-   TJ Wrangler Technical Forum (http://www.jeepforum.com/forum/f9/)
-   -   Vanco Big Brake - Knuckle question (http://www.jeepforum.com/forum/f9/vanco-big-brake-knuckle-question-641778/)
tkki1230 12-01-2008 09:59 PM
I have a kit on order, and I had a question. How does the Vanco knuckle compare to the stock piece? Is the steering part of the knuckle the same as the stock one? I know the knuckle is modified to accept a different caliper, but I'm thinking that the arm that attaches to the rod ends are the same? I just wanted to know if I had to adjust for alignment after the install.
FireMedicZ 12-01-2008 10:16 PM
I didn't have to realign after installing mine, but then there may be subtle differences in each knuckle. They looked like the same, where the tie rod attaches, to me.
Tip: follow the break in instructions....and when it says the brakes will improve over time....it does.
newbs 12-01-2008 11:03 PM
they are nothing more than a stock knuckle modified for the new brakes, everything other than brakes is stock
Joe Dillard 12-01-2008 11:10 PM
The knuckles I have on mine (YJ) were machined for the calipers like you mentioned, but as far as the steering goes, they send knuckle units out for stock steering links which allows you to alter them as necessary.
Mine is the Big Brake kit which typically gets installed/used on 16" wheels (12" rotors & dual 48MM calipers), but they fit fine for my application.
My brakes are now nothing shy of incredible. :)
http://www.fototime.com/3D3B3556C961916/standard.jpg
http://www.fototime.com/36D327531841F60/standard.jpg
http://www.fototime.com/2734265CF2EE16E/standard.jpg
http://www.fototime.com/E4D1B2197375FE3/standard.jpg
newbs 12-02-2008 12:12 AM
don't worry I bought one of the very early only 20 made ones and liked it enough that I bought 2 more.
The time now is 04:48 PM.
