Quantcast V-8 unlimited build - Page 4 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > V-8 unlimited build
Rock Krawler Suspension's for BLOW OUT prices!!!Great deals on Mickey Thompson Tires @ Jeephut.comRCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.com
Old 05-27-2008, 10:53 PM   #46
Grewe02
Cant edit my user title
Grewe02's Avatar
1980 CJ5
When you did the intake did you keep the MAF sensor? Or did you delete it from the computer? I'm not sure if I should delete mine or not
Andy, KD8EIA
| USN Jeep Hull # 66 | ΜOΛΩΝ ΛΑΒΕ |
| My Jeep's Thread | My Photobucket | San Diego Jeepers!! | VBARC | Military Jeepers |
"Don't take life too seriously, You'll never make it out alive."
"A government big enough to give you everything you want
is a government big enough to take from you everything you have"
- Gerald R. Ford in an address to a joint session of Congress on August 12, 1974
Grewe02 is offline   Reply With Quote
Old 05-27-2008, 10:53 PM   #47
Grewe02
Grewe02's Avatar
1980 CJ5
Originally Posted by REDTJ35 View Post
5.3L chevy
LQ4.
Andy, KD8EIA
Old 05-28-2008, 12:35 AM   #48
neverbackdown
i kept the MAF sensor in, i dont really feel like messing with the computer
plus doesn't that help regulate fuel and air ratio ? i say keep it
neverbackdown is offline   Reply With Quote
Old 05-28-2008, 01:11 AM   #49
bman9089
You get what you pay for
bman9089's Avatar
to a great project.
Looks like a smooth build up. So many pictures, but the problems seem to be few to none.
"The American Republic will endure, until politicians realize they can bribe the people with their own money." -- Alexis de Tocqueville
“Sometimes I wonder whether the world is being run by smart people who are putting us on or by imbeciles who really mean it” -- Mark Twain
† Christian Jeep Club †
Romans 12:5 | 1 Peter 3:15 | Matthew 9:37-38
bman9089 is offline   Reply With Quote
Old 05-28-2008, 06:13 AM   #50
V-8unlimited
Originally Posted by bman9089 View Post
to a great project.
Boy don't I wish there were no problems! Seems I'm running into small problems everyday. LOL.. The latest was my brake pedal switch, the harness requires a hot wire to feed the torque converter, then when you push the pedal, it kills the power to unlock it. I went to carquest, and talked to them regarding a normally "open" or "closed" switch. I ordered one, took it home and mounted it: No dice, so I called and they ordered just the opposite, picked it up and no dice again. So they tried another, and low and behold it didn't work either. I finally went to a big truck parts store, explained what I needed, and $25 later was on the road. I'll see if I can get some pictures of that.
I kept my MAF sensor yes, now I need to call Howell and get a pigtail to reach my filter, I actually started with a K&N for a chevy truck, but only used a very small amount of the parts.
V-8unlimited is offline   Reply With Quote
Old 05-28-2008, 08:21 AM   #51
Curlee
US Army 19D
Curlee's Avatar
As we discussed in my build thread, if you could possibly post some more pics of your intake that would be awesome. It looks like you might have a bit more room that I do though. Im going to have to go down there and do an exact measurement so I can see exactly how much room I have to play with.
My LS2 Wrangler build http://www.jeepforum.com/forum/f9/ls2-my-97-wrangler-pics-540376/
Wheelers for the wounded Great cause, check it out
http://profile.myspace.com/index.cfm?fuseaction=user.viewprofile&friendid=320 753688
A democracy is nothing more than mob rule, where fifty-one percent of the people may take away the rights of the other forty-nine.
- Thomas Jefferson
Curlee is offline   Reply With Quote
Old 05-28-2008, 01:34 PM   #52
V-8unlimited
Here is a couple pics of the intake, the hard plastic tube coming from the throttle body is the K&N tube. I had to shorten it, and it add the rubber straight piece and also rubber 90* to connect to the airfilter mount. It is a nice piece that has a place for the maf to mount, along with a filter mount. It was worth spending the money on it even though I had to butcher it. Also, here is a picture of my GM ECU mount. I used the factory box (new only $25 I think) and made 2 mounts, one is a "pedistal" besically a piece of solid stock I drilled and tapped on both ends, to mount it to the tray, then mount the ECU holder on the top. The 2nd mount you can't really see, but I happen to find a nice bracket that mounted to the inner fender and had a flat top that just so happend to work fine.
Old 05-28-2008, 01:48 PM   #53
crusty1007
Your getting close!
Looks awesome!
Thean
crusty1007 is offline   Reply With Quote
Old 05-28-2008, 01:54 PM   #54
V-8unlimited
Well, my rearend delima is cured for the time being, I just found a set of dana 44 with arb front, detroit rear, good axles, basically built for a good price. I'm going to pick these up and run them this summer, and once fall comes around I'll go back to work and pick up a set of dynatrac pro-rocks.
Old 05-28-2008, 03:48 PM   #55
bman9089
bman9089's Avatar
I'm sure you'll have no problems at all reselling those 44s.
Old 05-28-2008, 06:49 PM   #56
Grewe02
Grewe02's Avatar
1980 CJ5
Dang! You've got a crapload more room inbetween your intake and fan than I do... Do you have any shots of the firewall? Mine is tucked up pretty damn close to it.
Andy, KD8EIA
Old 05-29-2008, 06:22 PM   #57
V-8unlimited
It Runs!!!
Old 05-29-2008, 06:38 PM   #58
brass
Originally Posted by 1997jeeptj View Post
It Runs!!!
Too cool! Anyway you can shoot a little video including the bad*ss sound I am sure it has and post it on youtube or something? That would be cool.
brass is offline   Reply With Quote
Old 05-29-2008, 07:21 PM   #59
V-8unlimited
Not sure how to do that, I'll see if if my 10 year old can handle it.
I heard a loud exhaust leak, and forgot about the large holes in the camaro manifolds, so I found some 1/2" scrap and got to work. No leaks now!
Old 05-29-2008, 11:32 PM   #60
Curlee
US Army 19D
Curlee's Avatar
Yea, you have a TON of room compared to both of us. Your intake looks nice, but isnt going to help us any. Thanks for taking time and posting the pics though.
My LS2 Wrangler build http://www.jeepforum.com/forum/showthread.php?t=540376
- Thomas Jefferson
Glock Forum
