Quantcast V-8 unlimited build - Page 11 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > V-8 unlimited build
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 06-20-2009, 07:02 PM   #151
V-8unlimited
We do not have smog checks in Ohio, although I don't think it would be a problem passing a smog test.
V-8unlimited is offline   Reply With Quote
Old 06-21-2009, 03:32 PM   #152
waynehartwig
www.jeeperman.com
waynehartwig's Avatar
Originally Posted by V-8unlimited View Post
Yes, after modding, my "D" is the overdrive on my tranny. It will shift into all 4 gears but, it the shifter is on "1" it is probably in 2nd in the tranny.
Here is a very NICE example of the V-8 power, 18' V-nose full of motorcycles, driven around a 45 miles one way, cruising at 65mph no problem.
Yup! Jeep should have had the v8 as an option. It makes it such a nicer vehicle. I use mine, with 39" tires, to pull a tent trailer. Like you, no issues from WA to Moab and back. 75 mph and 12 mpg. The steepest mountain passes that used to bring it to it's knees in third gear, now it barely shifts out of overdrive. On most, the torque converter doesn't even unlock.
If I ever sell this or buy another one, the first thing I will do to it is do a V8 swap and 1 ton upgrade. Out of everything I've done to mine, those are the best two mods I've done. 1 ton's got me the killer brakes and the V8 swap gave me the power to move it!
'04 Rubicon with all the goodies....
www.Jeeperman.com
www.DiffsOnly.com
waynehartwig is offline   Reply With Quote
Old 06-21-2009, 05:59 PM   #153
V-8unlimited
1 tons! That is on my wish list for sure. I have built 44's now, but need better brakes. I am thinking of the vanco upgrade, but honestly tired of dumping money into these axles.
Here is a picture of my shifter. I used the end from the jeep tranny that the cable "plugs" onto, and welded it to the GM factory arm. Length is 1 3/4". I kept the factory bracket that actually holds the cable, and fabbed my own brackets to bolt it onto the bellhousing.
Also, I have had a few pms regarding the fuel line adapters from Jegs, here is a picture of that part. It basically just plugs into the factory line, and converts it to an AN fitting.
Another mod I just installed is a Full Traction rear swaybar, and changed out the swaybar ends to a JK setup which used heim joints instead of the factory rubber bushings. As you can see, with using this as my everyday driver, alittle road stability is worth it.
Old 06-21-2009, 06:00 PM   #154
V-8unlimited
Also, here is my fuel pump and filters (pre and post pump) mounting location.
Old 06-21-2009, 06:05 PM   #155
V-8unlimited
I bought an 07 4-door wrecked a couple of months ago, it is about finished now, and after getting it inspected, I think it will get a hemi, at least a 5.7. I have a local guy who deals in mostly Dodge parts, and can get a low mileage late model 5.7 for cheap. Not sure how much difference between the 6.1 and 5.7, but I've been looking at some superchargers to make up the difference. Also a set of Solid (now spyntech or something) will be going under it.
Old 06-21-2009, 06:11 PM   #156
rubidriver
rubidriver's Avatar
How many Jeeps do you have?
2005 Black Rubicon - OME 933/942 - OME N66/N67 - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16 MTZ
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline   Reply With Quote
Old 06-21-2009, 06:40 PM   #157
V-8unlimited
5 right now.
I have a 98 that I use strickly for offroad, getting ready to sell it to finish my 1 ton 97 I'm building. I also buy and sell/trade stuff, and jeeps seem to do well. I have a 5 year old that wants this gold jeep for his 16th birthday, so it will probably get parked when I finish the 4 door. One reason for the 1 ton rearends on the JK is gears and brakes. As you can see with this jeep, I pull a trailer, and don't want another truck, so why not have a 3/4 ton jeep. I actually just went on a small trip, and had the 98 on a trailer behind this 05. Lots of funny looks with a jeep pulling another jeep (or this enclosed trailer for that matter) and it gets even better when you pass someone on a hill with trailer in tow.
Old 06-21-2009, 10:03 PM   #158
waynehartwig
www.jeeperman.com
That's great!
Thanks for the measurements!!
www.Jeeperman.com
www.DiffsOnly.com
Old 07-16-2009, 09:25 PM   #159
lilmuddyjeep
1987 XJ Cherokee
looks great. I like the build. Im wanting to completely rebuild my XJ sometime
lilmuddyjeep is offline   Reply With Quote
Old 08-12-2009, 10:58 PM   #160
BigJoshStud
What a great build! What axles did you swap in and what was the donor vehicle for the engine?
I'm no pig... but I'm definately an ANIMAL!!!
BigJoshStud is offline   Reply With Quote
Old 08-13-2009, 07:25 AM   #161
V-8unlimited
I used the factory rear dana 44, upgraded it to 456 gears, arb locker, 35 spline axles, and a rubicon dana 44 frontend built the same way. Motor is from a chevy suburban.
Old 08-13-2009, 09:54 AM   #162
Yelladog1
Yelladog1's Avatar
I want to see a video !
CHRISTIAN JEEP CLUB
BLACK JEEP SOCIETY
PARROTHEAD JEEP CLUB # 1
Yelladog1 is offline   Reply With Quote
Old 08-14-2009, 09:20 AM   #163
V-8unlimited
I'll have to get with my 12 year old to see if that can happen, I'm lucky to post pictures without his help.
Old 08-18-2009, 08:00 PM   #164
V-8unlimited
Actually, I think this jeep may be for sale! I've found another TJ locally for cheap, and an almost new 6.2 6spd auto combo from a Caddy that would be awesome in a jeep. Either that, or I may rob this jeep of it's motor/tranny for the other one and sell it, then put the bigger motor in this jeep. Man, if money wasn't an issue, what fun we could have.
Old 08-23-2009, 08:04 AM   #165
lumpster
lumpster's Avatar
1Man, if money wasn't an issue, what fun we could have.
Join the rest of us, it sucks.
Originally Posted by SuperWade2 View Post
Blaine asked me before we left camp if I'd ever been wheeling before, I said "sure, of course I have"... about 50 feet onto the trail, he said "Wade, you f'in lied to me, you've never been WHEELING before"... I think he was right! :rofl:
Want to STOP?
JEEP Co-op parts, jk, tj, lj, yj, cj delrin door bushings, TRE inserts, poolball shifters, tierod flip kits
My Goodyear tire experience
lumpster is offline   Reply With Quote
Glock Forum
