URGENT need help advise balljoint - JeepForum.com
post #1 of 6 Old 06-08-2012, 08:37 PM Thread Starter
silver97tj
silver97tj's Avatar
Hi all
I normally wouldnt post such a title. I am having a hard time getting out top dvrs side ball joint. I have the ball joint press and the addintional case with all adapters. I am cranking on it so tight that the c clamp is bending? I backed off try different adpaters but the ball joint wont BUDGE. I am afraid I will break something or have something fly out a speed, already had one pop and I fell backwards...................Any how my Q? is how much heat can I apply or shouldnt apply to the top part that the ball joint is in.??? Will the heat weaken that part the ball joint sits in??This is beyond any thing I have ever seen, it is VERY stubborn. ...................Please any advise appreciated.
1998 Blue TJ, 4 Cyl., Auto (30rh), Hardtop with installed Sunroof, mostly stock.
31x10.5x15 Mud Tires, TJ Rubicon springs, Mopar Deep Trans Pan and Cooler
Army Vet and proud of it! Have you served your country?
Support our Troops!! Thank You!!!
silver97tj is offline
post #2 of 6 Old 06-08-2012, 09:03 PM
kloppk
Crank it down tight.
Then hit the side of the "C" next to the ball joint with a BIG hammer.
The u-joint ought to then pop loose.
Baystate Jeepers
Deep Woods Extreme
New England 4 Wheelers
kloppk is offline
post #3 of 6 Old 06-08-2012, 09:09 PM
Knuckelhead
AFSOC Retired
Knuckelhead's Avatar
Yep.
I use a 3 lb hammer and hit it hard...
Knuckelhead is offline
post #4 of 6 Old 06-08-2012, 09:24 PM Thread Starter
silver97tj
silver97tj's Avatar
Hi all I tried that but the c clamp is bending or deflecting. I am afraid something will snap and come out at speed...................
I will attempt it first thing in the morning
I think heat will work but I am not sure how much heat and how to apply it?
post #5 of 6 Old 06-08-2012, 09:29 PM
sethhawk1
I'm thinking you didn't hit it hard enough. I have a small handled mini sledge I use for those stubborn suspension parts. I wouldn't apply any heat to anything on my suspension. Accident waiting to happen when you hit that next gnarly pothole.
sethhawk1 is offline
post #6 of 6 Old 06-08-2012, 10:38 PM
mrblaine
Wizard of Brakes
mrblaine's Avatar
Load the clamp pretty tightly, put on some safety glasses and then smack upwards on the bottom of the press. If you have the screw down, reverse it.
I am Savvy
blackmagicbrakes.com
mrblaine is online now
URGENT URGENT!!! YJ Transfer Case in TJ ???? TJRider97 TJ Wrangler Technical Forum 4 03-06-2012 11:29 AM
Urgent advise needed! Tire/Wheel related USHotRod JK Wrangler Technical Forum 1 09-29-2011 03:12 PM
URGENT Brake advise please NateWithoutBeer YJ Wrangler Technical Forum 10 10-08-2010 08:49 PM
How to tell between kingpin and balljoint? sitdwnandhngon YJ Wrangler Technical Forum 5 03-07-2009 09:30 AM
d30 balljoint replacement Dmbguy357 TJ Wrangler Technical Forum 7 08-28-2005 09:46 PM
