Very confused! banck two sensor two oxygen sensor - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Very confused! banck two sensor two oxygen sensor
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 03-03-2010, 07:10 PM   #1
imnotaniceboy
The computer says i need to replace my Bank two sensor two! is not to be found here in DR!
Online store are not very clear about it. I get often confused! Can some please give me a "ready to buy link" for this item?
thanks in advance!
imnotaniceboy is offline   Reply With Quote
Unread 03-03-2010, 08:58 PM   #2
brunosplace
Here are the factory part #'s for all of your oxygen sensors, I am not sure yet which one is the one you need. Since it says sensor 2, I am guessing it will be one of the after catalyst sensors.
#56028 994AA SENSOR, Oxygen, Before catalyst rear
#56028 995AA SENSOR, Oxygen, Before catalyst front
#56028 996AA SENSOR, Oxygen, After catalyst front
#5139 021AA SENSOR PACKAGE, Oxygen, After catalyst rear
Originally Posted by Boodyrider View Post
Big tires, done right, are FREAKING EXPENSIVE. Deal with it, or don't go there.
Originally Posted by woodnjeep View Post
I live in the land where they salt cure roadkill.
97 Jeep TJ Sport, 4.0L, Auto, 3" BDS Lift (SOLD)
98 Jeep ZJ Laredo 4.0L, Auto, Stock Totaled, parted out and scrapped
96 Jeep XJ Sport, parted out and scrapped
Tummy Tuck without a body lift. Finished!!
Superior Axle & Gear TJ/XJ Dana 44 Discovery Shafts (DC45 kit) for sale
brunosplace is offline   Reply With Quote
Unread 03-03-2010, 09:30 PM   #3
TJ311
Before you run out and buy a new O2 sensor, it may actually be the bank 2 catalytic converter that is bad, NOT the O2 sensor. What is the exact code you are getting?
If it is the catalytic converter that's bad, then you'll need this part.
TJ311 is offline   Reply With Quote
Unread 03-03-2010, 10:21 PM   #4
brunosplace
More info: http://www.jeepforum.com/forum/f9/ox...mation-701776/
http://www.rockauto.com/catalog/catalog.php enter your vehicle info then do a part # search for bosch #15513
Unread 03-12-2010, 12:03 AM   #5
imnotaniceboy
I know for sure is the sensor.
so i guess this is what i need right?
Original Replacement Parts 56041212 - Oxygen Sensor for 97-00 Jeep® Wrangler TJ with 4.0L - Quadratec
Unread 03-12-2010, 04:22 AM   #6
wquin
1956 CJ3B
Or given that the downstream o2 sensor doesn't do anything other than tell you your cat/exhaust is bad, both of which you could probably figure out, and slim out your wallet, you could just stick an O2 simulator on it and call it a day...
Googling O2 simulators will find you what you need. I built mine for about 10$ in parts and wired it up under the passenger seat. Been running for 4 years now...
wquin is offline   Reply With Quote
