Upgrades with 2.5 liter - JeepForum.com
post #1 of 9 Old 11-05-2011, 11:16 AM Thread Starter
98Tjboy
Are the upgrades worth the money on the 2.5 L?(air intake, exhaust, etc.)
98Tjboy is offline
post #2 of 9 Old 11-05-2011, 11:19 AM
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
V8 or gears. thats about it.
Useful Write-Ups:
Fabrication & Build:
Funny:
Unlimited04 is offline
post #3 of 9 Old 11-05-2011, 11:31 AM
jeepinmichguy_
Soar Forever Six
jeepinmichguy_'s Avatar
Trade it in for a 4.0L.
ΜΟΛΩΝ ΛΑΒΕ
Jeepinmichguy is a jerk.
jeepinmichguy_ is offline
post #4 of 9 Old 11-05-2011, 11:33 AM
TheBoogieman
Disturbed
TheBoogieman's Avatar
Regear or inject the Gerbil with steroids!
TheBoogieman is offline
post #5 of 9 Old 11-05-2011, 05:05 PM
relgnarw
For the money, I'd do gears, anything else (other than forced induction) is going to be a waste of money.
"I had wobster at Wed Wobster" - Austin age 5
My onboard air build.
relgnarw is offline
post #6 of 9 Old 11-05-2011, 06:45 PM
aparke4
don't listen to the haters!! haha... I love my 4 cyl TJ... peppy around town and will hold 65-70 on the highway (hills still downshift to 4th - 4.88 gears going in this weekend - will report back...)
here is what I have done to my 01 TJ:
Banks header
DIY Cowl intake with AEM dry flow filter
64 mm bored 4.0 Throttle Body
magnaflow hi flow cat
4WD 2.5 inch cat back exhaust w/ turbo muffler
IAT relocation to air tube
Royal Purple 10w30 with K and N oil Filter
Mobil 1 Syn gear oil in Diffs
Hyline hood vent panel
cooling system is fresh and the motor stays around 190-203
clutch and tranny have 20k on them - motor has 22k on it (both replaced at same time by previous owner) ... so my jeep essentially has a new 2.5 motor to compare these mods to...
and a couple of other small things...
all my friends that drive it can not believe it is a 4 cyl jeep... I have had 4.10 gears and 33x10.50 tires for about 3 months (31's for about 6 months before) and I am getting 4.88's this weekend which will make I huge difference compared to the 4.10's... all these mods together helped a lot in drive-abilty but i am not sure how much real HP I have gained... they make the engine come alive sooner but it is still a slow vehicle...
let the engine breathe and regear and call it good - no need to do cam, forced induction, stroke on the 2.5... the engine block and size just does not have the capacity unless you want to spend $$
gears are the best bang for your buck though if running over a 31 tire... the 4.10's and 31's drove great
aparke4 is offline
post #7 of 9 Old 11-05-2011, 09:59 PM Thread Starter
98Tjboy
If you had to estimate how many percent more powerful, what would you guess aparke?
98Tjboy is offline
post #8 of 9 Old 11-05-2011, 10:28 PM
256ChiliPepper
Ill throw in my experiences with my 4 squirrels. Everything was done in the past 2 years My jeep now has 84,000 miles. Check my profile for details.
Tune up with coil, plugs, wires, cap rotor- noticeable power gains, and minor milage gains (but my old plugs had chunks missing out of the tips)
Cold Air Intake-No power or milage gains, just that cool intake "whoosh" noise
4.0L Throttle body- a little seat of the pants power feel, felt like it could live at higher RPMs easier, throttle response improved some
Flowmaster muffler and tail pipe- minor throttle response and the nice sound
Head rebuild-no noticeable power or milage, piece of mind everything was in good order
Electric fan to replace clutch fan- milage increased 0.5 mpgs, motor revved easier, more throttle response, down shifting the motor takes longer to wind down. Warms up faster in the winter too
4.88 gears-major power gains, milage jumped up 2 mpgs or so, defiantly worth it if you are running larger tires
My opinion would be to add an electric fan, muffler if you like to hear your motor, 4.0L throttle body if you can get one for cheap, 4.88s if you are going to 33s, and just let it be. Just my $0.02.
256ChiliPepper is offline
post #9 of 9 Old 11-06-2011, 06:31 AM
Tr00b
For me, I've got 31's and 4.10s and 150k on the stock engine trans etc. Too poor to swap gears or a motor. I just spent some time an and fixed what was broken and spent money, around 500 total on motor and exhaust. It runs smooth and quiet. All the parts are stock spec nothing special.
It's liveable... Even pleasant. But that was my goal. Depending on how trashed your current motor is, you might be assessing how much power it has unfairly.
Tr00b is offline
4.0 liter for 4.2 liter engine swap questions danlab825 YJ Wrangler Technical Forum 7 04-29-2015 06:28 AM
4 liter injectors on 2.5 liter? stevedude19 YJ Wrangler Technical Forum 11 10-05-2011 06:42 PM
3.8 liter vs 4.0 liter any suggestions rollmeovertj Wrangler General Discussion 22 06-02-2011 01:42 AM
2.5 Liter Engine swap to Mopar 340, 360, or 3.8 Liter Ethan03 TJ Wrangler Technical Forum 6 03-13-2011 08:40 PM
93 2.5 Liter Help DEAN062961 YJ Wrangler Technical Forum 3 04-07-2007 10:04 PM
