Is using the stock front bumper on a 2006 tj with a winch a good idea? - JeepForum.com
post #1 of 7 Old 07-05-2010, 09:36 AM Thread Starter
Tryer
I have a 2006 tj Rubicon. I, kind of, like the looks of the stock square bumper, with the soft ends. Can I put a winch plate on this that will work and looks good?
Thoughts please.
Tryer is offline
post #2 of 7 Old 07-05-2010, 09:39 AM
0blcktj6
No never it will blow up and kill everything!!
In all seriousness yes you can run a winch plate on your stock bumper and there are many that work. Frankly the bumper doesn't even matter it's the frame that the winch plate and winch mount to.
3" Currie progressives, OME Shocks, 1" BL, 1" MML, 35x12.50" KM2's, 4.88's, Detroit in rear, Vanco BBK, Currie CA's
My Build Thread:
0blcktj6 is offline
post #3 of 7 Old 07-05-2010, 09:41 AM
JeepFund
1982 CJ7
If you add a winch plate that ties into the frame, I don't see a problem. The bumper isn't as strong as some aftermarket bumpers and won't offer as much protection, but as far as the winch goes, should be okay.
-JeepFund
ΞlllllllΞ
JeepFund is offline
post #4 of 7 Old 07-05-2010, 09:44 AM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
Buy a winch plate and mount it.
GOLENJEEPTJ is offline
post #5 of 7 Old 07-05-2010, 09:48 AM
cvd
cvd's Avatar
The winch bolts to the winch plate, which bolts to the frame. The stock bumper has no impact on the strength of the winch attachment. Whether or not it looks good is up to you. Many after market bumpers have an integrated winch plate, which can look cleaner.
FWIF – I’ve stuck with the stock front bumper (and cheap winch plate) because most after market bumpers 1) add significant weight, and 2) protrude about 2” further than stock (reducing your approach angle). The Savvy bumper is the only one I know of that doesn’t have those two problems.
cvd is offline
post #6 of 7 Old 07-05-2010, 10:23 AM Thread Starter
Tryer
Excellent info, Thanks
Does anyone want to recommend a low profile winch, for this application?
I will be doing light rock crawling, in the Arizona desert, for this season.
Tryer is offline
post #7 of 7 Old 07-05-2010, 01:33 PM
Caribic-TJ
I have the Warn M8000 on my '06 Rubicon with stock bumper.
Martin
Caribic-TJ is offline
stock bumper , winch
Winch ideas needed for a stock JK front bumper Curiosity JK Wrangler Technical Forum 29 03-07-2016 11:13 AM
stock front bumper with winch? chadc84 TJ Wrangler Technical Forum 10 02-02-2010 07:03 PM
Winch Solenoid Mount-Good Idea or No? BoatCop TJ Wrangler Technical Forum 5 11-09-2008 05:52 PM
Stock front bumper+winch ? sourskittle TJ Wrangler Technical Forum 21 02-17-2008 09:14 PM
TJ Front revr mount for winch ... good idea or not? 97TomsJeep TJ Wrangler Technical Forum 19 11-01-2005 09:48 PM
