upper and lower ball joint replacement - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > upper and lower ball joint replacement
CCOR is your 1 stop source for everything Jeep!TJ 5.25" Speaker Adapters - NalinMFGSteinjager TJ tube doors
Unread 07-10-2013, 04:35 AM   #1
shnobi24
Good morning all I have a question and need some help. I tracked my dw to the front right or passenger side upper and lower ball joints. I have the parts ready to go but I need to know if there is any thing I should look out for or pay attention to when pulling the axle shaft. This is the first time trying this sort of thing. My jeep is an 04 wrangler w/ dania 30 in front. Thanks for your 2 cents .
shnobi24 is offline   Reply With Quote
Unread 07-10-2013, 05:32 AM   #2
Jeepsr4me
I just pull the whole knuckle off and pull shaft with it. No need messing with removing shaft or hub.
Jeepsr4me is offline   Reply With Quote
Unread 07-10-2013, 05:41 AM   #3
ekim
Ensure that the side your working on is flat or even raised a little in order to prevent a gear oil mess.
Especially on the long side, make sure you have enough room to get the shaft out - not parked next to a garage wall or another car for example.
ekim is offline   Reply With Quote
Unread 07-10-2013, 06:20 AM   #4
shnobi24
Cool thanks guys for the help :-D
Unread 07-10-2013, 07:05 AM   #5
reb162
Seeing you live in New York, you will have the same issues I just had from the Road Salt. They will be a ***** to get out. Make sure you have a qulaity C-frame press with the proper adapters (autozone, advanceauto, etc rent them for free). You will bend the harbor freight press (ask me how I know). Pre Soak for a day in PB Blaster and then clamp it up and put on some tension, hit side of knuckle with BFH, hit it with a torch and repeat til its out. Have you checked out Stu Olsen's website?
http://stu-offroad.com/axle/balljoint/balljoint-1.htm
reb162 is offline   Reply With Quote
Unread 07-10-2013, 01:24 PM   #6
shnobi24
Yes I used the proper tools but it still took a few hrs to finish. I just got back from the test drive all is tight. Thanks for all the help guys.
Unread 07-10-2013, 06:21 PM   #7
JEK3
JEK3's Avatar
I must be doing it wrong. My Harbor Freight press did the job without a whimper.
JEK3 is offline   Reply With Quote
Unread 07-10-2013, 09:30 PM   #8
mrblaine
Wizard of Brakes
mrblaine's Avatar
You aren't that dumb. There are 100's of instances of folks reporting bent frames on that HF POS over the years and you have seen them.
Next time I get a good one, you can loan me your HF POS and I'll send it back bent to crap. OTOH, if you get a quality one, I know for a fact you can put a 5' cheater on the end of a quality ratcheting breaker bar and break the breaker bar.
I am Savvy
blackmagicbrakes.com
mrblaine is offline   Reply With Quote
Unread 07-11-2013, 04:46 AM   #9
JEK3
JEK3's Avatar
I know many folks have mangled their HF ball joint presses. I'm just saying they won't instantly destruct as soon as you pull them out of the case like some people imply. I take my time, using nothing larger than my 2' HF breaker bar (best $10 I ever spent at HF, by the way). Sure, my ball joints aren't rusted in place, and I know that makes a difference.
Did you break the bar itself, or the ratcheting part?
Unread 07-11-2013, 05:13 AM   #10
shnobi24
I have the hf tool as well the trick is to take your time and make sure its in alignment before you but a breaker bar to it
Unread 07-11-2013, 06:44 AM   #11
J03_TJ
Self Smarted
J03_TJ's Avatar
Can I ask if you smack the side of the knuckle with a hammer after tightening down the press? Just wanting to make my HF press earn its money when the time comes.
J03_TJ is online now   Reply With Quote
Unread 07-11-2013, 07:58 AM   #12
mrblaine
Wizard of Brakes
mrblaine's Avatar
You should be smacking the press in the correct direction. If you elongate the holes in the inner C, you won't like the repair.
I am Savvy
Unread 07-11-2013, 07:59 AM   #13
mrblaine
Wizard of Brakes
mrblaine's Avatar
The bar, not the ratchet.
I am Savvy
Unread 07-11-2013, 08:34 AM   #14
J03_TJ
Self Smarted
J03_TJ's Avatar
Thanks, doesn't sound like a good use of JB Weld.
Unread 07-11-2013, 10:55 AM   #15
JEK3
JEK3's Avatar
If I remember correctly, they popped free before I got around to smacking the knuckle.
