Used Hi-lift For 40$ -- Should I Buy? (not A Listing)
#1 | |
Ive got this guy whose gunna sell me a used hilift for 40$ bucks. Its a 48"er. Theres minor rust on it, nothing too bad. I was gunna wire it down and then hit it with some flat black when I got it home. Do you think this is a good find, or jut buy new for 70?
[CENTER][B][COLOR="Navy"]2.25" BB w/ RE shox K&N air intake & Borla Cat Back 15x8 American Eagle Alloy & 32x11.5 Pro Comp MT Custom Sound System & 5% Window Tints [/COLOR][/B][/CENTER] |
#2 |
As long as its in good shape...why not? You can get a new one at tractor supply stores for $50-60. As long as it works with no problems....I say go for it
When they say "Don't be That Guy" They're probably talkin about me. |
#3 |
If its a red one with a black handle then get it, if it is the black one witht the red handle then you may not wnat to. The black ones arent made quite as well, and in my experience it is the black ones that stop working with mud and water in them sooner than the red ones(Looong story). Either way Hi-lifts are great adn useful, if you do get it you will never have to worry about crawling around on the ground to change a flat tire. Instead you will look like a pro at the side of the road and your girlfriend will be inpressed with you cause you changed a tire in all of 8 minutes without even getting dirty. Not to mention it has been my primary extraction device for years, I still have the same one I did when I was 16 and it has saved me dozens of times. In the end it is up to you, its a great jack and you shouldn't live without one.
'77 CJ-5---'63 Scout 80 FOR SALE---'71 Scout 800B---'78 F-250 Camper Special---'75 Econoline 100 |
#4 |
i got mine for 20 in new condition only used once to leval a deck
[COLOR="Red"]______ l ,[____], l---L –0lllllll0- ()_) ()_)--o-)_) [/COLOR] [url]http://www.myjeepspace.com/profile.php?id=653[/url] |
#5 | |
Is it steel or cast? You want the cast (red) jack. TCS has them for $55.00 new. If it's cast tell him you have 35 to give him and see what he says. If it's stell let him keep it. A used highlift works better than a new one. They do need to break in sort of. Bob
2006 Solar Yellow Rubicon Unlimited Jeep Club Member #1340 6 Speed, Hardtop Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
