V8 replacing 2.4 - JeepForum.com
post #1 of 8 Old 07-29-2011, 09:30 AM Thread Starter
acharrier
V8 replacing 2.4
I am at the "thinking about it stage" of changing engines next summer. I will have 4 weeks next July to do this project.
My hope is to replace the 2.4 that's in my 2003 TJ with a small V8 of some ilk. I'd like to not have to replace the NV1500 transmission because the engine swap itself seems like a manageable amount of work, but when you start talking about moving around tranny, tcase, drive shaft length, etc. it all seems overwhelming. I am open to any reasonable engine selection.
Not planning on doing anything crazy like towing, plowing, climbing rock formations. Mostly want an engine that can deal with trips through the Rockies with ease.
So, suggestions?
Thanks in advance.
acharrier is offline
post #2 of 8 Old 07-29-2011, 09:47 AM
SinearOnyx
i dont think your transmission will hold up to a v8
SinearOnyx is offline
post #3 of 8 Old 07-29-2011, 09:51 AM
Eric1080
1978 J-Series Truck
ive never had a 4 cylinder but it made a huge difference to all of my jeeps when i took out tons of unneeded tools, etc. all the skid plates and protection adds weight that will slow down even my heathly v8 going over these passes
Eric1080 is offline
post #4 of 8 Old 07-29-2011, 09:52 AM
KingtheZJ
ive seen quite a few v8 swaps. in order of popularity i would say it is something like this.
Dodge 5.7 Hemi
GM 5300
Dodge 360
Dodge 318
i would second that the trans will not hold up to a v8.
you may want to look around pirate4x4. there are tons of v8 swaps there
'88 XJ
'98 ZJ on 37s and tons
'02 Chevy 2500HD 8.1
KingtheZJ is offline
post #5 of 8 Old 07-29-2011, 09:52 AM
Eric1080
1978 J-Series Truck
i personally would go with a 4.3 v6 from a blazer/ jimmy if i were thinkin engine swap
Eric1080 is offline
post #6 of 8 Old 07-29-2011, 10:05 AM
chris142
I don't think that 4 weeks is enough time to do a swap like this.
chris142 is offline
post #7 of 8 Old 07-29-2011, 10:10 AM
Duramaxxed
That would put you right where the Stock Jeep 4.0L Engine is. Which people say STILL isn't enough.
06 KJ CRD
07 Silverado Duramax
Duramaxxed is offline
post #8 of 8 Old 07-29-2011, 10:31 AM Thread Starter
acharrier
OK, this helps. Knowing the NV1500 has to go makes all of this much easier to plan. Thanks.
2.4 , swapping , v8
Replacing a 98 l6 with a 94 is it possible lyricalflo TJ Wrangler Technical Forum 3 09-29-2009 09:10 AM
Replacing my 258. What's best? Nicks90YJ YJ Wrangler Technical Forum 9 03-17-2008 09:52 AM
Replacing tie rod Zice TJ Wrangler Technical Forum 23 01-26-2007 04:13 AM
Replacing an ECU... Where is it? j_nition YJ Wrangler Technical Forum 3 01-16-2007 12:13 AM
replacing pcm greensahara TJ Wrangler Technical Forum 1 08-13-2006 09:59 PM
