Upper control arm mount has come off. - JeepForum.com
post #1 of 6 Old 07-15-2012, 12:37 PM Thread Starter
MrKevinRosales
My father had noticed a change in ride quality in his 98 TJ, so he took a look at the suspension and he noticed that the rear upper control arm mount had become dettached from the frame. Pictures below.
What is the best way to fix this? We don't do any welding. What kind of place would be best to take this problem to? Or any specific place suggestions? We live in northeastern CT.
Thanks
MrKevinRosales is offline
post #2 of 6 Old 07-15-2012, 12:41 PM
ivester1992
i would see if you have any local machine shops that would weld it up for a fair price. or if you have any friends willing to. theres not a bolt on application for this so it has to be welded to the frame again
ivester1992 is offline
post #3 of 6 Old 07-15-2012, 10:08 PM
ratmonkey
R.I.P.
ratmonkey's Avatar
How bad is the rest of the rust on that frame? Before trying to her that repaired (hot rod shop or garage that specializes in customs is your best bet), you need to be sure the frame is worth fixing.
ratmonkey is offline
post #4 of 6 Old 07-16-2012, 04:25 AM
tjsean0308
as a New England Jeep owner I would highly doubt the frame is in much better shape I have seen this on several N.E. Jeeps but it was usually not the worst part of the frame.
tjsean0308 is offline
post #5 of 6 Old 07-16-2012, 04:53 AM
Necko2529
X2. Definitely check the frame and the rest of the frame-side control arm mounts and around the skidplate nutserts, that's where the rust is most like to start eating away at your frame.
Rokmen TT, Rokmen control arms, Novak NV241 cable shifter, JKS 1.25" BL + 1" MML.
Anybody can take advice if it doesn't interfere with their plan.
RIP "Prescott 19" Prescott Fire Department
Necko2529 is offline
post #6 of 6 Old 07-16-2012, 06:51 AM
fromme
fromme's Avatar
That weld looks like it had very little penetration. I bet a good weld will hold it just fine.
"The Wicked Flee When No Man Pursueth, But The Righteous Are Bold As A Lion."
fromme is offline
control arm , control arm brackets
Rear upper control arm mount broke gixxer1397 TJ Wrangler Technical Forum 9 09-21-2011 05:48 PM
Exhaust hitting upper control arm mount 06jeep TJ Wrangler Technical Forum 4 06-22-2011 07:13 PM
Broken upper control arm mount , Driverside rear OLDTJ TJ Wrangler Technical Forum 2 05-31-2011 10:31 PM
Rotted Upper Control Arm Mount! gfisher270 TJ Wrangler Technical Forum 5 05-05-2011 08:22 AM
Upper Control Mount Suggestions Sallad TJ Wrangler Technical Forum 15 01-20-2010 10:27 PM
