very low idle then dies. - JeepForum.com
post #1 of 4 Old 05-20-2010, 10:59 PM Thread Starter
failure2stop
I have a 2004 wrangler unlimited (LJ) with a 4.0 and just today out of the blue.... On the first crack all the gauges on the cluster maxed out then came back with no starter... tried again and got it to crank for 5 seconds with no start. after a few cranks it started. I gassed it. rpm's rose. when i released accelerator it just dropped off again. next start it would idle at around the first dot above zero. and move slightly up and down then die after awhile or if i hit the gas and let it go it seems like the engine just lets it fall and die. beside the idle it seems to run fine i just need to keep the engine running with a little gas applied. this is the only problem i have ever had with my jeep. i did not recently get gas. The only think that worries me is the way the gauges seemed to freak out the first time then the problem started.
Thanks for the help in advance.
failure2stop is offline
post #2 of 4 Old 05-20-2010, 11:06 PM
ohtenwillys
hmm.. check the battery and make sure your wires from the alternator are secure and nothing is shorting out to the body.
Could be that you're losing power from your alternator somewhere.
Check your battery is 12v. If you have a voltmeter you can check that your alt. is up to spec.
ohtenwillys is offline
post #3 of 4 Old 05-21-2010, 06:59 AM
robncar
robncar's Avatar
Does it throw any codes? Once you check the battery and connections as recommended above, you may want to clean the throttle body and IAC (I-dle A-ir C-ontroller). The IAC is responsible for maintaining idle.
http://www.jeepforum.com/forum/f9/diy-alignment-kit-steps-w-pics-2264465/
robncar is offline
post #4 of 4 Old 05-21-2010, 09:22 AM
calabrate2
I would have to second the alternator. My old car, a Nissan maximal same systoms and it was the alternator
calabrate2 is offline
200 RPM idle and dies, 4.0L chainsaw620 TJ Wrangler Technical Forum 17 11-11-2009 07:07 PM
carb on 4.2 dies at idle 90yjdude YJ Wrangler Technical Forum 13 09-28-2009 01:18 PM
Help! 4.0 dies when in idle 4LiterFury2010 TJ Wrangler Technical Forum 2 08-17-2009 03:15 PM
88 almost dies when idle pgatherum YJ Wrangler Technical Forum 15 08-04-2008 06:12 PM
need help jeep won't idle just dies damian H YJ Wrangler Technical Forum 5 06-17-2007 07:06 PM
