upgrading - JeepForum.com
post #1 of 3 Old 07-01-2003, 02:29 PM Thread Starter
slimcjp
upgrading
looking to upgrade to bigger tires. 35" to be exact. should i use 4.56 gears or 4.88 gears. also i have a 3" suspension lift kit installed and all i need is 4" lift springs and larger shocks. is there any company that will sell me just those things. and do i need anything else to upgrade to 35" tires?
slimcjp is offline
post #2 of 3 Old 07-01-2003, 09:43 PM
CoryB
CoryB's Avatar
2015 JK Wrangler
What rear diff do you have? A D35 won't hold up for very long with 35" tires.
What is your intended usage for the Jeep? 4" of lift will work for the street but not on the trail unless you bumpstop the heck out of it. Or you could sawzall the fenders.
How about longer anti-swaybar links?
Adjustable control arms?
SYE or t/case drop?
You have more things to consider here...
CoryB is offline
post #3 of 3 Old 07-01-2003, 11:25 PM
Animal
For 35 tyres youll need to put a body lift of at least 1" on and if you use 12.5 wide the brake lines and steering stops will need work
Animal is offline
Upgrading BB to OME wizwoz TJ Wrangler Technical Forum 2 09-03-2009 11:42 AM
Upgrading tie rod Wrangler_91 TJ Wrangler Technical Forum 19 06-21-2009 07:54 PM
upgrading BB UTmike TJ Wrangler Technical Forum 5 05-23-2006 07:11 PM
Upgrading tie rod? PhilipJ YJ Wrangler Technical Forum 19 01-19-2006 08:11 PM
upgrading to 4:88 reynir TJ Wrangler Technical Forum 3 07-23-2004 11:21 AM
