Quantcast Unlimited04's LJ Build - Page 3 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Unlimited04's LJ Build
The Original 3/8" Ruffstuff Diff Cover!Ruffstuff Axle Simple Swap Kit!RUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 05-17-2009, 09:54 PM   #31
LJameson
mudb8, are the drive shafts on TJ's ''timed'' or not? What I'm getting at is do you need to mark the position of the drive shaft before you remove it?
2005 LJ- Mostly stock/ DD
2000 TJ- Slowly Rebuilding
1976 CJ7- 304/TH400 | 3" suspension | Warn 9.5ti |
LJameson is online now   Reply With Quote
Old 05-17-2009, 09:59 PM   #32
Knuckelhead
Knuckelhead's Avatar
Originally Posted by mudb8 View Post
nothing wrong woth cam bolts and they don't cost 150 bucks... a little tack weld does wonders...
I had to put these in last week to correct a 3.5" re that has adjustable uppers... it wasn't enough including cutting off the end of the threaded shaft to make the upper even shorter...
Isn't he talking about the rear axle?...
Originally Posted by Yucca-man View Post
My experience is that poly loves to groan
Knuckelhead is offline   Reply With Quote
Old 05-17-2009, 10:00 PM   #33
Knuckelhead
or that fluid is going to spill all over.
Not on a TJ NP231...
Old 05-17-2009, 10:08 PM   #34
Unlimited04
Unlimited04's Avatar
can't i just pull the driveshaft off without touching the slip yoke in anyway? like by pulling the u-joints off or something? or is that even more trouble than its worth?
Unlimited04 is offline   Reply With Quote
Old 05-17-2009, 10:16 PM   #35
spyder6
Just violated my Parole
spyder6's Avatar
you have to remove the rubber boot between the shaft and the output shaft for it to slide off. it weighs about 35-40 lbs so be careful to not catch it with your face.
fluid wont come out of the transfercase, the slinger is protecting the bearing and seal on the back.
USAF
Blue Crush Build
When is the last time you saw a fully installed upper front control arm pointing straight down?
Really?
spyder6 is offline   Reply With Quote
Old 05-17-2009, 11:38 PM   #36
mudb8
want it rite or rite now?
mudb8's Avatar
only the slip shafts like the rubi or cv shafts. they need to be in phase, not necessarily marked tho.. the wranglers are fixed and slide in and out of the extention housing of the t-case
yep, and the front has a wobble that may be needing some caster to fix... that's the stink I was making about the cams.. In the rear they are a real PITA..
I want your factory 07-up take-off/thrown out JK front/rear Lower Control Arms! Bent ones are perfect also as long as the bushings and cold cut rings are in good shape/useable
HighLine Hood Jeepers
TJ Adjustable Track bars
DIY highline fenders.... 34-37's under 0"-2.5" lifts
shock length, bumpstop extension, tire size chart click here
DIY shock shifters, more uptravel/better ride
2011 E-350 4x4 Van conversion
2006 Rubicon Unlimited
ASE Certified Master Tech/Fabricator
In need of work... 11/2/11
mudb8 is offline   Reply With Quote
Old 05-18-2009, 08:03 AM   #37
Unlimited04
the theory is i've got two things going on. Pre-death wobble and t-case vibes. trying to divide and concur...which may need FWD to diagnose.
Old 05-18-2009, 10:38 AM   #38
Shakey
I'd also check the control arms as a cause for any wobble. I know that once I added my lift after about two years of wheeling it stock, the bushings in my stock arms were shot and were the sole cause of death wobble. After I installed my Currie arms, problem solved. The way you describe your problem is exactly how mine started, FWIW.
I would also add rocker guards ASAP, assuming you plan on wheeling it places like Spring Creek, Wheeler Lake or Holy Cross. I know that even with 3" of lift and 33s, those three trails routinely abuse the rocker guards on my Unlimited.
Shakey is offline   Reply With Quote
Old 05-18-2009, 11:16 AM   #39
irishgearhead
The ZJ tie rod is in the "Next on the List" section. I've been doing mods methodically in stages with a finally goal in mind, but funds are short right now.
BUT...the GOOD NEWS...FINALLY got the rear shock in!
