UPDATE: hi-amp alternator swap - Page 4 - JeepForum.com
post #46 of 76 Old 03-08-2011, 06:05 PM
Richd1963
Richd1963's Avatar
I know some of the guys who are using winches frequently run the idle up while winching. I am sure it is to get more JUICE to the battery(s)-Winch during usage. I hear they draw some amps. That is next on my Mod list are bumpers and winch.
Rich G. 2005 Wrangler 4.0 6-Speed.
just4effect 10" single sub, enclosure and amp 4 sale. PM me if interested, local only
Richd1963 is offline
post #47 of 76 Old 03-08-2011, 06:05 PM
wtroger
You do need to add or upgrade the wiring from the alt to the battery which is usually the place the rest of the jeep gets its power for the simple reason that when lead acid batteries are even slightly discharged (like starting) will take all the amperage the charging system can give until recharge has occurred. It is called in rush current this may be for just a few seconds or longer depending on the how discharged the battery is. If the wire from the alt to the tie in point is to small then some not to pleasant things can happen especially if the battery is deeply discharged.
wtroger is offline
post #48 of 76 Old 03-08-2011, 06:47 PM
drummerchukb1
x3 for what works on a 2.5l
drummerchukb1 is offline
post #49 of 76 Old 03-08-2011, 07:00 PM
Weeeee
Originally Posted by wrangler1988 View Post
Do you have a part number for that? I can only find the 136amp at napa???
X2 I am interested as well
Weeeee is offline
post #50 of 76 Old 03-08-2011, 07:19 PM
Richd1963
Richd1963's Avatar
Check the part #'s at the website I bought mine at and see if your 2.5l is the same.
Here:
http://storesense1.mysuperpageshosti...ail.bok?no=476
vs.
http://storesense1.mysuperpageshosti...ail.bok?no=697 for mine. So depending on the years. Check yours there!
post #51 of 76 Old 03-21-2011, 06:16 AM
jknutter
jknutter's Avatar
So for those that did an upgrade did you get a larger fusible link also? I did the 04 Durango alt upgrade yesterday, went to change the charge wire and came across the fusible link. Is there a larger one from Autozone as well?
2005 TJ Rubicon & 2014 WK2 Overland
jknutter is offline
post #52 of 76 Old 03-21-2011, 08:02 AM
NYMCTJ
Has anyone had any experience using the Mean Green alternator as an upgrade?
NYMCTJ is offline
post #53 of 76 Old 03-21-2011, 11:49 AM
jknutter
jknutter's Avatar
I found a 175amp in line fuse at Autozone and made my own fusible link out of 2 AWG cable.
jknutter is offline
post #54 of 76 Old 03-26-2011, 12:31 PM
AKGeo
Originally Posted by freeskier93 View Post
So let me get this straight, if I were to order a higher amp alternator for a 04 Durango 4.9l from advance auto or someone, it would bolt up to my 97?
Edit: No such thing as a 4.9L 04 Durango, I'm assuming whoever posted that earlier meant 4.7L.
Upgrade for a 1998 Dakota/Durango 360 would bolt in to a 97-03 TJ 4.0L.
I found this: https://www.dcpowerinc.com/fit/1998~...42-180-hp.html
$50 cheaper than the same upgrade specifically for the Jeep.
There's also a 270A alt on there but it's $600...crazy.
AKGeo is offline
post #55 of 76 Old 03-26-2011, 11:55 PM
Toonces
Originally Posted by nj95yj View Post
i would like to know if and what does fit the 2.5
The 136A alt out of a 96-98 ZJ, Durango, 1500 PN 56027913 will fit the 2.5. The difference from later years is the regulator. On 97-99 the regulator is external and 00+ the regulator is internal. The 160A alt mentioned for the later years has an internal regulator and is not a direct swap in. It could be used but you'd have to rewire to use the internal regulator. The higher 175 amp alts from Load Boss are rebuilt from the 136A alt. You can get a local alt shop to rewire your alt for a higher amp if you really want higher or buy one already rewound. The 136A alt 56027913 (NOT 56027913AB, it's internally regulated) runs around $40 from a junkyard.
Toonces is offline
post #56 of 76 Old 03-27-2011, 01:54 AM
5-90
5-90's Avatar
1988 XJ Cherokee
Originally Posted by sduncan View Post
Today my Dad and I swapped alternators on our TJs. There have been several threads lately about this but there was a bit of confusion on the earlier models. We both used Duralast alternators that we bought at Autozone. They easily bolted on with no fitment issues.
For my 98 w/ 4.0 : Autozone part #13387 136amp, is a DIRECT FIT. No changes are needed. This is an option for 1998 Dodge truck/Durango w/ 5.9 V8. Price was $147.00
For A 2003 w/ 4.0 : Autozone part #12328 160amp, is a DIRECT FIT. No changes are needed. This is for a 2004 Dodge Durango w/ 4.7 V8. Price was $121.00.
As I mentioned, for a '98 and an '03, these were direct fits and a great upgrade for the money spent.
The wiring connections for the field coils were the same? I know the ND alternators use M6-1.0 B+ studs as a rule, but you're right around the split where they went from two M4 studs for the field coils to a funky two-wire plug instead...
Please confirm - I'll use it to update my donor list...
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
post #57 of 76 Old 06-27-2011, 10:24 AM
99JeepWrangler
You have the right idea.
What I would do is get an upgraded alternator for a Durango from these guys...https://www.dcpowerinc.com/fit/1998~...42-180-hp.html
99JeepWrangler is offline
post #58 of 76 Old 03-13-2012, 02:28 PM
ClimbStuff
Some of the bigger winches are drawing 400-500amps on full 5-6 ton pulls on the top layers of cable. A popular mod is to use a hand throttle to raise rpm to spin up the alternator for extra juice.
ClimbStuff is offline
post #59 of 76 Old 07-10-2012, 02:57 PM
02ws666
What if you do not upgrade the wiring? Can anything bad happen?
2003 Wrangler - Light Khaki Metallic - 4.0 w/ nv3550, Smittybilt Stinger, Warn M8000 Winch, 4 Hybrid lift, G2 Dana 44s w/ 4.56 and E-Locker in front 30 spline, Detroit in rear 33 spline, 33x12.5 KM2s
02ws666 is offline
post #60 of 76 Old 07-10-2012, 04:27 PM
JBTJ
Yep, if you have a load on the circuit then the higher amp will fry the wire. It only makes sense, you upgrade the power supply, and you upgrade the wire. Don't want to cause a fire do you?
JBTJ is online now
Swap or update Sliver YJ Wrangler Technical Forum 2 01-31-2012 06:57 PM
Chevy Small block swap update Atropine YJ Wrangler Technical Forum 6 11-27-2009 08:54 PM
Update of 6.0 swap. simadownow6988 TJ Wrangler Technical Forum 28 11-16-2009 06:03 PM
update on my 4cyl to 6cyl swap duglas25 TJ Wrangler Technical Forum 9 03-08-2008 06:42 PM
alternator swap bugeater YJ Wrangler Technical Forum 0 08-24-2004 08:20 AM
