vent controls - JeepForum.com
post #1 of 5 Old 05-12-2009, 09:32 AM Thread Starter
nate00
vent controls
does anybody know why when i switch from vent to the floor to the a/c vents it takes a while then switches. by a while i mean like a minute or more.
nate00 is offline
post #2 of 5 Old 05-12-2009, 09:34 AM
NotURMailman
You could possibly have a small vacuum leak somewhere. Then again, vacuum motors were never designed for reaction speed...
equipped... And loving it!
I drive on the right side, what's wrong with you?
It's difficult to take you seriously. It's like you're an easily perturbed autistic teenager who's drunk typing the whole time.
NotURMailman is offline
post #3 of 5 Old 05-12-2009, 09:38 AM Thread Starter
nate00
even if its off, when i turn it directly to the a/c vents it starts at the defrost, then moves to the floor then to the a/c vents
nate00 is offline
post #4 of 5 Old 05-12-2009, 09:46 AM
NotURMailman
Vacuum motor control systems are slow to react sometimes. A lack of proper vacuum supply (due to a leak) could make it worse. There is also the possibility that the peice on the back of your knob is cracked (blue plastic that slips over the posts). Check the back of your knobs and check for vacuum leaks. I justed noticed you said over a minute, so something isn't right. Those are the two things I would check first. One common place for a vacuum leak is the rubber elbow on the end of the plastic line at the lower portion of the intake manifold near the rear. That boot can get oil on it and swell, creating a loose fit.
post #5 of 5 Old 05-12-2009, 10:13 AM Thread Starter
nate00
alright thanks for the help
nate00 is offline
question about AC controls Peltboy25 YJ Wrangler Technical Forum 6 08-12-2009 12:31 PM
AC/Heat vs. Vent (( vent dosen't work idk why )) gamer0 YJ Wrangler Technical Forum 10 04-10-2009 11:24 AM
99+ A/C Controls in a 98TJ? izanuff TJ Wrangler Technical Forum 7 02-12-2008 12:58 AM
air controls tcox TJ Wrangler Technical Forum 3 01-03-2007 08:10 PM
Vent Controls 7sdad YJ Wrangler Technical Forum 12 05-02-2004 01:03 PM
