Using OEM steering stabilizer with Currie CurrectLync - JeepForum.com
 1Likes
post #1 of 25 Old 06-17-2017, 09:06 AM Thread Starter
toximus
Any tips on using the stock stabilizer with the Currectlync? Do you just press the tapered bolt out of the end of the stabilizer and use Currie's bracket instead?
toximus is offline
post #2 of 25 Old 06-17-2017, 09:28 AM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Cant do that, the stud is a permanent part of the OE steering stabilizer.
jjvw likes this.
Jerry Bransford is offline
post #3 of 25 Old 06-17-2017, 10:03 AM
jjvw
jjvw's Avatar
Just buy a cheap Monroe stabilizer. For fun, drive a bit without one just to see what difference there is.
2003 Rubicon
jjvw is offline
post #4 of 25 Old 06-17-2017, 07:07 PM
Gary2
I have not used one for years . Last Currie steering lasted over 15 years .
Gary2 is offline
post #5 of 25 Old 06-17-2017, 08:47 PM Thread Starter
toximus
I took her for a spin without the stabilizer and I can't notice any difference at all. I had forgotten all about it until I was half way home and only then realized that it was no different. Gravel roads, back roads, and highways.
Are there any concerns running without? Increased wear on the steering gear? If so, any difference or experiences between a cheapy like the Monroe or expensive like the Fox?
toximus is offline
post #6 of 25 Old 06-17-2017, 10:36 PM
biffgnar
biffgnar's Avatar
Steering dampers do exactly that. They decrease shock and stress to rest of the front end. I would not run without one, but in almost every case it would be a Monroe parts store part.
biffgnar is offline
post #7 of 25 Old 06-17-2017, 11:50 PM Thread Starter
toximus
I figured as much.
I ordered a Monroe with a boot (hoping it'll protect slightly against the sand on the roads around here which tends to sand blast things.)!
Thanks for the help guys!
toximus is offline
post #8 of 25 Old 06-18-2017, 05:49 AM
jjvw
jjvw's Avatar
I ran without a stabilizer for a short while when I switched to Currie steering. I didn't need it, but I did like the steering and handling better once the stabilizer was installed.
2003 Rubicon
jjvw is offline
post #9 of 25 Old 06-18-2017, 07:18 AM
rapracing
So in the Monroe like, what part number should I look for. '01 TJ
rapracing is offline
post #10 of 25 Old 06-18-2017, 07:19 AM
jjvw
jjvw's Avatar
I am running this one.
Monroe SC2928 Magnum Steering Damper https://www.amazon.com/dp/B000C53XRK..._CsxfF8sCTCdjY
2003 Rubicon
jjvw is offline
post #11 of 25 Old 06-18-2017, 08:31 AM Thread Starter
toximus
That's the one I purchased too.
toximus is offline
post #12 of 25 Old 06-18-2017, 09:15 AM
Jerry Bransford
Administrator
I figured as much.
Boots that cover the shock strut just keep crap/sand/dirt/salt trapped inside against it and make it hard to wash them off.
post #13 of 25 Old 06-18-2017, 09:40 AM
biffgnar
biffgnar's Avatar
While I've never seen damage from road salt sand blasting that he mentioned, I've definitely seen it from desert sand. If I was doing a lot of higher speed stuff in sand I'd run boots or more likely the removeable covers.
biffgnar is offline
post #14 of 25 Old 06-18-2017, 09:43 AM
Jerry Bransford
Administrator
Yep, not thinking of desert racing.
post #15 of 25 Old 06-20-2017, 09:37 AM Thread Starter
toximus
Nearly all of the roads here are covered with varying amounts of sand and gravel year round. For how cheap it is I suppose I could run without a boot and just see what happens. Being front and center it probably won't get the beating that shocks seem to get.
Are there any tricks to the cotter pin in the recess? I opened the pin up and just stuck half of it through. It seems that with the proper torque and how often I inspect things it really shouldn't lead to catastrophic issues. The nuts would have to back off a bit to reach the cotter pins anyway. Maybe if I removed the drag link from the pitman arm I could get it through?
toximus is offline
