upgrading BB - JeepForum.com
post #1 of 6 Old 05-22-2006, 11:44 PM Thread Starter
UTmike
UTmike's Avatar
upgrading BB
I've got a 2" budget boost that's only been on a few months. I used BDS shocks for it and it ran fine until i put a new rear bumper/tire carrier on and now it's just too heavy and it feels like it's bouncing around too much. I was thinking about getting some 2 1/2" Heavy Duty springs from OME. I'm pretty sure my BDS shocks that are made for a 2" lift will work fine, but are there any other heavy duty springs out there that are made for heavier rigs that give 3" of lift, and would my currents shocks work with a 3"lift? Thanks!
4.5" RE Long Arm, 37" Mud Grapplers on Beadlocks, OX Locked Dana 60s front and rear
UTmike is offline
post #2 of 6 Old 05-23-2006, 03:25 PM Thread Starter
UTmike
UTmike's Avatar
anyone have any input???
UTmike is offline
post #3 of 6 Old 05-23-2006, 03:38 PM
Wheelin98TJ
JEEP FREAK
Wheelin98TJ's Avatar
Just about every suspension manufacturer makes 3" lift coils. Teraflex, Rusty's, and BDS just to name a few.
With your shocks, how much room for down travel do you have now? Are the shocks maxed out at full droop, or do they still have some room left?
Wheelin98TJ is offline
post #4 of 6 Old 05-23-2006, 05:37 PM Thread Starter
UTmike
UTmike's Avatar
yeah, i was looking for some stiff coils like the OME heavy duty ones, my heavy rear bumper/tire carrier/hilift jack/jerry cans/cargo rack/bike rack really weigh it down. I was wondering if any of those guys made extra stiff coils for that. how am i suppose to know if i've maxed out the shock? won't it look the same when it's at it's max as it would w/a couple more inches left?
UTmike is offline
post #5 of 6 Old 05-23-2006, 05:43 PM
Wheelin98TJ
JEEP FREAK
Yea, it will look the same.
You'll have to unbolt the bottom end of the shock to see if has more room for travel. Unbolt both of them and flex the axle so you get max droop. Then get your shocks to the fully extended position and compare to where the shock mounting point is on the axle. If you have 1" or 2" to spare, then they will be long enough for a slightly longer coil.
post #6 of 6 Old 05-23-2006, 07:11 PM Thread Starter
UTmike
UTmike's Avatar
gotcha! a little more work I guess. so what about the heavy duty springs. Is OldManEmu the only one that makes them?
UTmike is offline
Upgrading BB to OME wizwoz TJ Wrangler Technical Forum 2 09-03-2009 11:42 AM
Upgrading tie rod Wrangler_91 TJ Wrangler Technical Forum 19 06-21-2009 07:54 PM
Upgrading tie rod? PhilipJ YJ Wrangler Technical Forum 19 01-19-2006 08:11 PM
upgrading to 4:88 reynir TJ Wrangler Technical Forum 3 07-23-2004 11:21 AM
upgrading slimcjp TJ Wrangler Technical Forum 2 07-01-2003 11:25 PM
