Unlimited04's LJ Build - Page 29 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Unlimited04's LJ Build
BDS 4-1/2" Suspension Lift Kit - Jeep Wrangler YJRuffstuff 10 year saleRough Country Lift Kits and Parts!
Unread 04-09-2012, 04:02 PM   #421
Unlimited04
This post/info=my opinion
Unlimited04's Avatar
Originally Posted by -sean- View Post
Yeah, got an 05' Rubicon (see sig). Actually just got done removing the BL and MML a few minutes ago. One hour flat.
I like the supercharger idea, I will be keeping an eye on how that goes. I knew a guy with a similar set-up and he loved it, said the 42rle was no longer an issue.
What kind of boost are you planning on running?
Nice Boost will be low...~7psi area. Gotta see how the IAT's look without an intercooler.
Unlimited04 is offline   Reply With Quote Quick reply to this message
Unread 04-10-2012, 01:53 PM   #422
thn394
Unlimited 04 did you notice in your LJ sat higher in the front with the 934 springs as opposed to the 933's? I'm looking to see if the 933's sit a bit lower than the 934's without any additional weight on the front end.
thn394 is offline   Reply With Quote Quick reply to this message
Unread 04-21-2012, 10:53 PM   #423
Unlimited04
Covered the differences here. It sits where I want it.
Unread 04-21-2012, 10:58 PM   #424
Unlimited04
Sold my Hobart Handler 140 and got a Millermatic 211 Autoset (runs 110V & 220V). It hurts the wallet, but will pay for itself quickly
Put it to good use on the trailer:
The tub is taking shape...next up is framing the tailgate, finish welding, and add sheet metal.
Unread 04-21-2012, 11:13 PM   #425
spyder6
Got that Toyota chit
spyder6's Avatar
2010
you'll really like that 211, i love mine. you'd be impressed with what it can do when you're burning with gas. these are my dicking around welds on 3/16ths plate before i left for the AF
My builds: Bruiser and The Grey
|Forge Overland| or follow us on Facebook
spyder6 is offline   Reply With Quote Quick reply to this message
Unread 04-22-2012, 08:45 AM   #426
tailhole
Love my miller's
tailhole is offline   Reply With Quote Quick reply to this message
Unread 04-22-2012, 10:14 AM   #427
Hendrix
TJOTY 2013
Hendrix's Avatar
What ya planning on doing with the trailer? Hay rides? :shh:
Looks good man.
Hendrix is offline   Reply With Quote Quick reply to this message
Unread 04-22-2012, 08:31 PM   #428
Mannyssj13
Looking good man love your build.
Mannyssj13 is offline   Reply With Quote Quick reply to this message
Unread 05-02-2012, 03:01 PM   #429
4wdjeepguy
Have you had any issues running these extensions? What meterial did you use again? I'm assuming you just drilled out the stock threads and ran a bolt through? Or would it be structurally sound to use longer bolts with the existing threads. Great idea. I have about 1.5" of up travel I can't use because of my extended bumpstops. Might as well turn it into down travel.
My Thread
http://www.jeepforum.com/forum/f22/clip-bowtie-2203257/
4wdjeepguy is offline   Reply With Quote Quick reply to this message
Unread 05-02-2012, 08:44 PM   #430
Unlimited04
no issues yet. maybe because i have the bumpstops set before the shocks bottom out. the "extensions" are just steel spacers I bought from the local hardware store. no drilling involved, the front mounts do not use weld-nuts. the bolt and mount is basically in perfect tension/compression, there shouldn't be much of a side load at all....but if bumpstops aren't proper, i could see potential for buckling. i think if it was going to do it again, i'd weld them together with some plate to make it less of a damn finger fumble to install.
I will be removing these soon however. After making bar pin shock mounts for my trailer and seeing some builds on here, I'm going to cut the bar pin mount completely off my front axle, make new ones out of C-channel and weld them about 1" lower than stock. Then I will run N66L shocks, with a compressed length of 15.5"...which normally requires 2" bumpstop extensions...but using my current 1-3/8" bumpstop extensions. basically running 4" lift shocks on 2.5" of lift. Lots more down travel, lots more flex. Hopefully I'll also do the rear lower mount outboard I've been meaning to get to for over a year too...
Looks good man.
thanks funny guy. my friend said the same thing..."hmmm...that'd be good for takin' a big bail out to the horses"....he's talking about those big half ton hay bails...crazy cowboys
Here's another trailer picture, with Jeep tailgate frenched in....just need to drill and tap the hinge mounts now.
Unread 05-03-2012, 07:22 AM   #431
tweenerlj
Subscribed to follow your trailer build...looking good!
tweenerlj is offline   Reply With Quote Quick reply to this message
Unread 05-15-2012, 09:02 AM   #432
G Beasley
X2 ... Your way looks much easier than mine
G Beasley is offline   Reply With Quote Quick reply to this message
Unread 06-10-2012, 08:42 AM   #433
Unlimited04
Trailer updates:
Sheet metal is almost done. Tub can be separated from the frame, and bolts in place with button head screws (15 of them ).
CJ tailgate is mounted & cables done....that was an ordeal. Busted off a tap and had to cut the whole mount off and make a new one, then drill & tap again. .
For the latches, I may do this:
http://www.jeepforum.com/forum/f9/lo...wners-1007833/
Next up: 7" wide TJ fender flare install, finish minor body work, caulk/seal tub, drain plugs, Chassis Saver, paint & Monstaliner.
Unread 06-10-2012, 09:00 AM   #434
Unlimited04
Also, was driving highway for an hour in 97F heat, and A/C is still causing engine to heat up too much. IAT's in the 160F-190F range, tranny temps 180-200F range, 220F coolant temps and climbing w/ A/C, but 204F w/o A/C. I've had these issues almost since new, but because I only use A/C like two weeks a year before the hard top comes off, I've just been dealing with it for years. I've discussed the whole overheating issue extensively in the Explorer fan thread...main link here. The difference this time was a CEL tripped for P0432 (main cat), dash buzzers going and all. Engine compartment was very very hot, and power/acceleration sucked. Appears the mini-cats have finally died....will be making a custom exhaust setup from manifold back to muffler to relocate the cats out of the engine compartment...my theory is this may reduce underhood temps, IAT's & tranny temps. Parts are already on order. May finally work up the courage to cut holes in the hood for the junkyard Grand Prix hood vents I've had for almost 2 years....here's the Oman4x4 hood vent write up reference.
Unread 06-10-2012, 11:20 AM   #435
spyder6
spyder6's Avatar
2010
looks great man. I'm going to get my hands on an M101A2/A3 trailer one of these days
