelies; JKS: BPE's, 1.25" BL, shock conversion, front Adj. TB's, quick discos, Extended Brake lines; FT 3-link rear; JCR 1-ton Steering; Warn 6" Flares; Olympic Slider Bumpers; OME SS; Taurus Electric Fan; 4.88 Gears; D30/D44 Detroit True-Trac Front/Rear;
02tjsport is offline   Reply With Quote
Old 12-18-2008, 11:10 AM   #148
CCJ
Now if they only made a targa top version.
CCJ is offline   Reply With Quote
Old 12-18-2008, 11:45 AM   #149
zachv
Vendor
Still available at reduced prices!
Give yourself a nice top for the Holidays.
Have a great day!!!
Zach Vaughn.
AtoZ Fabrication, Inc.
570-385-3931--shop
570-385-3932--fax
MADE IN AMERICA---and proud of it!!!
Now scheduling cage/custom work so call now to get on the calendar.
CHECK OUT OUR DIY FAB PARTS FOR SALE!!
We also offer the best prices available on:
Advance Adapters
Clayton Offroad Suspension
Amsteel Winchline and accessories
Staun beadlocks and deflators
zachv is offline   Reply With Quote
Old 12-18-2008, 12:02 PM   #150
jbo667
Yeah, you just wait for a warm-ish, sunny day and stretch it out. I left mine on 2-3 days w/o being tucked in the side tailgate channels and pulled them to fit when I got a sunny 65*+ day, works perfect now.
jbo667 is offline   Reply With Quote
Glock Forum