It took 4+ hours and several idea attempts, chisels, BFH's and a case of beer, but one weld-nut is busted off and one is drilled through and mangled pretty good. I didn't have enough Class 10.9 or Grade 8 washers, so we ended up stacking a bunch of Grade 2 or less washers to get me home. The bolts torqued just fine to ~25 ft-lbs, the recommended spec, so I'm going to run it like this for a while and watch for problems.
Got 400+lbs of tools in the back right here (still sits level!):
I've decided to drive around with all my tools in back for a week to try to settle the springs a bit.
I also re-centered the rear axle today. Its still slightly pushed to the drivers side, but I don't think I can get it much better. One more turn on the JKS track bar may push it too far the other way.
The BAD NEWS - I've got vibes and a steering shimmy. I'm going to get the tires balanced and re-torque the front track bar some more tomorrow.
The vibe symptoms - slight steering wheel shimmy/wobble under 40mph - very tolerable. BUT - as soon as you hit 48-50mph the steering wheel shimmy hits, the vehicle doesn't become uncontrollable, but its definitely two hands on the wheel and annoying as hell. I didn't get over 55mph - and its worse under throttle, 3rd gear or OD don't matter - vibes the same. Steering wheel just shimmy's and vibes side to side rapidly. Goes away after getting below 45mph. DEATH WOBBLE? OR SYE/CV??
Until this thing settles, I'm getting ~3.5" of lift from the 2.5" lift kit, and I've got a TT .
did you set the toe an 1/8 inch out? thats what fixed mine.
If it will float, fly or **** its cheaper to rent!!
irishgearhead is offline   Reply With Quote
Old 05-18-2009, 02:05 PM   #40
LGriffith
I have the same steering wheel shaking problem as you I believe. Atleast it sounds the same. I got back from Rausch and my steering wheel wasn't centered so I think I messed up the alignment. I'll wait until I get my front track bar before I get it aligned though. Not enough shaking to be a problem yet...
04 LJ|2.5" OME|RE arms|1" BL|ROKMEN|Savvy|33" MTZ's
LGriffith LJ Build
LGriffith is offline   Reply With Quote
Old 05-18-2009, 02:18 PM   #41
Unlimited04
the desired toe isn't effected by the lift or tire size. you do need to adjust it, but it should remain in the stock spec range. As I stated in post #1, a laser alignment was done, and as I stated in post #8, the toe is at 0.15/0.14 degrees (L/R).
The steering shimmy is 99% fixed. I over-torqued the track bar and put the stink arm on a crescent wrench w/ locktite to the JKS adjustment nut. Had the tires balanced, they were both road force balanced and were 1-2oz off. The Jeep pulls to the left slightly and wanders more, but I expected this due caster decrease w/ 31s.
I've still got vibes from the driveline, but its not bad at all. Tolerable, but since I know thats the t-case vibrating itself to death, I'm going to start with stacking washers.
The new thing is every time I hit a big bump going slow, when the front axle drops and rebounds, I get a loud clunk. No idea what that is.
Old 05-18-2009, 06:50 PM   #42
Shakey
I had the same lift and front diff cover, but different track bar, but mine did the same thing. It was the track bar hitting the diff cover. (that's one of the many reasons I ditched the OME springs as well).
Did you loosen any control arms when you added the lift? If so, did you re-torque them?
Old 05-18-2009, 07:19 PM   #43
Unlimited04
did not loosen any control arms. I'm pretty sure its not the track bar hitting the diff cover - no signs of hitting my diff cover, no paint marks - and my stock track bar did hit the diff cover, so I know what to look for. I also added bumpstops to the front, which should help keep the track bar off the diff cover.
Maybe shocks? I had no idea what the torque spec is on the upper shock mounts, OME's instructions just said three turns past the poly beginning to compress, whatever the heck that means. Give me a quantitative spec and I'll hit it, this qualitative spec sucks. I just compressed them till there was over 1/2" of stud thread sticking out.
Old 05-18-2009, 09:55 PM   #44
mudb8
mudb8's Avatar
your's for shipping if you want it....
Old 05-18-2009, 10:13 PM   #45
Unlimited04
that 1"? for 2003+ metric bolts right?
Glock Forum
jeeppartsdept.com
Get your jeep parts here. Full line Jeep dealer. HUGE DISCOUNTS!
