Vapor recovery line??? - JeepForum.com
post #1 of 9 Old 07-07-2010, 10:12 AM Thread Starter
skinton
I found a steel line that runs along the frame on the drivers side in the back wheel area. It was rusted completely apart. It appears to go to the fuel tank. I think it is for the vapor recovery system.
First, is my assumption correct?
Second, where do I get a replacement? (buy line & bend myself?)
Third, What does this affect?
Thanks.
(I can post pictures if it helps)
1998 TJ Sport, 4.0L - 5 spd -Suffering from frame rot
2006 Grand Cherokee Overland (5.7L HEMI)
HEMI Club Member #53
2003 M-B C240 4matic
skinton is offline
post #2 of 9 Old 07-07-2010, 10:47 AM
Sundowner
Pictures, please.
Sundowner is offline
post #3 of 9 Old 07-07-2010, 10:53 AM Thread Starter
skinton
Hi Sundowner,
I'll get some pictures after work.
PS- Still no problems with my idle. (you tried to help me with grounding issue on TPS codes not too long ago)
Shane
skinton is offline
post #4 of 9 Old 07-07-2010, 11:06 AM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Yes, your assumption is correct. It is a vent line for the fuel tank.
You can get a new line from the dealer. The part # for the long line is 52127601 and it lists for $33.70.
It appears to be nothing more than a 3/16" hard line, but I have never confirmed this, so I cannot say for sure.
The purpose of this is to reduce the emission of fuel vapor in to the atmosphere. Usually you will get a check engine light for an evap leak if this hose is not properly connected.
Wheelin98TJ is offline
post #5 of 9 Old 07-07-2010, 11:15 AM
Sundowner
Or, someone that knows more than me can just save us all the trouble.
P.S. Glad to hear that you got your idle problem fixed!
post #6 of 9 Old 07-07-2010, 08:01 PM Thread Starter
skinton
Took some pics, but can't upload because file is too big and the computer I am at doesn't have anything to resize pics. However, looking at the inside of the frame rail, there are three hard lines: bottom one is steel brake line, middle is pressurized fuel line (i think stainless), and top line is the one in question. It is steel and is routed over the top of the top spring perch on the left rear tire and goes to the fuel tank.
skinton is offline
post #7 of 9 Old 07-08-2010, 10:48 AM Thread Starter
skinton
It looks like I have my answer, but here are the pictures for future reference.
skinton is offline
post #8 of 9 Old 07-08-2010, 07:11 PM Thread Starter
skinton
...and 4wd.com has it for $32.99.
skinton is offline
post #9 of 9 Old 09-01-2016, 11:03 AM
skippydo-99
Vapor Line Part Number
I'm having the same problem and need to replace it. Thanks for your information.
skippydo-99 is offline
fuel , vapor , line , TJ
EGR Line/ Vapor Line Question KRenegade YJ Wrangler Technical Forum 6 01-08-2010 01:51 PM
Rubicon 4 door lost the vapor recovery canister rufrdr JK Wrangler Technical Forum 32 07-26-2008 06:59 PM
Vapor recovery nozzles and my TJ Whybu1 TJ Wrangler Technical Forum 7 07-02-2008 03:46 PM
Replacement for OEM vapor line connectors? Moxie TJ Wrangler Technical Forum 2 12-12-2007 08:47 PM
fuel tank vapor line help? nutterbetter YJ Wrangler Technical Forum 3 12-04-2005 12:20 AM
