Quantcast UPDATE: hi-amp alternater swap - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > UPDATE: hi-amp alternater swap
Old 12-06-2009, 08:15 PM   #1
sduncan
sduncan's Avatar
Today my Dad and I swapped alternators on our TJs. There have been several threads lately about this but there was a bit of confusion on the earlier models. We both used Duralast alternators that we bought at Autozone. They easily bolted on with no fitment issues.
For my 98 w/ 4.0 : Autozone part #13387 136amp, is a DIRECT FIT. No changes are needed. This is an option for 1998 Dodge truck/Durango w/ 5.9 V8. Price was $147.00
For A 2003 w/ 4.0 : Autozone part #12328 160amp, is a DIRECT FIT. No changes are needed. This is for a 2004 Dodge Durango w/ 4.7 V8. Price was $121.00.
As I mentioned, for a '98 and an '03, these were direct fits and a great upgrade for the money spent.
'98 TJ, G2 33 spl. D44, HP D30,ARBs,4.10s, RE 4.5 LA,33in Mickey Thompson MTZs w/Pro Comp 15x10 alloys,Smittybilt XRC8 w/Amsteel rope, LED tail lites, Rampage top
Link to my Hemi build thread http://www.jeepforum.com/forum/f9/so-begins-5-7-hemi-conversion-1277803/
FOR SALE: 4.0 motor & TF999 trans, Premier Power Welder 195 amp,Fabtech Rockers
PM me for details.......
sduncan is offline   Reply With Quote
Old 12-06-2009, 08:20 PM   #2
Unlimited04
Unlimited04's Avatar
o0o good info
Unlimited04 is offline   Reply With Quote
Old 12-06-2009, 08:32 PM   #3
B_faster
So what would fit the 06? Is it the same as the 03? What is the output of the stock unit?
B_faster is offline   Reply With Quote
Old 12-07-2009, 03:33 PM   #4
Pipedrummer
My '04 4.0 has a 117amp stock alternator. I'd imagine its the same for the '06 if you have the same engine, not sure though.
Solar Yellow '04 TJ Sport, RE 3.5" Standard Kit w/ GEN 2 Discos, 33x12.5R15 Cooper Discoverer STT's on Black Crager D Windows, OME Shocks and Stabilizer, LOD Xtreme Duty Rear, Jeeperman Front w/ Pre-Runner Bar, Viair Constant Duty OBA - Front & Rear Quick Air Discos, Firetruck Air Horn, Galls Siren w/ PA, CARR Rotabar w/ KC Long Range Lights & KC Driving Lights, KC Fogs, Superwinch 9000lb, Viking Synthetic Line, Optima Yellow Top
Pipedrummer is offline   Reply With Quote
Old 12-07-2009, 03:59 PM   #5
SkylinesSuck
Just to be certain, they wouldn't have been interchangeable, right? I mean, they looked different and you couldn't have put the 160amp on the '98 TJ, right?
'98 Sahara w/5 speed & 4.6L stroker, 2.5" OME lift, 32x11.50 BFG M/T's, D30/35 with Trashlock and 3.07's :-(
SkylinesSuck is offline   Reply With Quote
Old 12-07-2009, 08:05 PM   #6
Best4x4
Best4x4's Avatar
03-06 4.0L Wrangler's should have the exact same setup. I'll probably being doing this before the end of the year myself. Just not a big fan of Auto-Zone's Duralast aka Duradead line of alternators/batteries. It does have a lifetime warranty though vs my stock unit lol.
05 Rubicon with a 4spd Auto, Banks CAI, Optima Yellow Top Battery, Mastercraft Rubicon Suspension Seats, MT Classic II Beadlock Rims with 33 Pro Comp M/T's, Rugged Ridge XHD Front Bumper, Rugged Ridge Rear Tire Carrier/Bumper, Warn Gas Tank Skid, GenRight Front Tube Fenders, Pro Comp 2.5inch Coil Springs, OME Shocks, JKS 1.25 BL, JKS 1inch MML, Warn XD9000i Winch with Warn Wireless Remote, Cobra CB with a 3ft Firestik Antenna, 48inch Hi-Lift X-TREME Jack, and all the survival gear needed for owning a Jeep.
