Vibration after SYE + CV. What could it be? - Page 2 - JeepForum.com
post #16 of 40 Old 11-19-2011, 03:42 PM
BLK00TJ
Like this:
Not like this. This is a stocker setup:
BLK00TJ is offline
post #17 of 40 Old 11-19-2011, 03:54 PM Thread Starter
TheOrffs
TheOrffs is offline
post #18 of 40 Old 11-19-2011, 04:00 PM Thread Starter
TheOrffs
any suggestions?
TheOrffs is offline
post #19 of 40 Old 11-19-2011, 04:04 PM
BLK00TJ
Originally Posted by TheOrffs View Post
any suggestions?
Can you get a shot that shows both of those in one picture? From pinion to TC?
BLK00TJ is offline
post #20 of 40 Old 11-19-2011, 04:05 PM Thread Starter
TheOrffs
put the picture together is quite easy to see.
TheOrffs is offline
post #21 of 40 Old 11-19-2011, 04:08 PM
MFERNICO
I bet your driveshaft measurements are off.
MFERNICO is offline
post #22 of 40 Old 11-19-2011, 04:31 PM
Barcus
Go buy a angle finder at your local hardware store. They are less than $10. Double check your angles bc even it might look "good" just eyeballing it, even being off a couple of degrees could give you the vibes.
98 TJ Currie arms-RC 2.5 coils-RC 2.0 shocks-1.25 BL-TF rear track bar-custom bumpstops-mud-scratches-gas.
Barcus is offline
post #23 of 40 Old 11-19-2011, 04:36 PM
biffgnar
biffgnar's Avatar
Or if you have an iphone or android download a bubble level app. $1 and you don't have to go to the hardware store. Although, personally I think eyeballing usually turns out just fine.
biffgnar is offline
post #24 of 40 Old 11-19-2011, 04:38 PM
Barcus
Im borderline OCD so I needed to know what my angle was.
Barcus is offline
post #25 of 40 Old 11-19-2011, 04:42 PM Thread Starter
TheOrffs
biff does the angle look fine to you from the pictures provided?
TheOrffs is offline
post #26 of 40 Old 11-19-2011, 04:46 PM
biffgnar
biffgnar's Avatar
Well, the picture is out of focus, too close and not square to the axle, but if you put a gun to my head I'd say pinion is touch low, although its close so might not be the isssue.
Have you pulled the shaft and driven in 4H just to confirm that the vibration goes away?
biffgnar is offline
post #27 of 40 Old 11-19-2011, 04:48 PM
biffgnar
biffgnar's Avatar
Did you put adjustable arms on the front and realign pinion there? Front CV shaft is materially longer so less senstive than rear, but 6" of lift is a lot. Personally I find localizing vibrations by butt feel can be a bit inaccurate.
biffgnar is offline
post #28 of 40 Old 11-19-2011, 07:03 PM
Necromancer_tat
Where'd all my money go?
Necromancer_tat's Avatar
It does look like the pinion could be adjusted up just a touch more, but it looks to be pretty close. The pinion and the drive shaft should be the same angle, but some folks like to run the pinion down by one degree so that when the drive line is loaded up the pinion will rise to be inline with the drive shaft. I don't know which way is better one way or the other though.
I agree with the post above about pulling your rear DS and seeing if that makes the vibration go away.
Necromancer_tat is offline
post #29 of 40 Old 11-19-2011, 07:46 PM
Night Wolf
That's an odd looking output yoke, looks big, bulky and long (no homo). Also looks to be a lot of drivetrain lift. Sears has the angle finder. I'm currently adjusting mine, it can be difficult to set properly by eye.
*edit
Keep in mind - the pinion isn't supposed to point to the transfer case, but instead the center ball of the DC driveshaft - that's the pivot point. If it was set by eye, that may have been what happened.
Just having a hard time getting over that output though - you buy a SYE to also shorten the output - that partly defeats the purpose.
I could be mistaken though - I ordered my SYE with a Rubicon style output flage in stead of a yoke. I thought mine stuck out a bit more than normal but nothing near that.
-Rick
-1987 BMW 528e 5spd e28 - personal Panzer for the daily driven battlefield, just broken in at 300k
-1990 BMW 325i Convertible 5spd e30 - extensive overhaul in progress
-2005 TJ Sport - stuff
Night Wolf is offline
post #30 of 40 Old 11-19-2011, 08:27 PM
jutgin
Are we sure it's pinion angle causing vibration? Could be a number of other things.
Justin
2013 Wrangler Sport
Chattanooga, TN
jutgin is offline
beadlock , exhaust , lift , long arm , Tie rod end
vibration fix bcarroll_us TJ Wrangler Technical Forum 15 02-20-2010 09:07 PM
A little vibration H_Swank YJ Wrangler Technical Forum 18 01-21-2010 10:36 PM
vibration moeflow YJ Wrangler Technical Forum 3 12-05-2009 03:36 AM
new vibration db_17_85 TJ Wrangler Technical Forum 10 07-22-2005 10:15 AM
Vibration @ ~ 95-105 km/h (60-65 MPH) matthewb57 TJ Wrangler Technical Forum 4 07-06-2005 04:30 PM
