Using brake fluid to stop an oil leak? - JeepForum.com
post #1 of 25 Old 10-15-2008, 03:11 PM Thread Starter
TheMightyGoat
I've been putting off changing my rear main seal as it looks like it's gonna be a pain, and then I heard that pouring a few ounces of brake fluid into your oil will swell the seals and stop them from leaking without hurting anything in the engine. Does that work? Is it safe?
Also, I'm due for an oil change. If I try this, should I put the brake fluid in the oil oil, drive around a bit, and change it? Or should I change it and put it in the new oil?
TheMightyGoat is offline
post #2 of 25 Old 10-15-2008, 03:46 PM
RavenCorax
1988 XJ Cherokee
my bro has b een telling me this rumor for years. i still havent made up my mind on it yet.
2 door cherokee
I wave
RavenCorax is offline
post #3 of 25 Old 10-15-2008, 05:03 PM
Timmah707
Timmah707's Avatar
replace your rear main seal. You never want to band-aid a real problem, or any problem for that matter...It's fun in owning a JEEP! Get-Ta-Wrechin'!
5.5" RE Long Arm, RE Monotubes, Gen. 2 Discos, 15x10 black steel, 35" BFG Muds, SYE, 30 spline chromoly rear shafts, 27 spline chromoly front shafts, Lock-Right Auto front, Ox Locker rear, 4.88s, LoD Xpedition Series Rear Bumper Tire Carrier
Blue Jeep Club Member #268
J ust
E mpty
E very
P ocket
Timmah707 is offline
post #4 of 25 Old 10-15-2008, 05:26 PM
gaucho919
X2 on Timmah707
"The journey is the destination"
gaucho919 is offline
post #5 of 25 Old 10-15-2008, 05:33 PM
DixiesCJ3B
Yea it sounds like that might only be a temp fix, and possibly create bigger problems
X3 on what Timmah said
1999 TJ Wrangler, 4 banger 5-spd
Soft-top, full doors
31" BFG AT, 3" Lift
1954 CJ3B Willys
Hurricane 4, 3-spd with Warn Overdrive, Snow-plow
NGJC# 15
Low Output 4 cylinder Jeep Club Member #166
Originally Posted by MysticGringo View Post
This "Jeep thing" is like dating a really really hot chick, who is crazy! Its alot of fun, you spend too much money, your up all night ending up sweaty & greasy from it, your friends are jealous, you get admission into some sort of weird club... but it gets mad at your for no reason, throws fits seemingly randomly, has unexplained issues which it somehow solves on its own only after you try a bunch of different things (and spend a bunch of money) to solve it... and yet you can't resist getting in it every chance you can.
DixiesCJ3B is offline
post #6 of 25 Old 10-15-2008, 05:35 PM
kenbuck
kenbuck's Avatar
Um, I probably wouldnt be putting brake fluid in my engine oil. Fix the seal, its really not hard.
02 TJ.
2.5" RC Progressive Lift
1" PA Body Lift
33" KM's
misc other stuff.....
kenbuck is offline
post #7 of 25 Old 10-15-2008, 05:42 PM
Squeeky
Replacing the rear main in these 4 liters is simple. Cost if you do it yourself is roughly 50 bucks and it takes between 3 and 6 hours depending. All it really entails is dropping the oil pan and undoing the rear bearing cap to get at teh two peace seal.
Here's a walk-through for ya...
http://www.jeephobby.com/repairs/rea...armainseal.php
I plan on doing mine my next available weekend
Originally Posted by Unscathed View Post
Yea.. I mean really... who herculines their jeep naked.. go figure..
Squeeky is offline
post #8 of 25 Old 10-15-2008, 07:45 PM
tcox
would this be a good thing to do while replacing a clutch? i will be doing a clutch replacement soon and it seams like it would be a bit more simple with the transmission out of the way.
stuff
tcox is offline
post #9 of 25 Old 10-15-2008, 07:55 PM
Squeeky
Replacing the main seal doesn't involve removing the transmission...
Squeeky is offline
post #10 of 25 Old 10-15-2008, 08:14 PM
2jhanna
I have a very minor real seal drip (117,000 miles). I am currently using Valvoline Max-Life 10/30 oil. Max-life is supposed to have approved additives to help with seals. Put it in at about 116,000 miles. It may be just my imagnation but I think it is helping.
jhanna
denton county, tx
2jhanna is offline
post #11 of 25 Old 10-15-2008, 08:24 PM
Squeeky
It may be that its helping, but if you just replace the seal you could run normal oil lol... jerry runs normal 10-30w dino oil in his if im not mistaken and his jeep has well over 100k miles.
Squeeky is offline
post #12 of 25 Old 10-15-2008, 10:08 PM
tcox
i know it does not involve removing the transmission. the question was "would it be a good time to do while i have the transmission out of the way"
stuff
tcox is offline
post #13 of 25 Old 10-15-2008, 11:10 PM Thread Starter
TheMightyGoat
I started on the rear main tonight and had to give up on it after a couple hours 'cause I couldn't get those four bolts out of the exhaust. Whoever came up with the idea of putting that flange on the joint flush with the bolthead so it's impossible to get an open-end wrench on there, when there's already too little room to fit a socket wrench on it, is a complete and utter *******.
Class in the morning. I'll be back at it tomorrow. With a torch on standby.
post #14 of 25 Old 10-15-2008, 11:59 PM
Squeeky
Oh...the way you wrote made it sound like you were asking if a clutch replacement would be good to do since you'll have the tranny out of the way...my bad
Squeeky is offline
post #15 of 25 Old 10-16-2008, 12:01 AM
Squeeky
Hit them with pb blaster and let them soak for a day or so then try again...It may also be easier to use a socket with a long extension to get at those bolts
Squeeky is offline
Q's About Using Brake Fluid to Stop Power Steering Leaks 01TJfuntime TJ Wrangler Technical Forum 10 10-12-2009 09:14 PM
lucas stop-leak steering fluid Muddeprived TJ Wrangler Technical Forum 22 06-13-2009 05:27 PM
How do I stop this brake line leak? rymanrph YJ Wrangler Technical Forum 4 05-05-2007 08:28 AM
brake fluid leak? benvh TJ Wrangler Technical Forum 14 07-10-2006 04:06 PM
