Vibration after SYE + CV. What could it be? - Page 3 - JeepForum.com
post #31 of 40 Old 11-19-2011, 08:43 PM
RubiconRazorbac
RubiconRazorbac's Avatar
Originally Posted by jutgin
Are we sure it's pinion angle causing vibration? Could be a number of other things.
It's the first thing he should make sure is perfect. Then move on down the list
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #32 of 40 Old 11-20-2011, 06:37 AM Thread Starter
TheOrffs
rubicon what else could it be. The tires are balanced, the jeeps aligned, pinion bearing are good, dont know what else.
TheOrffs is offline
post #33 of 40 Old 11-20-2011, 06:46 AM
Barcus
Are you getting vibes during accelerating/decelerating? If that's the only time you get vibes then its your pinion angles.
98 TJ Currie arms-RC 2.5 coils-RC 2.0 shocks-1.25 BL-TF rear track bar-custom bumpstops-mud-scratches-gas.
Barcus is offline
post #34 of 40 Old 11-20-2011, 08:08 AM
bikerdude
1987 YJ Wrangler
When I did mine, I put the rear on jackstands, removed the rear tires, and ran it like that at all speeds to see if there was driveline vibration without the possibility of feeling vibration from the wheels.
bikerdude is offline
post #35 of 40 Old 11-20-2011, 08:11 AM
biffgnar
biffgnar's Avatar
With the jackstands on the frame or the axle?
biffgnar is online now
post #36 of 40 Old 11-20-2011, 08:31 AM
fowfiddy
i would say it is the rear output shaft nut torque spec. in the destructions they call for i believe 150ft-lbs i found this to not be enough and tightented mine to 185 and the vibes went away. your pinion angle can be set to the eye i believe. you want your ujoint at the axle to be as straight as possible
fowfiddy is offline
post #37 of 40 Old 11-20-2011, 08:33 AM
jutgin
I just fixed my 40 mph wobble with new driver side ball joints. That may be something to check if it has not been already.
Justin
2013 Wrangler Sport
Chattanooga, TN
jutgin is offline
post #38 of 40 Old 11-20-2011, 11:32 AM Thread Starter
TheOrffs
Thanks for your help everyone it was the pinion angle. I just fixed a couple minutes ago. All i had to do was lengthen the rear upper control arms to straighten out the pinion angle. I also just fixed the lean of the jeep. The jeep was leaning to the passenger side by like an inch and i used the sway bar links to fix it.
TheOrffs is offline
post #39 of 40 Old 11-20-2011, 11:58 AM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
I'm glad you figured it out!
Necromancer_tat is offline
post #40 of 40 Old 11-21-2011, 04:25 PM
bikerdude
1987 YJ Wrangler
For future reference, I had my jackstands under the axle so that everything was sitting the way it would be while driving. I had made my own driveshaft by shortening an xj front shaft and wanted to check my work. It had no vibration so I was relieved.
OP, good to hear you got it fixed, happy wheeling!
beadlock , exhaust , lift , long arm , Tie rod end
vibration fix bcarroll_us TJ Wrangler Technical Forum 15 02-20-2010 09:07 PM
A little vibration H_Swank YJ Wrangler Technical Forum 18 01-21-2010 10:36 PM
vibration moeflow YJ Wrangler Technical Forum 3 12-05-2009 03:36 AM
new vibration db_17_85 TJ Wrangler Technical Forum 10 07-22-2005 10:15 AM
Vibration @ ~ 95-105 km/h (60-65 MPH) matthewb57 TJ Wrangler Technical Forum 4 07-06-2005 04:30 PM
