#121 | ||
want it rite or rite now?
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable HighLine Hood Jeepers TJ Adjustable Track bars DIY highline fenders.... 34-37's under 0"-2.5" lifts shock length, bumpstop extension, tire size chart click here DIY shock shifters, more uptravel/better ride 2011 E-350 4x4 Van conversion 2006 Rubicon Unlimited ASE Certified Master Tech/Fabricator In need of work... 11/2/11 |
#122 |
FINALLY got my Jeep back. It drives a bit different. Now i'm going to try to educate it to NOT shift at 45mph, since they reset and reflashed the TCM with the latest and greatest program.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? |
#123 |
Different in a good or bad way?
2005 LJ- Mostly stock/ DD 2000 TJ- Slowly Rebuilding 1976 CJ7- 304/TH400 | 3" suspension | Warn 9.5ti | |
#124 |
haven't decided yet. need to put more miles on it.
#125 | |
Unlmtd04 all your threads come back to the 42rle sooner or later! Might be prudent to go for another fluid change with the guys who caught the debris just to be sure the rebuild was tidy. Good luck with the new pieces. I hope your vaca. wasn't totally shot from the loos of the LJ. Our winter cabin trip was stifled by WalMart Lube Express jamming a wrench on my alternator and frying a hole in it. The jeep was packed and all. We switched vehicles but the time away was a little overshadowed by the incident.
After resetting my LJ the ?stall? (hi rev without upshift) got nice and high around town in D with OD on, it is staying in 1 better off-road too. As long as I stay mostly off the gas, before it would just idle right up through the gears between stop signs and then stumble to get me into 1 as I roll to a stop shuddering. No upshifts in D off road on a decline either As for highway I immediately noticed an ability to keep it in three as long as I don't fluctuate the accelerator at all. Climbing a hill I can maintain 3 on a hill with a slight steady increase in accelerator too. But once I crest a hill it goes right to four. That's when I go for the button anymore. I plan to reset again now that I know the game and have been more accustom to "tranny training". |
#126 |
Rokmen rock sliders underway - got em used for a good price. No idea how 'used' rockers come to be, but whatever I saved a ton of money since I got everything- rocker gaskets, internal reinforcement braces, all hardware and the sliders. There was a few scratches on the passenger side, but other than that they were in good shape. I had a set of aluminum BDO's originally, then decided I didn't want to go with aluminum and drill through the body, so I traded those off, then got a set of Garvin frame mounted rock sliders, but decided I wanted body mounted steel for more complete protection...so basically I've been very indecisive. Finally settled on Rokmen's after seeing a friends rig and meeting the Rokmen guys.
So I sanded them down with fine grit sandpaper - cleaned all rust, loose paint and sealant off. ![]() Primed with this stuff, and lightly sanded again to ensure a smooth surface. ![]() About herniated myself doing a test fit today. Found out I've got interference with the PSC roll cage bolt that goes through the floor and the rock sliders. I couldn't get the sliders in place without a better floor jack and more wood, so I've got to look at my friends rig and how his mount. I'd prefer to tie to slides into the cage, but I may just end up grinding out a section to clear the bolt. Theres already a slot in the slider for drainage, but its not near big enough to clear the bolt, and I can't even tell if it lines up right. The PSC cage bolt is like 1", so this isn't going to be much fun. I don't even know if my drill could torque through 1" of steel, even if I had the right bit. The rockers fit around my Kilby body clamz, but it will make install a bit more complicated, just more wiggling.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? Last edited by Unlimited04; 07-29-2009 at 01:23 PM.. |
#127 |
Updates!
