Vibration at 50+ mph - JeepForum.com
post #1 of 20 Old 05-18-2013, 07:21 AM Thread Starter
Bayview471
I just installed a Zone 2" spacer lift and new sway bar links into my '03. I have a very bad vibration at 50+ mph to the point where I can no longer drive at that speed or above. I've checked all bolts and nuts with nothing found loose. I even tightened them all more to be sure. I'm thinking it might be drive shaft no longer being balanced. There are no vibrations under 50 mph. Any ideas? Thanks
Anyone who has never made a mistake has never tried anything new.
Firefighter/EMT
Bayview471 is offline
post #2 of 20 Old 05-18-2013, 07:28 AM
JEK3
JEK3's Avatar
It's your driveshaft, but it's not out of balance. You've pushed it past the amount of "bend" it can reasonably handle.
Two ways to fix it:
- Transfer case drop. Basically you put spacers between your frame and the transfer case skid to help straighten out your driveline. Cheap, but not ideal.
- Slip yoke eliminator and double cardan drive shaft. Basically gives you a drive shaft that can handle more bend. This is the right way to fix it, but parts alone are at least $500.
JEK3 is offline
post #3 of 20 Old 05-18-2013, 08:40 AM Thread Starter
Bayview471
How far of a drop would you recommend? I'm on a budget as a college student so $500 isn't happening.
Firefighter/EMT
post #4 of 20 Old 05-18-2013, 08:49 AM Thread Starter
Bayview471
I also have a welded in skid plate from before I bought it. Does this change my options?
Firefighter/EMT
post #5 of 20 Old 05-18-2013, 09:26 AM
tyvanwie
Is it a high clearance skid?
Sent from my iForum using JeepPhone
tyvanwie is offline
post #6 of 20 Old 05-18-2013, 09:44 AM Thread Starter
Bayview471
No. It's the stock. I was told the nuts inside the frame were torn to shreds while it was being worked on at a shop so they welded it back up.
Firefighter/EMT
post #7 of 20 Old 05-18-2013, 01:04 PM
rchase559
Yes that would pose a problem then. That shop did a hack fix. You would need to cut off the skid and either weld in a steel spacer or actually fix the frame and restore it to its original condition.
Why don't you pull the rear driveshaft and see what happens to your vibes. There's no point in throwing parts at it when you aren't really sure what the problem is. I wouldn't think that a 2" lift would cause all that significant of vibes (I had a 2.5" and a short rear DS with the 42RLE and was free of vibes) but I guess anything is possible.
rchase559 is offline
post #8 of 20 Old 05-18-2013, 01:49 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Hopefully the shop welded new threaded inserts in the frame, and then bolted the skid plate to the frame.
First thing to do is what rchase559 suggested, remove the rear driveshaft and take it for a drive.
Wheelin98TJ is offline
post #9 of 20 Old 05-19-2013, 09:47 AM Thread Starter
Bayview471
I'll get on that after work. I did try throwing it in 4wd this morning on my way into work and the vibes went away.
Firefighter/EMT
post #10 of 20 Old 05-22-2013, 11:47 PM Thread Starter
Bayview471
So I dropped the shaft and no more vibration. I did notice the U joint was loose and was wondering if replacing it might get rid of the vibes. Thanks.
Firefighter/EMT
post #11 of 20 Old 05-23-2013, 02:11 AM
JEK3
JEK3's Avatar
Certainly won't make them any worse.
JEK3 is offline
post #12 of 20 Old 05-23-2013, 08:38 AM
bobjp
It's the bad drive shaft u joint that is causing vibrations. 2" of lift alone will not cause vibration from a good drive shaft.
97 TJ sport.
bobjp is offline
post #13 of 20 Old 05-23-2013, 02:43 PM Thread Starter
Bayview471
Any recommendations on where to get the replacements or the brand?
Firefighter/EMT
post #14 of 20 Old 05-23-2013, 02:57 PM
rchase559
Spicer 1310
post #15 of 20 Old 05-23-2013, 05:15 PM
SilvFx
http://www.northerndrivetrain.com/ca...ints_1310.html
I like the 5-1310-1X that are greaseable through the end caps....but they are more expensive. The 5-1310-X are lower cost and non-greaseable. You might want to replace your straps while you are at it ($5.55 on the same link shown above).
You also really need the right tool to do this quickly....such as this one that I bought:
http://www.amazon.com/OTC-7248-U-Joi...t+removal+tool
Harbor freight and other tool places have some cheaper alternatives, or maybe you can rent one. This makes the job go faster and is less frustrating than trying to bang it out using sockets. Use a penetrating spray and let it soak overnight first.
SilvFx is offline
lift advice , vibration
