vibration at speeds over 50 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > vibration at speeds over 50
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRaceline/Allied Wheels on Sale NOW !Bead Lock Wheels! Raceline, Trail Ready, & Trail-Gear
Unread 07-14-2010, 04:44 PM   #1
jerseyboxer58
i have a 2006 tj, i take great care of it but i get a slight vibration at highway speeds. i feel it in the steering wheel and pedals. but nothing shakes... im going on a long road trip soon and i would like to get it resolved soon so any advice is awesome.... thanks
jerseyboxer58 is offline   Reply With Quote
Unread 07-14-2010, 04:54 PM   #2
moore14
check u joint?
moore14 is offline   Reply With Quote
Unread 07-14-2010, 08:02 PM   #3
BlueFlame
wheel balance
BlueFlame is offline   Reply With Quote
Unread 07-14-2010, 08:30 PM   #4
jerseyboxer58
i had the wheels balanced, 5000 miles ago.... whats the u joint? also note i just had my rear seals replaced too but it was vibrating before that too soo i duno
Unread 07-14-2010, 08:52 PM   #5
BlueFlame
That in no way rules it out.
I once had mine balanced three times in a row before they got it right...
In fact, in 5000 miles they could easily now be out of balance, or have a wear pattern.
Unread 07-15-2010, 03:52 AM   #6
jerseyboxer58
yeah true ok ill have them rebalanced anyway! and rotated.. just sayiong though if it was an inbalance wouldnt the steering wheel shake? and its only 50 mph and above.
Unread 07-15-2010, 04:05 AM   #7
AlexGeorgakis
AlexGeorgakis's Avatar
Do the vibs disappear when you remove your foot from the gas pedal at the same speeds? If yes I would say it's a driveline issue. If no then it's probably a wheel balancing issue.
My HEMI build thread
AlexGeorgakis is offline   Reply With Quote
Unread 07-15-2010, 04:09 AM   #8
jerseyboxer58
if im doing like 75ish and i let off it wont go away untill under 65mph. ok ill have them balanced again rotated and how about alignment?
Unread 07-15-2010, 06:15 AM   #9
AlexGeorgakis
it could possibly be misalignment as well. i'd have the whole thing done - balancing and alignment, just to be sure.
Unread 07-15-2010, 07:47 AM   #10
jerseyboxer58
alright ill get it done this weekend and ill get back to the thread thanks..
vibration , shaking , steering wheel , pedals , high speed
