Quantcast V8 Swap Or Stroke The 4.0 I6??? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > V8 Swap Or Stroke The 4.0 I6???
Old 10-26-2008, 09:24 AM   #1
GEM1N1
I am getting my ducks in a row before I take on another project wrangler. I am looking for feedback and opinions on stroking a TJ's 4.0 to about a 4.7??? Obviously we all know what a v8 swap will produce but I don't have any experience with the 4.0 stroker (horsepower, cost, reliability, drivability, etc...) I am liking the idea of having a clean and easy swap (if there is such a thing ) with the I6 and I have been reading some impressive #'s as far as horsepower. Bring on the comments especially $$$ if you have done one of these.
GEM1N1 is offline   Reply With Quote
Old 10-26-2008, 09:47 AM   #2
jamaicanmecrazy
1994 ZJ
http://www.jeep4.0performance.4mg.com/
http://www.angelfire.com/my/fan/stroker.html
http://www.jpmagazine.com/techarticles/engine/154_0508_golen_4_6l_stroker_engine/index.html
http://www.rockcrawler.com/techreports/stroker40/page2.asp
http://www.ajeepthing.com/stroker-motor.html
http://www.bc4x4.com/tech/bryce/stroker/assembly.cfm
Need more? LOL
jamaicanmecrazy is offline   Reply With Quote
Old 10-26-2008, 03:45 PM   #3
GEM1N1
Thanks. Has does anyone on here have a stroker in their TJ???
Old 10-26-2008, 04:04 PM   #4
PBR
I have one. If you have the money to do a v8 do v8!!!
PBR is offline   Reply With Quote
Old 10-26-2008, 05:11 PM   #5
rubidriver
rubidriver's Avatar
If the stroker is done correctly, you will like it better than a SBC or the dodge v8s. The v8s are very costly if you do them right, thats why my vote is for the stroker.
2005 Black Rubicon - OME 933/942 - OME N66/N67 - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16 MTZ
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline   Reply With Quote
Old 10-26-2008, 05:25 PM   #6
spyder6
Just violated my Parole
spyder6's Avatar
if you would have built yours, you would have had a different opinion. and you're missing the proper .1 liter :P
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Old 10-26-2008, 05:48 PM   #7
PBR
building and buying doesnt matter. It all the same components pretty much:
4.2L crank and rods
.30 over pistions
High output head
I think all the power comes from what kind of cam you wanna run. I have a mild cam right now but i may change it to a more aggresive cam.
Old 10-26-2008, 06:00 PM   #8
spyder6
spyder6's Avatar
i want to get a cam that just lopes around like a big block V8. something crazy.
USAF
Blue Crush Build
Really?
Old 10-26-2008, 07:04 PM   #9
jamaicanmecrazy
1994 ZJ
Even built to the max 5.0 you are still at base of a SBC.
My vote for the stroker is weight and being inexpensive for parts and easy to maintain over the long run.
I had a 2.8L Ford that was stroked and it was a fun car.
Old 10-26-2008, 08:01 PM   #10
99blackFRC
I did a late model GM 5.3L swap in my 01 TJ last year and love it. I also did stage 2 heads and a more aggressive cam while it was still on the pallet, so that helped a lot too. Used AA parts to make the swap easier..
99blackFRC is offline   Reply With Quote
Old 10-27-2008, 12:45 AM   #11
jamaicanmecrazy
1994 ZJ
Sounds nice but since finding this i'd want the Hemi
http://jalopnik.com/photogallery/aevwrangler2/1004166859
Old 10-27-2008, 12:52 AM   #12
rubidriver
rubidriver's Avatar
Built right, the stroked 4.0 will produce massive amounts of torque at low RPMs that most mildly built SBCs cant achieve. Thats the beauty of an inline motor. The long stoke is something that every Jeeper should think about when deciding on v8 or stroker.
Old 10-27-2008, 06:12 AM   #13
vapoppa
strokers are better than stock but still no match for V8's -a v8 will cost more but there are more options with the v8. mase
vapoppa is offline   Reply With Quote
Old 10-27-2008, 06:32 AM   #14
stogie25
stogie25's Avatar
I have a stroker. I have 40000 miles on it. I have had no problems. It was easy to put in. The extra hp is exactly what the Jeep needed to wake it up, especially after adding 1000 pounds over the years.
The V8 would have more power, but would be a pain to get in right. Sometimes too much more power opens the door to more breakage. It really depends on what you want out of your Jeep.
Jarhead Jeep Club
O|||||||O
97 Black TJ (one owner), BFG KM2 35s, 4.7L Stroker, ARB's, Dana60 rear, Dana30HP Front Warn manual hub conversion, 6 inch mostly Tera long arm lift. Rhino lined tub. Allied Rock 8 beadlocks. Tera-Low 4:1. Sanden OBA. Sniperfab tube fenders.
My Build Thread http://www.jeepforum.com/forum/f22/my-jeep-history-1997-present-1304114/#post12717920
stogie25 is offline   Reply With Quote
Old 10-27-2008, 07:12 AM   #15
dcorn
I've wheeled with Tom a few times and his Jeep is a beast. You just can't beat that V8 sound coming out of a lifted Wrangler. The swap is perfectly done and draws all kinds of attention.
FOR SALE 1998 Cherokee Classic - White
5" lift - 35" tires - locked/geared/shafted/armored
2012 Subaru WRX Limited
dcorn is offline   Reply With Quote
Glock Forum
