Are upper control arms easy to put in? - JeepForum.com
post #1 of 2 Old 07-13-2005, 10:49 PM Thread Starter
cspoffroad
I am thinking about ordering some upper control arms to go with my lowers. I was just wondering if i could just unbolt the stock uppers and then bolt the new ones in, with the jeep just sitting on flat concrete?
Is this possible?
Thanks.
98' Jeep Wrangler Sahara
Skykacker 4inch, 33x12.50 BFG M/T's, kilby steering skid, optima red top, flowmaster 40 series, airaid intake and TBS, bestop bikini and halftop, lock-right in Dana 30
"Are you locked up?
Yup, both doors!!!!"
cspoffroad is offline
post #2 of 2 Old 07-13-2005, 11:06 PM
rubi-soho
rubi-soho's Avatar
The rears are a piece 'o cake... just bolt em in. as for the front do one at a time and use your factory bottle jack wedged between the frame and lower shock mount. The front axle will try to rotate the pinion up with spring force.... so the jack is necessary if you dont want to fight with the bolts.... and safer than the 2x4 prybar meathod.... its a 30 minute job
'04 Stone White Rubicon
five tires, metal stuff, slinkies and those HID lights everyone Loves?
rubi-soho is offline
Upper control arms-what to buy? TJamz TJ Wrangler Technical Forum 23 11-17-2009 06:24 PM
SYE and Upper control arms Daylan TJ Wrangler Technical Forum 7 06-16-2009 07:25 PM
Upper control arms Daylan TJ Wrangler Technical Forum 1 03-25-2007 10:31 PM
Upper Control Arms Lime Jeep TJ Wrangler Technical Forum 4 05-05-2006 04:21 PM
Upper control arms...which ones? ImaginaryFriend TJ Wrangler Technical Forum 8 04-04-2006 07:02 PM
