Vacuum diagram - JeepForum.com
post #1 of 5 Old 04-07-2010, 07:37 AM Thread Starter
jvandy98
Vacuum diagram
I recently did a swap from a 2.5l to a 4.0l into my Wrangler. I am in desperate need of a vacuum line diagram as I have one line open on my intake and I do not think I have my leak detection pump hooked up correctly because i am generating a P1495 code. Does anyone have any information that they could pass on to me?
Thanks
Josh
jvandy98 is offline
post #2 of 5 Old 04-07-2010, 09:45 AM
amiller
I'm reasonably certain that the 4.0 intake manifold had some changes over the years. What year engine did you swap in?
amiller is offline
post #3 of 5 Old 04-07-2010, 10:33 AM Thread Starter
jvandy98
I swapped a 4.0l from an 03 WJ. All in all it was a pretty serious swap moving the engine and transmission, ECM, and just about everything else from the WJ to the TJ. I now have the engine running really well but missing a vacuum line and it is making it miss just a little bit.
thanks
Josh
jvandy98 is offline
post #4 of 5 Old 08-30-2011, 01:18 PM
wrangler1997tj
97 Wrangler TJ 2.5 Liter Vacuum Diagram
I have a 1997 Jeep Wrangler TJ 2.5 Liter and was wondering if anyone had the vacuum diagram for this model.
Thank you
wrangler1997tj is offline
post #5 of 5 Old 08-30-2011, 02:45 PM
JWebber
Here the typ. layout. But if you what spacific vac to other areas Which ones?
JWebber is offline
94 yj vacuum diagram WranglerWheeler YJ Wrangler Technical Forum 0 01-23-2009 03:09 PM
4wd vacuum diagram??? Bluevee33 YJ Wrangler Technical Forum 4 04-24-2008 09:53 PM
vacuum diagram? OlllOTJ TJ Wrangler Technical Forum 0 11-06-2005 10:35 AM
Vacuum diagram soxfann YJ Wrangler Technical Forum 8 11-11-2004 02:08 PM
vacuum diagram Durbahn YJ Wrangler Technical Forum 9 06-04-2003 09:56 PM
