#1 | |||
Senior Member | V-8 unlimited build
| #2 | |
Senior Member | My first step was to remove the body, and look at the damage. Frame was bent, so ordered a brand new frame from the local Dodge dealer. Then, promptly stripped all of the brackets and welded up some holes, then added a fresh coat of paint. I chose to use Rustoleum paint, nothing special, but looks nice, and seems to work fine on other vehicles I've used it on. |
| #3 | |
Member Join Date: Jul 2004 Location: Pinellas Park, FL Posts: 425 | That looks like a cool project, good luck with it. |
| #4 | |
Senior Member | After trial fitting the engine, decided I like the position and nailed everything down. |
| #5 | |
Senior Member | fresh coat of paint, and fit the RE skid plate: |
| #6 | |
Senior Member | Now, it's time to mount up the rear suspension. It does make it nice to be working with new parts on this. |
| #7 | |
Registered User Join Date: Aug 2005 Location: Amarillo, Texas Posts: 132 | Nice, very nice. __________________ Too bad stupidity isn't painful. |
| #8 | |
Senior Member | Fitting the engine into the freshly painted chassis. |
| #9 | |
Senior Member | Got some more finished, although forgot to snap any pics of this process. Basically installed the front suspension, and gas tank with skid plate(although this would later have to be dropped) |
| #10 | |
Registered User Join Date: Jan 2003 Location: Shelby, NC Posts: 349 | Looks like a lot of fun! __________________ 2005 TJ 2.5" OME HD,1.25" BL,1.25" Spacer lift,PSC Rocker Knockers,Jeeperman Rear Bumper,35x12.5-16 MTZ |
| #11 | |
Senior Member | Got the atlas in, and installed (Thanks Thein @ Advance Adapters), as you can see I'm not the only one excited! |
| #12 | |
Senior Member | I had to clearance the tranny pan to clear the skid plate. Made my tranny/transfer mount, figured out how to use the stock shifter cable, and buttoned it all up: |
| #13 | |
Senior Member | Got the tub sit back on, and used a 1" body lift, still ran into a small clearance issue on the firewall. A small dent in the firewall fixed it, and behind the valve cover, can hardly been seen: |
| #14 | |
Senior Member | Got the AEV hood and grill painted, and after posting on this site, decided to upgrade the headlights. It now looks like a jeep again: |
| #15 | |
Senior Member | I had just started on the bumper in the previous picture, but had to mount it to get it on the trailer for exhaust. Here is the finished bumper. I had planned to paint the winch body the same color as the jeep body, but ran out of time (hopefully will get to that later). I need to add a stinger or brush bar to the bumper also. |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| 30 day Unlimited Rubicon build... | BRICKTOP2 | JK Technical Forum | 258 | 12-26-2009 12:13 AM |
| SRTpusher's 2007 Unlimited Sahara Build-up | srtpusher | JK Technical Forum | 38 | 11-30-2008 06:52 PM |
| Buy a Unlimited Rubicon? Build a Unlimited X Monster? | Piet | JK Technical Forum | 21 | 05-09-2008 04:18 PM |
| Need Help with a JK Unlimited Build | BRICKTOP2 | JK Technical Forum | 47 | 04-07-2008 09:22 AM |
| '05 Unlimited Rubicon Build up... For those of you that are interested | jasonh | TJ Technical Forum | 27 | 02-22-2005 09:14 PM |
Previous Thread
Next Thread
