Vanco Big Brake kit. Which is updated information. - JeepForum.com
post #1 of 4 Old 12-01-2015, 12:20 PM Thread Starter
fugitive
I am considering the 15 inch Vanco Big Brake Kit. I see different one setup from blackmajicbrakes.com
http://www.blackmagicbrakes.com/uplo...structions.pdf
verses from 4lowparts.com
http://www.jeepforum.com/forum/f9/bl...combo-2491153/
The info on blackmajicbrakes.com appears to have a bracket bolted to the knuckle and indicates that the unit bearing must be ground. The knuckle on the 4low parts looks different and says nothing about grinding down the unit bearing. My application is on a 2000 tj. My question is which instruction setup is the current version of the Vanco Big Brake kit for the TJ? Thanks.
fugitive is offline
post #2 of 4 Old 12-01-2015, 12:29 PM
biffgnar
biffgnar's Avatar
The bracket was the old way the kit worked. They now have redesigned knuckles specifically for the kit.
I think grinding the unit bearing is still necessary. It is a question of the unit bearing and the rotor meshing properly and those are off the shelf parts that haven't changed.
biffgnar is offline
post #3 of 4 Old 12-01-2015, 02:08 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
It depends on the kit. The Super 16, Currie F-450, and Reid kits still have brackets that bolt to the knuckles.
The 15", 16" and 17" that are RCV compatible don't need additional brackets because they have been built with a knuckle that has the bosses located for the caliper saddles.
The 15 and 16 still need the flange on the unitbearing reduced in diameter slightly so the rotor can fit over them, but they are the only ones.
I am Savvy
mrblaine is offline
post #4 of 4 Old 12-02-2015, 06:44 AM Thread Starter
fugitive
Got it. Thanks bud.
fugitive is offline
