Upgrading front brake pads and rotors? - JeepForum.com
post #1 of 17 Old 05-09-2008, 12:29 PM Thread Starter
05moabTJ
05moabTJ's Avatar
I just ordered EBC yellow stuff brake pads after hearing and reading about their great performance. Should I replace my stock rotors also? They are not worn or warped at all. I stop just fine now, just not as quickly as I would like with my 35's. What's the opinion on replacing rotors at the same time as pads?
Synergy 3" Phase 3,FOX,TOYOs 37",TrailReady 17HD Beads,RCV shafts,Yukon 5.13
05moabTJ is offline
post #2 of 17 Old 05-09-2008, 12:46 PM
TheBoogieman
Disturbed Jeepaholic
TheBoogieman's Avatar
Vanco if you have the bucksI don't,so i don't tailgate.
TheBoogieman is offline
post #3 of 17 Old 05-09-2008, 12:50 PM
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Depends on how worn they are.
If you are replacing the pads, you should definitely have the rotors turned. The minimum thickness is stamped somewhere on the rotor. Just take them to your local NAPA or other parts store/shop... they'll mic them out and cut them if possible.
Oh... and x2 on the Vanco kit. Very happy with mine.
I'll be Savvy someday!
neZZr is offline
post #4 of 17 Old 05-09-2008, 12:52 PM
DaOne
DaOne's Avatar
I always replace both the pads and rotors. I don't like the idea of turning the rotors. IMO, this just makes them too thin, which causes more runout or warping due to the increase in heat.
Just my 2 cents
...Sometimes, the more you see, the less you understand...
I miss my Jeep. On the hunt for a replacement.
DaOne is offline
post #5 of 17 Old 05-09-2008, 01:24 PM
FLATFENDER54
FLATFENDER54's Avatar
Rotors do not need to be changed or turned just because you are changing pads (inspect them first) They do not have to be perfectly flat/smooth like a brand new set. If they are in good shape and seasoned well just change the pads. ( I wouldnt ever turn them if they dont pass your inspection just replace them.......at least thats me)
01 TJ Sahara 4"short arm/rear gas&tire
carrier bumper/front winch bumper winch/detroitEz
1954 WILLYS CJ3B (under construction)
FLATFENDER54 is offline
post #6 of 17 Old 05-09-2008, 01:31 PM
Jerry Bransford
Administrator
Jerry Bransford's Avatar
Originally Posted by DaOne View Post
I always replace both the pads and rotors. I don't like the idea of turning the rotors. IMO, this just makes them too thin...
How can turning a rotor make it "too thin" if it's still within the thickness specification stamped on the edge of the rotor? Rotors are too thin when they reach that specification, not before then.
Jerry Bransford is online now
post #7 of 17 Old 05-09-2008, 02:44 PM
DaOne
DaOne's Avatar
I won't argue that...I just like to replace them. They aren't nearly as expensive as they used to be for a good set of rotors. I'm certainly not well educated in brakes, and much less so than a lot of you, which is why this is just my own preference
I read once about adherrent friction as a braking mechanism, why uneven deposits leading to "shudder", and why it is a vicious cycle once it happens. Even machining the rotor may not neccessarily fix the problem, because if you are overheating the rotor in localized areas -- that's not just a surface problem. As you wear the rotor metal away, the cementite inclusions remain and cause further hot spots. if you drive on the street at low brake temperatures, the braking mechanism is abrasion and you will wear away the transfer layer.
It just seems to me that anyway you cut it (literally haha), removing material from the rotor reduces its ability to dissipate heat much like a "heatsink" which has to increase hot spots and/or the possibility for warping even if it is still above the minimum thickness...no?
DaOne is offline
post #8 of 17 Old 05-09-2008, 02:51 PM
fish4life
So what you're saying is you'd rather spend the money unnecessarily, on new rotors then learn something new from the folks who you claim to be more knowledgeable then you
buying new rotors every time you change pads is a waste of money!!
fish4life is offline
post #9 of 17 Old 05-09-2008, 02:55 PM
DaOne
DaOne's Avatar
Not saying that at all...by all means, re-educate me I guess my way of thinking comes from some cars having those "throw away" rotors that didn't have much material at all to turn. Cost of turning was like $20, replacing was like $30. I just like to be safe when it comes to brakes even if it costs me an extra $30 or so.
DaOne is offline
post #10 of 17 Old 05-09-2008, 02:57 PM
Jerry Bransford
Administrator
You can find a pair of quality all-cast rotors for $30? Where? I'll buy a truckload of $30 high quality all cast rotors and sell them on eBay.
post #11 of 17 Old 05-09-2008, 03:03 PM
DaOne
DaOne's Avatar
Well, since you put it that way, I suppose you are correct. I think I actually paid around $150 for the Jeep, and $30 for the Honda...
DaOne is offline
post #12 of 17 Old 05-09-2008, 03:17 PM
fish4life
yeah, that sounds more like it ... besides i'd rather turn my original OEM rotors several times then buy over the counter crap that probably barely meets factory specifications in terms of quality....
post #13 of 17 Old 05-09-2008, 03:23 PM
Xlr8n
1967 JK Wrangler
The OEM rotors are crap as well. Some of the over-the counter rotors are actually better than stock. There aren't very many places that actually turn rotors anymore in my town. When my rotors on my XJ were too thin to turn at 30k miles, I took them back to the dealership where I bought the Jeep and just about blew a gasket! A friend from way back was the SM there and told me they simply aren't designed to last long anymore and are considered a disposable part. Cheaper for the dealerships to replace than spend time turning.
Xlr8n is offline
post #14 of 17 Old 05-09-2008, 03:24 PM
pilot-one
I paid $34 for a pair at Advance Auto. I have about 8000 miles on them and they are doing great so far.
Gravity Rat #149
But what do I know? I don't really even have a Jeep. I just make it up.
pilot-one is offline
post #15 of 17 Old 05-09-2008, 03:25 PM
Jerry Bransford
Administrator
Your '98 used composite rotors which are less expensive than quality all-cast rotors are that Jeep went back to using in later TJ models.
Those running 35"s. What brake pads/rotors? njbowhntr TJ Wrangler Technical Forum 88 02-11-2010 11:06 AM
Recommended Brake Rotors & Pads? cvd TJ Wrangler Technical Forum 35 08-19-2008 10:07 PM
I just need answers - hopefully not a fight?! (Brake pads and rotors) BlueJ TJ Wrangler Technical Forum 31 01-17-2008 09:36 AM
Need help with replacement brake pads and rotors bshwckr TJ Wrangler Technical Forum 10 07-26-2006 12:45 AM
Brake Pads And Rotors WR4NGLER TJ Wrangler Technical Forum 50 07-23-2004 05:31 PM
