-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Vibration at 50+ mph (http://www.jeepforum.com/forum/f9/vibration-50-mph-1524961/)
Bayview471 05-18-2013 08:21 AM
I just installed a Zone 2" spacer lift and new sway bar links into my '03. I have a very bad vibration at 50+ mph to the point where I can no longer drive at that speed or above. I've checked all bolts and nuts with nothing found loose. I even tightened them all more to be sure. I'm thinking it might be drive shaft no longer being balanced. There are no vibrations under 50 mph. Any ideas? Thanks
JEK3 05-18-2013 08:28 AM
It's your driveshaft, but it's not out of balance. You've pushed it past the amount of "bend" it can reasonably handle.
Two ways to fix it:
- Transfer case drop. Basically you put spacers between your frame and the transfer case skid to help straighten out your driveline. Cheap, but not ideal.
- Slip yoke eliminator and double cardan drive shaft. Basically gives you a drive shaft that can handle more bend. This is the right way to fix it, but parts alone are at least $500.
Bayview471 05-18-2013 09:40 AM
How far of a drop would you recommend? I'm on a budget as a college student so $500 isn't happening.
Bayview471 05-18-2013 09:49 AM
I also have a welded in skid plate from before I bought it. Does this change my options?
tyvanwie 05-18-2013 10:26 AM
Is it a high clearance skid?
Sent from my iForum using JeepPhone
Bayview471 05-18-2013 10:44 AM
No. It's the stock. I was told the nuts inside the frame were torn to shreds while it was being worked on at a shop so they welded it back up.
rchase559 05-18-2013 02:04 PM
Yes that would pose a problem then. That shop did a hack fix. You would need to cut off the skid and either weld in a steel spacer or actually fix the frame and restore it to its original condition.
Why don't you pull the rear driveshaft and see what happens to your vibes. There's no point in throwing parts at it when you aren't really sure what the problem is. I wouldn't think that a 2" lift would cause all that significant of vibes (I had a 2.5" and a short rear DS with the 42RLE and was free of vibes) but I guess anything is possible.
Wheelin98TJ 05-18-2013 02:49 PM
Hopefully the shop welded new threaded inserts in the frame, and then bolted the skid plate to the frame.
First thing to do is what rchase559 suggested, remove the rear driveshaft and take it for a drive.
Bayview471 05-19-2013 10:47 AM
I'll get on that after work. I did try throwing it in 4wd this morning on my way into work and the vibes went away.
Bayview471 05-23-2013 12:47 AM
So I dropped the shaft and no more vibration. I did notice the U joint was loose and was wondering if replacing it might get rid of the vibes. Thanks.
JEK3 05-23-2013 03:11 AM
Certainly won't make them any worse.
bobjp 05-23-2013 09:38 AM
It's the bad drive shaft u joint that is causing vibrations. 2" of lift alone will not cause vibration from a good drive shaft.
Bayview471 05-23-2013 03:43 PM
Any recommendations on where to get the replacements or the brand?
rchase559 05-23-2013 03:57 PM
Spicer 1310
SilvFx 05-23-2013 06:15 PM
http://www.northerndrivetrain.com/ca...ints_1310.html
I like the 5-1310-1X that are greaseable through the end caps....but they are more expensive. The 5-1310-X are lower cost and non-greaseable. You might want to replace your straps while you are at it ($5.55 on the same link shown above).
You also really need the right tool to do this quickly....such as this one that I bought:
http://www.amazon.com/OTC-7248-U-Joi...t+removal+tool
Harbor freight and other tool places have some cheaper alternatives, or maybe you can rent one. This makes the job go faster and is less frustrating than trying to bang it out using sockets. Use a penetrating spray and let it soak overnight first.
The time now is 02:46 AM.
