Quantcast Unlimited04's LJ Build - Page 15 - JeepForum.com
Go Back JeepForum.com > Models > Jeep Wrangler Forums > TJ Wrangler Technical Forum > Unlimited04's LJ Build
DISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp Series
Old 12-18-2009, 07:40 PM   #211
crqflier
I'm hoping I can ditch the t-case drop with the Currie upper arms...guess theres only one way to find out for sure. Besides, I don't mind drilling, my muffler isn't in the way
crqflier is offline   Reply With Quote
Old 01-23-2010, 01:45 PM   #212
phittie1100
Good thread - I took my trans swimming at 69k miles, and as you might imagine it was not happy. The trans shop that rebuilt it for me has turned out to be the biggest group of idiots I have ever had to work with, plus they will not install a bung in the pan, claiming it will eventually leak and the mod would void their rebuild warranty. The NAPA T-adapter is exactly what I was looking for - the one concession I got out of the trans shop was them installing a HD trans cooler, but I am having regular trouble with the trans burping up fluid when it gets hot. I need the temp guage so I can see what it is doing, the T-adapter should not give them any cause for grief. My popup is big and heavy, and still running stock 3.73 gears with my 33s does not help the trans run any cooler, especially on hilly, back roads.
Paul - 2004 Wrangler Unlimited
VP - GLFWDA
KD8PAV
phittie1100 is offline   Reply With Quote
Old 01-24-2010, 12:35 PM   #213
toddallen
Unlimited04, I saw on another thread you talking about gap guards for a body lift. Did you make your own?? If so do you have any pics of it??? I looked through your thread but didn't see anything about it, but I might have over looked it.
2004 LJ Wrangler, 5" Suspension Lift, 1.25" JKS BL, 1" JKS MML, 35"x12.50"x15"
toddallen is offline   Reply With Quote
Old 01-24-2010, 02:03 PM   #214
Unlimited04
Unlimited04's Avatar
Post #130 - Kilby Body Clamz
That what you mean?
Unlimited04 is offline   Reply With Quote
Old 01-24-2010, 02:36 PM   #215
toddallen
No, I was talking about the gap guard in the rear fender well. Between the frame and the body to hide the fact that you have a body lift.
Old 01-24-2010, 02:44 PM   #216
Unlimited04
i painted the body with undercoating and flat black paint.
Old 01-24-2010, 02:45 PM   #217
toddallen
I C thanks
Old 01-25-2010, 12:46 PM   #218
Unlimited04
I C thanks
it doesn't look bad...if people make fun of it, i'll pull out a tape measure and show them belly clearance of 4" lift & 33s, with 2.5" of lift & 31s... the enormous bike rack hitch looks worse, lol.
Old 01-25-2010, 02:34 PM   #219
rubidriver
rubidriver's Avatar
I forsee 35s in the near future sir.
2005 Black Rubicon - OME 933/942 - OME N66/N67 - JKS Adj Track Bars Front/Rear - JKS Quicker Discos - 285/75/16 MTZ
Originally Posted by bigj1974 View Post
your money will go farther in College Station.
rubidriver is offline   Reply With Quote
Old 01-25-2010, 03:29 PM   #220
CCJ
this thread is full of win
CCJ is offline   Reply With Quote
Old 01-25-2010, 03:38 PM   #221
CCJ
10 characters
Old 01-25-2010, 04:54 PM   #222
Unlimited04
you buying em? cuz my 31s are about 5k away from the wear indicators!!
HP D30 is coming well...slowly but surely....waiting till I get everything together before I post progress on it. But heres a hint - I pulled the old Clevite bushings out...it was easy and only took about 15 minutes per side. No fire either.
Old 02-01-2010, 07:29 PM   #223
Unlimited04
I think my B&M gauge crapped out. It's been behaving weird, spiking temps from 140 to 240 in an instant, so I pulled out the multimeter. The sensor gives a nice consistent resistance (about 530 Ohms for ~120 degrees). I can watch the resistance change with temp, so I don't think its a problem. The gauge output to the sensor keeps fluctuating widely....it gives 5.xx volts one sec, then 12.xx volts, then 10.xx volts the next. So the gauge shows 140*F one sec, 240*F the next. Needle bounces all over the place.
Gonna take it apart tomorrow, call Summit or B&M and see what I can figure out.
Old 02-01-2010, 11:15 PM   #224
ankyle62
posting to find this later for post #69, good info.
ankyle62 is offline   Reply With Quote
Old 02-01-2010, 11:27 PM   #225
Imped
TITS
Imped's Avatar
I hope you replaced them with a certain Currie product.
OlllllllO
Float Test Build
IndyORV
Best served cold
Imped is offline   Reply With Quote
Glock Forum
