Vibrations in the steering - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Vibrations in the steering
The Cure for your Tie Rod Roll!FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 06-05-2015, 05:35 AM   #1
Rican142
Between 25-35/40 in getting a vibration in the steering wheel as if I'm driving over a rumble strip at slow speeds. I only really feel it in the steering wheel, and it only happens when I'm on the throttle.
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline   Reply With Quote Quick reply to this message
Unread 06-05-2015, 06:28 AM   #2
Jerry Bransford
Administrator
Jerry Bransford's Avatar
The vibration is likely from improper (excessive) angles at the u-joints on the driveshafts caused by your 4" suspension lift. Was a SYE installed? What was done to correct the steeper driveshaft angles caused by the suspension lift?
Can you post good sharp well-lit photos of the front and rear driveshafts, especially showing the axles and their connections/angular-relationships to the driveshafts?
Getting Savvy...
Coolest offroad magazine ever! CRAWL Magazine
Jerry Bransford is offline   Reply With Quote Quick reply to this message
Unread 06-05-2015, 07:16 AM   #3
esad_b
interesting.. I might have noticed the same thing in my wheel.
I think its a balance issue as those are always speed related..
Black 05 LJ
Past 97 TJ
esad_b is offline   Reply With Quote Quick reply to this message
Unread 06-05-2015, 02:03 PM   #4
Rican142
Found it! It's a blown u joint-_-
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
