Vibration after SYE + CV. What could it be? - JeepForum.com
post #1 of 40 Old 11-19-2011, 03:17 PM Thread Starter
TheOrffs
Hello jeepers,
This is my first ever post ever considering i just joined a mnute ago. The reason i join is because of the vibration in my 2003 wrangler X. I installed a rough country 6 inch short arm kit, later i will be purchasing the long arm upgrade. I also installed the rugged ridge slip yoke eliminator and an adams custom driveshaft for a 6 inch lift. I dont know what to do next. The jeep only vibrates between 30-40 mph while accelerating. Below or above that the jeep is smooth. I just wanted some suggestions if possible what to do. I dont know if i want to install blocks to drop the transfer case or what. Thanks TheOrffs
TheOrffs is offline
post #2 of 40 Old 11-19-2011, 03:20 PM Thread Starter
TheOrffs
sorry everyone wrong section ment to click TJ but hit JK. But if you know anything please help me out, thanks
TheOrffs is offline
post #3 of 40 Old 11-19-2011, 03:21 PM
Benderff
Benderff's Avatar
Did you set the pinion angle?
Benderff is offline
post #4 of 40 Old 11-19-2011, 03:24 PM
dkrajcovic
pinion angle?
welcome to the fourm
post a pic of your pinion angle sounds like that is what it is
dkrajcovic is offline
post #5 of 40 Old 11-19-2011, 03:25 PM Thread Starter
TheOrffs
Yes the pinion angle was set when i got the jeep aligned.
TheOrffs is offline
post #6 of 40 Old 11-19-2011, 03:27 PM
Benderff
Benderff's Avatar
The pinion angle of the rear driveshaft was set by whoever did your alignment?
Benderff is offline
post #7 of 40 Old 11-19-2011, 03:29 PM Thread Starter
TheOrffs
Yes a good friend of my dad did it when he aligned it.
TheOrffs is offline
post #8 of 40 Old 11-19-2011, 03:29 PM
dkrajcovic
can you post a pic of it (rear pinion angle )
post #9 of 40 Old 11-19-2011, 03:30 PM
dkrajcovic
also what rear end do you have???
post #10 of 40 Old 11-19-2011, 03:31 PM
Benderff
Benderff's Avatar
It sounds like it needs to be checked again. Stuoffroad.com has a great write up.
Benderff is offline
post #11 of 40 Old 11-19-2011, 03:32 PM
dkrajcovic
X2
post #12 of 40 Old 11-19-2011, 03:32 PM Thread Starter
TheOrffs
dk i only have a dana 35 at the moment, and everyone asking about the pinion angle i will go out and take a picture of it but its at a 0 degree angle.
TheOrffs is offline
post #13 of 40 Old 11-19-2011, 03:34 PM
RubiconRazorbac
RubiconRazorbac's Avatar
0 degree angle to what?
Your shaft isn't long enough to handle that kind of droop...
2003 TJ Rubicon:
2017 JKU Rubicon:
RubiconRazorbac is offline
post #14 of 40 Old 11-19-2011, 03:35 PM
JC_Sahara
The pinion needs to be pointing at the Transfer case like this...
My Build Thread:
JC_Sahara is offline
post #15 of 40 Old 11-19-2011, 03:41 PM
dkrajcovic
do not know what 0 degree angle is but take a pic so we can see
also dana 35s pinion bearings are know to go bad but if that was it then it would vib all the time
beadlock , exhaust , lift , long arm , Tie rod end
vibration fix bcarroll_us TJ Wrangler Technical Forum 15 02-20-2010 09:07 PM
A little vibration H_Swank YJ Wrangler Technical Forum 18 01-21-2010 10:36 PM
vibration moeflow YJ Wrangler Technical Forum 3 12-05-2009 03:36 AM
new vibration db_17_85 TJ Wrangler Technical Forum 10 07-22-2005 10:15 AM
Vibration @ ~ 95-105 km/h (60-65 MPH) matthewb57 TJ Wrangler Technical Forum 4 07-06-2005 04:30 PM