Got an alignment done again (Firestone lifetime thing) - was toed out 0.58* total since the lift settled. I had some death wobble issues going on, and the drivers side wheel bearing was subsequently killed. Now the toe-in is correctly set and it drives beautifully. No wobbles, no harmonics and tight steering all the way up to 70mph. Caster actually got worse - was 3.9*/4.0*, about a 0.5* drop since the first alignment. Weird. Next up...I'd like to find a Currie steering setup or a ZJ tie-rod...patiently waiting for the right cheap price ![]() CB roll bar mount is finished, I couldn't take the bright silver look so I had to paint it black - ![]() Also made a new third brake light and CB antenna mount - http://www.jeepforum.com/forum/7666050-post2033.html I got the Rokmen sliders finished - 2 coats of primer, 3 coats of semi-gloss black, 2 coats of black Hammered finish, 2 coats of Clearcoat. Opened the drain slot up a bit with a grinder so I can tie them into the PSC cage. I plan to install them next weekend. ![]() The quality on these Rokmen's is amazing. Its hard to explain till you see them in person, the welds are literally perfect, the fit is awesome and the bare metal itself is extremely clean.
#128 |
I think the sliders come up for sale when something such as the Savvy sliders come out. People think they need the latest thing so they ditch their perfectly fine sliders. What kind of deal did you get?
#129 | |
I had thought about the aluminum thing for a long time - I went back and forth on design aspects, weight and frame vs body mounted for several years, but I just gotta bite the bullet and start drilling some holes. Rockers should help me be a little less worried on trails. And today I just figured out my Jeep has to go BACK to the stealership - the damn front passenger side axle seal is leaking again. They just replaced it in Sept of last year under warranty too. . Damn if it isn't one thing its another...
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? Last edited by Unlimited04; 08-02-2009 at 10:12 PM.. |
#130 |
Got the sliders on:
![]() Full coverage with the Kilby body mount skids: ![]() Internal Reinforcements ![]() Tied into the roll cage with one 5/16" bolt and one 1" bolt. ![]() ![]() Theres a 1/16" rubber gasket against the mounting surface (held on with construction adhesive), a rubber door gasket around the lip, one tube of silicon caulk and one can of undercoating in there to keep rust at bay. I put grip tape on the bars to use as a step - that didn't even last 12 hours. Horrible idea. I ripped them off this morning after removing a chunk of skin from my leg like I had a fight with a belt sander. The paint is black "Hammered" finish, the internal black paint is rattle can "Plasti-Coat". It did a sweet job on my battery tray, so I figured I'd give it a shot on the floor.
Useful Write-Ups: SEARCH TUTORIAL TJ Tech BOOT CAMP-A Must Read! FAQ: Cold Air Intakes & K&N's Off-Road Tips and Techniques What is a CV shaft and why do I want one? So you want a Tummy Tuck? Tire size, lift height, bumpstops & shock guide DIY Shock Shifters for Long Travel Shocks Lug nuts and bolt patterns Catalytic Converters Busted TJ Track Bar Bolt Fix Brake Knuckle Divot/Groove Repair Coconut Oil for Drilling and Machining Fabrication & Build: My Build Thread Funny: Will it fit in my Jeep? Last edited by Unlimited04; 08-10-2009 at 09:49 PM.. |
#131 |
nice find!
are you still messing with a trans temp gadge that will run off the tranny's thermistor? here's some stuff I ran across while doing some diagnostics on a 42rle... the thermistor puts out 1.8 v at 100 degrees.. ![]() ![]() the violet wire at t54 on the TCM is the temp wire.
#132 |
o0o nice mudb8.
I've also got the two stage voltage graph from the 42RLE's temp sensor (in the FSM), which i forwarded to Scangauge some time back. They got back to me, and while the graph shows what voltage = what temp, it doesn't specify where in the PCM/TCM that data is stored, which is whats needed access it from the X-Gauge. They claim they're working on it tho. I'll forward those pages and see if that helps. I'd love to get a temp gauge into the Scangauge...my dash is cluttered enough as it is with CB, GPS, radar detector, Scangauge, cell phone, iPod, roll cage, kitchen sink, etc...
#133 | |
#134 | |
![]() The X-Guage is hopefully the ticket tho - digital programming ![]()
#135 |
I love your build and how similar it is to mine.
Coming along nicely! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
