using a c clamp for a u joint press? - JeepForum.com
post #1 of 17 Old 12-27-2009, 06:43 PM Thread Starter
xamdarb
2015 JK Wrangler
Has anyone ever used a regular c clamp from a hardware store for a u joint press? They seem to be basically the same except for the c clamp at the hardware store does not have the option to put a wrench on it instead it has a built in lever.
Anyone ever done this?
xamdarb is offline
post #2 of 17 Old 12-27-2009, 06:46 PM
Jeffro06
Jeffro06's Avatar
Yep. I've also beat the old one out using a socket, while resting the DS on a brick.....very hi-tech stuff.
Jeffro06 is offline
post #3 of 17 Old 12-27-2009, 06:48 PM
wushaw
Rockin jeep
wushaw's Avatar
Yea it's the same thing all right (in principle) except the ball joint/ u-joint press is a whole lot stouter.
wushaw is offline
post #4 of 17 Old 12-27-2009, 07:33 PM
Morpheus
I second the "beating the socket" post! Just make sure the socket isnt too small or you'll damage the u-joint
Morpheus is offline
post #5 of 17 Old 12-27-2009, 07:48 PM
prd_cdn
prd_cdn's Avatar
I thought the same thing until I actually had to use one. With the handle, I could not get enough force to turn the handle. The flat edges of the clamp kept sliding off as the edges of the U Joint mount and are not completely flat. Mine were seized in and I needed to Zip Cut them out. I ended using a 4inch clamp, anything bigger didn't fit underneath. I used a 3/4 inch socket and a 1 1/8, just remember to take the length of each socket, plus the U joint and that is the minimum opening of the mouth needs to be.
Just some problems I had, hopefully you dont experience the same problems I did.
prd_cdn is offline
post #6 of 17 Old 12-28-2009, 06:22 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
u-joint presses have a nut on the top...so you can get lots of torque by using a breaker bar, wrench, whatever. c-clamps have a little t-handle. u-joint presses also have fine thread shafts, c-clamps have a coarse thread shaft. also meaning you won't get as much torque or fine control of movement.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #7 of 17 Old 12-28-2009, 10:19 AM Thread Starter
xamdarb
2015 JK Wrangler
alright then sounds like im going to attempt it was a c clamp at first, if it fails il use the proper tool.
xamdarb is offline
post #8 of 17 Old 12-28-2009, 11:25 AM
nwbronco
2014 JK Wrangler
u-joint replacement methods/tools
Good thread. You can use the C-Clamp, specific u-joint tool, hammer and socket, or bench vise and 2 sockets. It's always a good idea to try the method to match the tools in your jeep. It'll be a great lesson to learn for when this happens on the trail....been there...done that...
Bob K.
nwbronco is offline
post #9 of 17 Old 12-28-2009, 11:38 AM
MFortie
MFortie's Avatar
I used to use a c-clamp/socket-hammer setup before I bought a press...
MFortie is offline
post #10 of 17 Old 12-28-2009, 11:53 AM
wlmonk
I've been using a c-clamp for years. No problem. Ever.
wlmonk is offline
post #11 of 17 Old 12-28-2009, 12:01 PM
Brown Dog
Vendor
Brown Dog's Avatar
It's the way I do it every time.
Brown Dog Offroad
Motor Mounts, Motor Mount Lifts (MML), and Engine Brackets for Jeep
100% HANDCRAFTED IN AMERICA
91YJ 2.5
Brown Dog Mounts and Engine Brackets (Serial Number 1)
2" BL
4.5" Superlift SL
AA SYE
35" GoodYear Mud Terrains
Conteract Balancing Beads
Bulldog front bumper
Best Top seats
"Family" roll bar
25 foot 1/2" log chain
No Top, No Doors (Best Top Safari)
Brown Dog is offline
post #12 of 17 Old 12-28-2009, 12:09 PM
J03_TJ
Not sure if a c-clamp would do this. happened trying to remove my new axle joints to put the full circle clip on them. Kind of ruined my Friday night.
J03_TJ is offline
post #13 of 17 Old 12-28-2009, 12:47 PM
Jeffro06
Jeffro06's Avatar
I used the hammer / socket / brick method again today...quick and easy. Like said above, this is probably how I'll do it on the trail, if need be.
Jeffro06 is offline
post #14 of 17 Old 12-28-2009, 01:13 PM
spoofmastafly
If you have any type of rust on ur u-joints I doubt you'll be able to get enough torque on them using a c-clamp. I live in Hawaii.. so there is alot of rust here. But I had to use an impact and the u-joint press to get mine out. Every u-joint cap broke in the process also. U-joint press's just make every thing move a little smoother.. Install went flawless.. you can get a harbor freight one for like 50 bucks.
spoofmastafly is offline
post #15 of 17 Old 12-28-2009, 01:19 PM
IslandTJ
HF press is usually $30.
Now Jeeping in Oregon
IslandTJ is offline
front drivestaft u-joint install problem, cant press all the way in marylandjeeper TJ Wrangler Technical Forum 5 05-29-2009 11:46 AM
HFT U-Joint Press versus BFH edzakory TJ Wrangler Technical Forum 7 12-14-2006 08:29 PM
Recomendations for a ball joint press? 95wrangler2.5l YJ Wrangler Technical Forum 15 12-07-2006 10:57 AM
u-joint press Sandbagger66 YJ Wrangler Technical Forum 21 12-01-2005 08:34 PM
Using large C clamp for U-joint replacement?? mr_man YJ Wrangler Technical Forum 22 02-19-2005 11:48 PM
