Quantcast Unlimited04's LJ Build - Page 6 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Unlimited04's LJ Build
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 06-09-2009, 07:27 PM   #76
Unlimited04
Unlimited04's Avatar
NEastUnlmtd - where do you get control arm interference? front or rear? upper or lowers? frame side or axle side mount?
I didn't look at the control arm, just the track bars. Let me know where you see interference and I'll check mine.
Originally Posted by jeepfreak4life7 View Post
Very nice. Looks like it's ready for regear and 33's.
How is it on the highway? I know this is a ridiculous question, but notice anything with gas mileage? Your gonna love that OME kit even more after a while. Even with 80k miles on mine, it still felt great.
I haven't noticed a big change in gas mileage yet, but I haven't been keeping track. Just guessing off the Scanguage. I don't really care about mileage much anyway. Thats what my pedal bike is for. Its a 4.0L, I'm happy as long as its over 11mpg city and 15mpg hwy. I feel the wind resistance more, especially with the 42RLE's relentless search for Overdrive.
It rides awesome on the highway, even up to 80mph, especially after I got the wheel spacers back on. I have noticed more pre-death wobble with the wheel spacers tho - I've narrowed it to them for sure. They may not be perfectly balanced, or more likely it is a result of the change in scrub radius. I'm searching locally for some cheap alloy or steel 15x8 wheels w/ 4" backspacing. The reduction in caster with 31s does make the Jeep want to wander, especially around 55-65mph. It wants to follow ruts in the road, causing it to pull left slightly at times. The higher profile is definitely noticeable too, I can feel pushing more wind, and I can feel strong crosswinds causing the body to sway more. Keep in mind my roll cage + hard top makes my Jeep somewhat top heavy to me, even when I was on stock springs. I'm very cognisant of center of gravity, probably more so than most.
But overall, I'm very happy with the way it turned out. Still a great daily driver, still fits in the garage and its the tallest lift i'd ever fell comfortable with. I'll probably use these tires up, then put some 33s on aftermarket wheels, sell the Ravines, and save the Moab's for some winter tires.
Unlimited04 is offline   Reply With Quote
Old 06-09-2009, 07:40 PM   #77
Jeepguy1977
That Rubi Crawler thing is cool....oh wait, won't work with my 32rh
1998 TJ, 4.0L Auto | 3" Nth Springs | JKS QDs | D30 Detroit True Trac | Nth Tummy Tucker | 35x12.50r15 Goodyear MT/R | JB Super Short SYE| 1.25" BL | Novak Tcase Shifter
Rolled Red Jeep Club Member #7
Jeepguy1977 is offline   Reply With Quote
Old 06-09-2009, 07:53 PM   #78
Unlimited04
you can get a Klune
a D300 + Klune will fit in a TJ. So should an Atlas + Klune. A supershort NP231 SYE + Klune may fit too.
Old 06-09-2009, 08:47 PM   #79
mudb8
want it rite or rite now?
mudb8's Avatar
the front lower arms hang up on the shock pad mounts, the rear also hang up on the top of the axle mount with stock ca's. most round aftermarket arms clear both...
you can clearance both...
my rancho arms only hit the fronts with 26" shocks... I raised the rear lower mounts, so I clearanced them..
sorry about the small photo, took me a while to find it. must be why it wasn't in the apropriate album..
I run hard, it yank'd the mount off the axle from pounding on it...
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
In need of work... 11/2/11
mudb8 is offline   Reply With Quote
Old 06-09-2009, 08:56 PM   #80
Unlimited04
what should the eye-to-eye lengths be for front and rear lower CA's with 2.5-3" of lift?
Old 06-09-2009, 10:58 PM   #81
mudb8
mudb8's Avatar
16" works well with stock uppers and keeps enough caster.
Old 06-09-2009, 11:20 PM   #82
elkfan2
elkfan2's Avatar
you can get a Klune
Why not just go 4 speed atlas?
elkfan2 is offline   Reply With Quote
Old 06-09-2009, 11:32 PM   #83
Unlimited04
4-speed Atlas: $2875
3-speed Stak: $2900
Klune: $2600
^^damn thats expensive.
My idea:
Rubicon NV241J: $800-1000
AA Rubicrawler: $1600
Total: $2400-2600
Saves a few hundred bucks and doesn't change the drivetrain length at all.
Old 06-09-2009, 11:52 PM   #84
elkfan2
elkfan2's Avatar
3-speed Stak: $2900
Klune: $2600
My idea:
Total: $2400-2600
I would rather spend a few hundred more and have a gear driven transfer case, and I only had to shorten the rear drive line a half inch, so I don't think changing the drivetrain length was a big deal in my case.
Old 06-10-2009, 12:01 AM   #85
mudb8
mudb8's Avatar
I'll be going after the rubicrawler also.. wont' need any new driveshafts, shift linkages... ect.
I'd say since I havn't busted the 241 yet, it'll prolly last a long time...
I do like the atlas tho.. that's for sure
Old 06-10-2009, 12:05 AM   #86
elkfan2
elkfan2's Avatar
If I had a 241 I wouldn't replace it for an Atlas, but by the time you buy a used 241 and add a rubicrawler to it its getting too close to the price of a brand new atlas 4 me.
Old 06-10-2009, 08:12 AM   #87
Unlimited04
but you can put a 241 in for the same price as a SYE installed. Run it for several years, then add a Rubicrawler for less than half the cost of Atlas 4-speed once you figure new driveshafts, tub hammering and linkages. I can't afford a Rubicrawler or an Atlas right now. But a NV241J + $20 used Rubicon front driveshaft + 1310/1330 u-joint + Tom Woods rear shaft is doable, and will work forever if I want. Once I do get the money saved for a Rubicrawler, I can install it with zero changes to the drivetrain.
Compare that with an SYE in the NP231, a Teralow in the NP231, then blowing it up. Then going to an Atlas. Thats very spendy for the same result.
Old 06-10-2009, 09:45 AM   #88
klimb2xs
What do you have planned for the 241 linkage? Factory or aftermarket? I thought about reusing my factory stuff, but I did not like the feel of the engagement. After having the Novak 231 shifter I went with their new 241 cable shifter.
Black Jeep Society
Originally Posted by walldk View Post
Step away from from the vehicle and seek professional help.
klimb2xs is offline   Reply With Quote
Old 06-10-2009, 01:13 PM   #89
Unlimited04
Interesting, i'll look into that. I was just going to fabricate something if necessary or bend the stock linkage to make it work. Do you have any pics of the cable shifter?
Old 06-10-2009, 07:06 PM   #90
klimb2xs
Here is the only picture I have of it.
It uses the stock lever so you don't have to bend the shift arm like the old models.
Black Jeep Society
Glock Forum
