#1 | |
Vanco Hydroboost...
Just checked out their site today and noticed the hydroboost brake setup and I was wondering if anyone was running it. sounds like a great idea, so i just want to know what ya'll's opinions were on this subject....
2001 TJ Sport w/ D44, 2.5" Susp. lift,1" BL w/ MML, 35x12.50 BFG KM2's on 15x8 Soft 8's, Smittybilt XRC Front Bumper and Rocker Guards, S/B SRC Rear Bumper, Xenon 4" Flat Flares, JKS Disconnects, 48" Hi-Lift Jack, OBA System, Optima Blue Top, Hella Lighting. More on the way... ;} JEEP= Just+Empty+Every+Pocket..... EAT-SLEEP-JEEP OlllllllO TJ-XTREME |
#2 |
I run the Vanco big brake kit. It's a tremendous improvement over stock. I think I'd start there before changing out the hydraulics. The TJ system has plenty of pressure, just a lousy caliper and pad design when you add large tires and massive amounts of extra weight to the vehicle.
DON'T FEAR THE RE-GEAR!!!
______ |_____| (O|||||||O) |______| []===o==[] RED JEEP CLUB MEMBER #430 |
#3 | |
I have heard that the hydroboost kit can basically give the pedal an on and off feeling with little in between.
00 TJ with a few mods. Hopefully more someday... |
#4 |
It's not a Jeep but I have a homebuilt Hydroboost setup on my Chevelle and that thing will stop on a dime!
I pieced it together with parts from a chevy astro van and I definately think it is well worth it. Getting the prop valve/residuals right was kinda tricky. And NikVallens was right, it is pretty much on/off you need to be very careful about how much pedal you put down or else you might just find out what your steering wheel tastes like. |
#5 |
Do it right or not at all
![]() Join Date: Jan 2003
As Robncar says, the TJ's OE brake line pressure is already more than the OE front disk brakes can handle. You're far better off with VANCO's Big Brake kit that takes advantage of that available pressure without bending/flexing as the OE brakes do which will dramatically improve a TJ's stopping ability that gets reduced with big tires.
Gone to King of the Hammers, back Sunday! Jerry's Geezer Jeep II Website Getting Savvy... Coolest offroad magazine ever! CRAWL Magazine When you have a choice, buy American.
#6 |
Brake Wizard
Yes, the HB can develop that on and off feeling, but that's easily remedied by dropping the bore size on the master down to the correct size.
I am Savvy I am handling the sales of Black Magic Brakes on www.blackmagicbrakes.com |
#7 |
I have hydroboost on my TJ, this is what it did to my stock brakes:
![]() First the knuckle slider bent upwards, then the pads folded over. I did this a couple times before Vanco came out with the BBK. I got one of the first sets made, and haven't had a problem since. Like the others have said, get the BBK. It is cheaper, much easier to install and it will resolve your braking deficiencies. |
#8 |
thanks for all the quick replies guys, very much appreciated. I was planning on the big brake conversion already and was just wondering about the performance once supplemented by the hydroboost but it sounds like I won't need it. thanks again...
#9 |
Brake Wizard
The BBK is outstanding and only gets more outstanding with the addition of the HB.
#10 | |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
