Upgrading Axles - JeepForum.com
post #1 of 9 Old 08-11-2010, 12:35 PM Thread Starter
carr51
Upgrading Axles
Finally getting a bit of cash flow and I was curious as to pricing for upgrading axles. I have a 2004 TJ with a D30 front and D35 rear. Both are geared to 3.07 and that needs changed. I want to get a 44 for the rear with 4.10s or 4.88s. Should I change the whole axle out and grab a 44 with the gears then regear the front? Also where would I find replacement axles either new or old it doesnt matter.
carr51 is offline
post #2 of 9 Old 08-11-2010, 12:38 PM
ChefTJ
D44 or 8.8 stronger?
ChefTJ is offline
post #3 of 9 Old 08-11-2010, 12:49 PM
Calven727
Its pretty easy to find an 8.8 but its gonna take a little more work to find a 44. And it shouldnt be that hard to find an 8.8 with 4:10 and limited slip.
So if you find a jeep 44 it should just bolt in but you will probably have to change the ratio. If you find a 8.8 with 4:10s you will have to add the brackets and a few other things.
Calven727 is offline
post #4 of 9 Old 08-11-2010, 12:53 PM
ChefTJ
Same strength?
ChefTJ is offline
post #5 of 9 Old 08-11-2010, 12:58 PM
Calven727
Originally Posted by ChefTJ View Post
Same strength?
Well ive seen some people say they are about the same but i have also seen this a few times
The axle shaft strength tested by Warn Ind:
F8.8= 6,500 (lb. ft.)
D44= 4,600-5,000 (lb. ft.)
D35C= 4,000-4,300 (lb. ft.)
8.8 FACTS, OPINIONS & HOW-TO'S (F.A.Q.) - JeepsUnlimited.com Forums
So this looks like they are pretty strong
post #6 of 9 Old 08-11-2010, 01:06 PM
GOLENJEEPTJ
Running Secretly Amok!
GOLENJEEPTJ's Avatar
What transmission do you have, and what size tires are you planning on?
GOLENJEEPTJ is offline
post #7 of 9 Old 08-11-2010, 02:51 PM
quitelifted
quitelifted's Avatar
There is also a vendor in the vendor area selling custom built 8.8s. Brackets, locker ECG I think it was. Alot depends on what tire size you want and how much/how hard your gonna wheel it.
quitelifted is offline
post #8 of 9 Old 08-11-2010, 04:50 PM Thread Starter
carr51
Transmission I am not sure, but I have a 4L with a 5spd transmission. I am only really planning on running 33s or maybe 35s max. I have thought about the 8.8, but I would prefer to bolt on than finding someone to help weld on the brackets.
carr51 is offline
post #9 of 9 Old 08-11-2010, 04:56 PM
2003X
I got a HPD30 and Ford 8.8 with 4.88s ready to bolt in for $2,100 from East Coast Gear Supply.
Enjoy -
http://www.jeepforum.com/forum/f43/b...mblies-947998/
My Build
2003X is offline
axle , upgrade , dana 30 , dana 35
Upgrading the axles of my 35 ballallday89 TJ Wrangler Technical Forum 24 03-06-2009 01:14 PM
94 axles to 91 Axles Brake issue???? lawson1273 YJ Wrangler Technical Forum 1 12-13-2008 11:10 AM
Upgrading axles, a few planning questions..... tj99 Wrangler General Discussion 0 11-30-2008 05:47 PM
Gearing In the Axles & Upgrading it IMYY4U JK Wrangler Technical Forum 5 04-14-2008 07:21 PM
Superior axles vs. Alloy axles BusyDoinNothing TJ Wrangler Technical Forum 21 06-30-2007 01:40 AM
