Vanco Big Brake Kit & Hi-Steer - JeepForum.com
post #1 of 3 Old 08-11-2009, 08:01 PM Thread Starter
05jeeper
1988 XJ Cherokee
Has anyone installed the Vanco Big Brake Kit and Genright Hi-Steer? What was involved? Did you have to use genrights twisted pitman arm and/or drag link for hi-steer?
2005 JEEP RUBICON
GROUP MEMBERSHIPS:
05jeeper is offline
post #2 of 3 Old 08-12-2009, 01:46 AM
mudb8
want it rite or rite now?
mudb8's Avatar
it'll work, if you're using high steer knuckles, they will need to be sent to van to be machined. and be sure to tell em you're gonna drill out the knuckles for highsteer, he may have cores that are already drilled out.
the twisted arm depends on you suspension set up.
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
ASE Certified Master Tech/Fabricator @ jeepwest.com
mudb8 is offline
post #3 of 3 Old 08-12-2009, 09:46 PM Thread Starter
05jeeper
1988 XJ Cherokee
Thanks for the reply, I will contact Van directly before I purchase anything.
Currently I have "cage" 4" SA lift. I plan on getting the clayton LA upgrade kit. I'm still debating if I am going with coilovers or keeping the existing springs and upgrading to 5100 series Bilstein shocks.
2005 JEEP RUBICON
GROUP MEMBERSHIPS:
05jeeper is offline
Group Buy - Vanco Brake Kit leukus Wrangler General Discussion 42 05-26-2009 12:19 PM
Any issues getting Vanco brake kit?... Ohiodish Wrangler General Discussion 6 03-30-2009 01:54 PM
Vanco brake question 80 CHOPPER TJ Wrangler Technical Forum 1 02-25-2008 09:31 AM
Thanks VANCO Big Brake Kit!!! Jerry Bransford TJ Wrangler Technical Forum 173 08-30-2007 06:04 PM
Vanco Big Brake Kit and ORO U-Turn? robncar TJ Wrangler Technical Forum 4 05-23-2007 07:58 AM
