Upgrading my Rear Locker-ARB or Rubi Front Locker? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Upgrading my Rear Locker-ARB or Rubi Front Locker?
JK Bumper System - Free Shipping + Cash RebateSmoking Deal on Jeep Slip Yoke Eliminator Kit with rear 13Rough Country Jeep Suspension Deals at Rockridge 4WD!
Unread 05-26-2008, 04:19 PM   #1
tkki1230
I'll be re-gearing my Rubicon to 5.13, and I was thinking of upgrading the Rear Locker at the same time. I'll be running 33's for now, and then upgrading to 35's down the road. The first option I was considering was using a Rubi Front Locker along with stock spline count alloy shafts. The second option was using an ARB with either 33 or 35 spline shafts. Another option would be to just keep the stock rear locker and upgrade to stock spline alloy shafts. The jeep is a DD, and I wheel once a month, with most of the terrain being easy to medium grade. I am more concerned with strength and durability. I use the jeep for fishing, and I often go alone, so I need the Jeep to be bulletproof.
If I go with the ARB, would it be possible to use the factory switch?
tkki1230 is offline   Reply With Quote
Unread 05-26-2008, 04:42 PM   #2
mrblaine
mrblaine's Avatar
Factory front locker is a two pinion design. Arb is a 4 pinion design. Get the ARB and don't look back.
The Super 44 for what you are doing is about bulletproof.
I am Savvy
blackmagicbrakes.com
mrblaine is offline   Reply With Quote
Unread 05-26-2008, 06:54 PM   #3
tkki1230
OK- Super 44 it is.
Has anyone hooked up their ARB with the factory Rubicon switch? There were a couple of posts on another forum stating that it could be done, but the descriptions were vague. There is a Rubi that I saw where he has a separate switch for the ARB compressor and the locker itself, but when activated, the factory rear locker light in the dash flashes constantly. This must be a common thing, as I am sure that there are a lot of Rubi owners who've uupgraded to ARB's?
Unread 05-26-2008, 08:40 PM   #4
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
There's a guy in my club that went with 513s with his rubi.
He kept the rubi locker and it died soon after that. Then he went with an electric locker and it was built wrong. After that (third or 4th time taking the rear diff apart) he put a detroit in it.
You may be able to hook up the switch and the ARB. You would have to look at the leads for the switch itself.
Don't forget the different air compressor for the ARB.
Stretched TJ , Coil overs, 42" IROKS, 60/14 bolt...
'95 YJ fuel injected 302, 8.8, cage, ARBs.
My TJ Build Thread.
www.kifourwheelers.com
For Sale:
TJ Rear Dana 44 shaftsfor sale
3 11"& 2 13" BBCS shocks
JeepRocks86 is offline   Reply With Quote
Unread 05-26-2008, 08:45 PM   #5
Skeezer
100% Arb !
2005 Rubicon
Skeezer is offline   Reply With Quote
