Upper Track bar loose?? - JeepForum.com
post #1 of 11 Old 02-16-2012, 04:09 PM Thread Starter
NickM2828
Hey everyone, I just put in my Currie steering kit and noticed my upper track bar, where it fits over the ball, is loose. Not severely terrible or anything, just a little loose. I also think that is causing the 3-4 clacks when I accelerate from a stand still. What do you guys think?
Thanks,
Nick
****IF YOU CANT RAM IT, DODGE IT, IF YOU CANT DODGE IT.....GET A JEEP AND RUN OVER IT!!****
NickM2828 is offline
post #2 of 11 Old 02-16-2012, 04:18 PM
hatfield44
I was not aware there is a upper and lower trackbar
hatfield44 is offline
post #3 of 11 Old 02-16-2012, 04:20 PM
Jrob05
If your referring to the tie rod end of the front Trackbar then you should look into getting a new one before the evil specter of DW comes to haunt you. Do a dry steering test to check out everything else up front while your at it, anything loose or worn should be addressed and upgraded.
Jrob05 is offline
post #4 of 11 Old 02-16-2012, 04:20 PM Thread Starter
NickM2828
I'm really just wondering what the allowable play is where the track bar connects to the ball??
post #5 of 11 Old 02-16-2012, 04:22 PM
bairy
No play.
Buy a new one. Look at a MOOG track bar. If you look at the lower bushing it is far superior.
2006 LJ Claytonized
1999 TJ stockish
1987 J20
bairy is offline
post #6 of 11 Old 02-16-2012, 04:27 PM Thread Starter
NickM2828
Jrob05, the track bar doesnt connect to the tie rod, that is the drag link. I am wondering if the top of the track bar where it connects to the ball, which then connects to the frame should be loose.
http://www.boomspeed.com/bofh1968/jeep/alignment01.jpg
If you look at this picture it should show exactly what I'm talking about. Follow the track bar to the top right hand corner. That is the place!
Thanks,
post #7 of 11 Old 02-16-2012, 04:33 PM
Sundowner
Originally Posted by nickm2828 View Post
i am wondering if the top of the track bar where it connects to the ball, which then connects to the frame should be loose.
no.
Sundowner is offline
post #8 of 11 Old 02-16-2012, 04:37 PM Thread Starter
NickM2828
Thanks guys! I'm ganna see about the moog!
post #9 of 11 Old 02-16-2012, 04:46 PM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
I'm surprised nobody looked at your profile. If you've got 6" of lift as your profile says, you definitely don't want the stock type track bar.
Look into the Currie TJJ model. It requires 2" of front bumpstop extension, but you should already have about 3" or more with the long shocks normally used on 6" of lift...
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #10 of 11 Old 02-16-2012, 05:16 PM Thread Starter
NickM2828
Yes, I already have 2-3 inch bumpstops. Pretty sure its 3. I'm not sure if it is stock or not? Does the stock 98 tj come with an adjustable trackbar?
post #11 of 11 Old 02-16-2012, 05:57 PM
LJameson
No it doesnt
1990 YJ
LJameson is offline
loose , steering , track bar
upper 1/2 doors loose bbqfreak TJ Wrangler Technical Forum 3 02-28-2011 09:00 PM
Upper Steering Wheel shaft very loose Chris_24 YJ Wrangler Technical Forum 5 11-09-2009 07:45 PM
Loose upper ball joint NewLaw83 TJ Wrangler Technical Forum 6 05-30-2009 06:52 PM
Upper Steering Shaft loose, Repair ideas? Tecumseh TJ TJ Wrangler Technical Forum 6 01-22-2009 08:18 PM
Loose Upper front axle end control arm bushing RckyMtnTJ TJ Wrangler Technical Forum 3 05-08-2008 01:32 AM
