upper control arms diy? - JeepForum.com
post #1 of 3 Old 03-20-2013, 10:00 PM Thread Starter
mainemudbilly
How can you make upper control arms I'm a welder jus not sure if you just use the length of stock control arms or add some I got 4 inch left that came wit lower but want to upgrade uppers any thoughts on making homemade long arm kit? I got pipebenders n everything is need I think help me out
Cross the mountains and through the woods to the beer store we go
mainemudbilly is offline
post #2 of 3 Old 03-20-2013, 10:47 PM
Maverickxeo
I would assume if you set your pinion angles and measured the length of the control arm youd need, you could go with that length. I dont think there IS a proper measurement though. Just so you know, Im running adjustable lowers with a 4" short arm lift, and stock uppers currently.
Maverickxeo is offline
post #3 of 3 Old 03-21-2013, 02:28 AM
theGiantPanda
Swap This...
theGiantPanda's Avatar
you can make them. you will need to source 2 sets of poly bushings and sleeves if you are going to make them fixed length. if you want them adjustable you need to get about $50 in parts plus 2 bushing sets for your fixed end.
I am making a set of fixed uppers either tomorrow or Friday form my latest TJ project. I desperately need to correct my pinion angle. I plan on removing my stock uppers and adjusting the pinion with a jack to a corrected angle. then I will measure center to center for my new upper length.
I actually started the project today. I cut the 2 sleeves I need for the axle UCA mounts and found a piece of 1.5" DOM in the metal pile for the links. I will cut the sleeves for the frame side UCA mounts once I verify the width.
Originally Posted by CCJ View Post
Jesus. This is what heaven on 4 wheels looks like.
Hospital? What, are you suffering from Overextended Jeepaphelia or something? :)
I've never been poor, only broke. Poor is a state of mind. Broke is a condition brought on by Jeep ownership and a heavy right foot.
2006 Unlimited Redicon Panda Edition
RRI Long Arm...14" Fox CO's Front and Rear...D60 KP Front and D60 FF Rear... 5.38s spooled...40" Maxxis Trepadors...
6.1 HEMI...Atlas 5.1
5.7 HEMI 400 hp TJ Build
6.1 HEMI Ultimate LJ Rubicon Build
2.5 to 4.0L swap and build up
4.0 to 2008 5.3L GM LS in the Taco'd TJ [frame off build].....
My new DD Build, lift, 4.0 motor swap, done in 6 days?....
the new shop...
conversion, parts and wiring systems
shop email....
LIKE US on facebook.....
adding more daily
redrockindustries.net
theGiantPanda is offline
control arms , suspension , tj