Best4x4 is offline   Reply With Quote
Old 12-07-2009, 08:09 PM   #7
JeepRocks86
Some Call me RockDog
JeepRocks86's Avatar
good to hear.
Is the overall size of the alternators any larger than the stock TJ's?
Stretched TJ Future, Coil overs, 40s, 60/14 bolt
My Build Thread.
www.kifourwheelers.com www.indyorv.com
For Sale:
TJ 44 Combo, 4.88s, detroit, Alloy USA shafts, Disc Brakes, HD lower mounts, Clayton tube Truss
35" procomp tires with Aluminum wheels $650
(4) 5x4.5 steel beadlocks $200
3 11"& 2 13" BBCS shocks
Ford Dana 60 Rear $150
Big Daddy Offroad HD tie Rod
(4) 15x8 5x4.5 TJ, YJ, XJ, etc bolt pattern Aluminum wheels $175
JeepRocks86 is offline   Reply With Quote
Old 12-08-2009, 05:10 PM   #8
Pipedrummer
Just for clarification, were those prices for alternators bought new or rebuilt?
Old 12-08-2009, 06:10 PM   #9
fishinjeeper
i would guess rebuilt. seems pretty cheap to be new. are they both the same mounts? as in interchangeable? i have an 01 and dont know the year i will be needing
[CENTER]01 TJ. 35 inch KM2's. 4.5 RE. 2 inch body lift. dana 44. Detroit Locker. Olive Drab!! all set for trout and bambi![/CENTER]
fishinjeeper is offline   Reply With Quote
Old 12-08-2009, 06:48 PM   #10
Best4x4
Best4x4's Avatar
It should be 97-02 and 03-06 for part compatibility.
Old 12-08-2009, 06:59 PM   #11
BWFBezerk
New and rebuilt doesn't matter. On the rebuilt ones only the casing is reused, everything on the inside is all brand new. My question is will these fit the 4.0 and 2.4, or just the 4.0? I have an '04 SE and it has a 136 amp on it and it's starting to make noise, the AutoZone replacement is $180, can I get that 160 amp and put it in?
BWFBezerk is offline   Reply With Quote
Old 12-08-2009, 09:59 PM   #12
Pipedrummer
Interesting, mine is an '04 sport I-6 and only 117v. I think the older engines (maybe 02 and earlier) have a diff mounting location (somewhere near the bottom). My location is top left, looking at the engine from the front of the jeep. Where is yours on the '04 2.4?
Old 12-08-2009, 10:49 PM   #13
BWFBezerk
While standing in front of the Jeep, it's on the top right, extremely easy to get to. I was comparing my part number and the ones for the upgrade and the mounting holes and connector are the same, just that the connector is on the opposite side of the alt. I'm thinking if I can relocate the 2 plug connector then I can use the 160 amp one.
Old 01-11-2010, 07:34 PM   #14
dbbd1
dbbd1's Avatar
Do not know how I missed your post but yeah, I had one ordered from advance auto parts, it came damaged. Now, they say they do now have anymore. So, I ordered from autozone. No fitment issues (for the '03)? Did you cut off that sticking up nub thing?
Thanks
The opinions of worthless people, are worthless.
The only problem that you have with anyone in this world, is what you expect of them.
Society is no match for a stupid person.
"Life Is tough but it is tougher when you are stupid"
-John Wayne
dbbd1 is offline   Reply With Quote
Old 01-11-2010, 08:15 PM   #15
joeskyline06
maybe a dumb question...but did you notice your lights being any brighter?
joeskyline06 is offline   Reply With Quote
Glock Forum
